SS24 SMA
SS24 SMA
    BORN(伯恩)
    SMA(DO-214AC)
    表面安装肖特基势垒整流器SMA VRRM=40V Io=2A IR=0.5mA
SS24 SMA 数据手册
SS22-26 SERIES SCHOTTKY SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS ROHS FEATURES  For surface mounted applications  Metal silicon junction,majority carrier conduction  Low power loss,high efficiency  Built-in strain relief,ideal for automated placement  High forward surge current capability  High temperature soldering guaranteed: 250℃/10 seconds at terminals  The plastic material carries U/L recognition 94V-O MECHANICAL DATA  Case: JEDEC DO -214AC. molded plastic  Terminals: Axial leads. Solderable per MIL - STD - 750 Method 2026  Polarity: Color band denotes cathode  Weight: 0.003 ounce. 0.093 grams  Mounting position: Any MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 ℃ ambient temperature unless otherwise specified. Single phase. half wave. 60HZ. resistive or inductive load. For capacitive load. derate current by 20% SYMBOL SS22 SS23 SS24 SS25 SS26 UNITS Maximum Recurrent Peak Reverse Voltage VRRM 20 30 40 50 60 V Maximum RMS Voltage VRMS 14 21 28 35 42 V Maximum DC Blocking Voltage VDC 20 30 40 50 60 V Maximum Average Forward Rectified Current 9.5mm Lead Length. TA = 75℃ I(AV) 2.0 A IFSM 50.0 A Peak Forward Surge Current 8.3ms Single half-sine-wave superimposed on rated load Maximum Forward Voltage at 1.5A DC Maximum Reverse Current Tj = 25℃ at Rated DC Blocking Voltage Tj = 100℃ 0.50 VF 0.70 0.5 IR 15.0 V mA Typical Junction Capacitance ( Note 1 ) Cj 150 pF Typical Thermal Resistance ( Note 2 ) RQJA ℃/W Tj 20 55 to 125 TSTG 55 to 150 ℃ Operating Junction Temperature Range Storage Temperature Range NOTE: ℃ 1. Measured at 1.0MHZ and applied reverse voltage of 4.0V DC 2. P.C.B.mounted with 0.2×0.2 (5.0×5.0mm)copper pad areas Rev 8: Nov 2014 bufan www.born-tw.com Page 1 of 2 SS22-26 SERIES SCHOTTKY SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS ROHS Fig.2-Maximum Non-repetitive Surge Current Fig.1-Forward Current Derating Curve 80 2.0 At rated TL 8.3ms single half sine-wave 1.5 60 1.0 40 0.5 20 SS22-SS24 SS25&SS26 0 0.0 25 50 0 1.0 75 100 125 150 10 175 100 Number of Cycles at 60HZ Lead Temperatrue(℃) FIG. 4 -- TYPICAL REVERSE CHARACTERISTICS 10000 Instantaneous Reverse Current(uA) 50 TJ=125℃ 10 AMPERES INSTANTANEOUS FORWARD CURRENT, FIG. 3 -- TYPICAL INSTANTANEOUS FORWARD CHARACTERISTIC TJ=150℃ 1 TJ=25℃ 0.1 SS22-SS24 SS25&SS26 0 0.0 0.2 0.4 0.6 0.8 1 1.2 TJ=75℃ 100 1.0 1.4 TJ=25℃ 0 20 40 60 80 100 Pervent of Rated Peak Reverse Voltage(%) FIG. 5 -- Typical Junction Capacitance FIG. 6 -- Typical Transient Thermal Impedance 100 Transient Thermal Impedance(℃ /W) 1000 Junction Capacitance(pF) SS22-SS24 SS25&SS26 10 INSTANTANEOUS FORWARD VOLTAGE / VOLTS 100 SS22-SS24 SS25&SS26 0 0 Rev 8: Nov 2014 TJ=125℃ 1000 10 0 Reverse Voltage (V) www.born-tw.com 0.01 0.1 1 10 100 Page 2 of 2
SS24 SMA 价格&库存
很抱歉,暂时无法提供与“SS24 SMA”相匹配的价格&库存,您可以联系我们找货
