S2ABG THRU S2MBG
Surface Mount General Purpose Silicon Rectifiers
Reverse Voltage - 50 to 1000 V
PINNING
PIN
Forward Current - 2 A
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
MECHANICAL DATA
• Case: SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
Marking Code: S2A~S2M
Simplified outline SMB and symbol
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %
Symbols
S2ABG
S2BB G
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
Maximum RMS voltage
V RMS
35
70
Maximum DC Blocking Voltage
V DC
50
100
Maximum Average Forward Rectified Current
I F(AV)
2
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
60
A
Maximum Instantaneous Forward Voltage at 2 A
VF
1.1
V
IR
5
100
μA
Cj
25
pF
RθJA
RθJC
60
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
Typical Thermal Resistance
(1)
(2)
Operating and Storage Temperature Range
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
REV.08
1 of 3
S2DB G S2GBG
S2JB G
S2KBG
S2MBG
Units
400
600
800
1000
V
140
280
420
560
700
V
200
400
600
800
1000
V
S2ABG THRU S2MBG
Fig.2 Typical Instaneous Reverse
Characteristics
Instaneous Reverse Current ( μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
2.5
2.0
1.5
1.0
0.5
0.0
25
50
75
100
125
150
175
100
T J =150°C
T J =125°C
10
T J =100°C
1.0
T J =75°C
0.1
T J =25°C
0.01
Junction Capacitance ( pF)
Instaneous Forward Current (A)
10
1.0
800
100
T J =25°C
10
T J =25°C
0.1
0.4
1
0.6
0.8
1.0
1.2
1.4
1.6
1.8
0.1
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
1.0
10
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
600
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
100
Number of Cycles
REV.08
400
200
Instaneous Reverse Voltage (V)
Case Temperature (°C)
2 of 3
100
S2ABG THRU S2MBG
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
3.3
5.08
0.05
0.8
0.152
1.9
155
220
7.9
59
12
87
200
2.0
32
6
75
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
130
160
Marking
The recommended mounting pad size
2.2
(86)
2.4
(94)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
REV.08
E1
3 of 3
Type number
Marking code
S2ABG
S2A
S2BBG
S2B
S2DBG
S2D
S2GBG
S2G
S2JBG
S2J
S2KBG
S2K
S2MBG
S2M
很抱歉,暂时无法提供与“S2KBG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.15193
- 200+0.12180
- 600+0.10506
- 3000+0.08630
- 9000+0.07759
- 21000+0.07290
- 国内价格
- 1+0.11550
- 100+0.10780
- 300+0.10010
- 500+0.09240
- 2000+0.08855
- 5000+0.08624
