IF6031
IF6031
    IFM(易福门)
    Cylinder,Threaded-M12
    INDUCTIVE SENSOR; M12 X 1 / L =
IF6031 数据手册
IF6031 Inductive analogue sensor IFK4004A2PKG/IO/US Product characteristics Housing threaded type Dimensions [mm] M12 x 1 / L = 70 Electrical data Operating voltage [V] Current consumption [mA] Protection class 15...30 DC < 20 II Reverse polarity protection yes Outputs Analogue voltage output [V] 0...10; (linear; gradient: 2,77 V/mm; for frontal approach and for target made of mild steel: 12 x 12 x 1 mm) Min. load resistance [Ω] 2000 Short-circuit protection yes Overload protection yes Detection zone Measuring range [mm] 0.4...4 Accuracy / deviations Correction factor steel: 1 / stainless steel: 0.7 / brass: 0.5 / aluminium: 0.4 / copper: 0.3 Linearity error of analogue output [%] ± 3; (of UA max) Repeatability analogue output [%] ± 2; (of UA max) Temperature coefficient ± 10 %; (of UA max) Response times Response time [ms] < 10 [°C] -25...80 Operating conditions Ambient temperature Protection IP 67 Tests / approvals MTTF [years] 220 ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF6031-00 — 18.08.2017 — IF6031 Inductive analogue sensor IFK4004A2PKG/IO/US Mechanical data Weight [g] 44.5 Housing threaded type Mounting non-flush mountable Dimensions [mm] M12 x 1 / L = 70 Thread designation M12 x 1 Materials Tightening torque housing: brass white bronze coated; sensing face: PBT [Nm] 7 Displays / operating elements Display within the operating range 1 x LED, yellow lights outside the operating range 1 x LED, yellow flashing Accessories Items supplied lock nuts: 2 Remarks Pack quantity 1 pcs. Electrical connection - plug Connector: 1 x M12 Connection ifm electronic gmbh • Friedrichstraße 1 • 45128 Essen — We reserve the right to make technical alterations without prior notice. — EN-GB — IF6031-00 — 18.08.2017 —
IF6031 价格&库存
很抱歉,暂时无法提供与“IF6031”相匹配的价格&库存,您可以联系我们找货
