HL-A-4014H489W-S1-HR3-DM-HL(4750K-5300K) 数据手册
Under Development
Mass production
RoHS
Specification
规 格 书
Customer Name:
客户名称:
Customer P/N:
客户品号:
Factory P/N: HL-A-4014H489W-S1-HR3-DM-HL(改良无孔)
公司品号:
Sending Date:
送样日期:
Client approval
客户审核
Approval
核准
□ Qualified
接受
Hongli approval
鸿利智汇审核
Audit
确认
□ Disqualified
不接受
Approval
核准
Audit
确认
Confirmation
制作
黄巍
李卫
翦桂云
DATE:
日期:
Adr:No.1,Xianke Yi Road,Huadong Town,Huadu District,Guangzhou,China
地址:中国广州市花都区花东镇先科一路1号
Tel/电话:020-86733333
Fax/传真:020-86733883 86733938
86733265
Web/网址:www.honglitronic.com
注:1.此规格书以中英文方式书写,若有冲突以中文版本为准文本.
2.此规格书的最终解释权归鸿利智汇集团股份有限公司
3.此规格书的有效期限为两年,自盖章或签字之日起计算,期满时双方可以续签协议,但应采用书面形式
SPEC NO:B-17-A-1547
REV NO: A/2
DATE: May/07/2018
PAGE: 1 OF 13
Under Development
Mass production
Features( 特征)
PLCC-2 Package.(PLCC-2 封装)
Extremely wide viewing angle.(宽的发光角度)
Suitable for all SMT assembly and solder process.(适用于所有的SMT组装和焊接工艺)
Available on tape and reel.(适用于载带及卷轴)
Moisture sensitivity level: Level 4.(防潮等级 Level 4)
Package:4000pcs/reel..(包装每卷4000PCS)
RoHS compliant. (RoHS 认证)
ATTENTION
Description(描述)
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
DISCHARGE
SENSITIVE
DEVICES
The White LED which was fabricated using a blue chip and the phosphor
白光LED由蓝光芯片与荧光粉激发而成
注意:操作时应注意静电敏感
释放设备装置
Applications(应用)
■ Optical indicator(光学指示)
Package Dimensions(封装尺寸)
■ Indoor display(室内显示)
4.00 [0.16]
■ Automotive lighting(汽车照明)
3.70 [0.15]
(LCD背光、转换器,开关和标志,显示器等)
■ Tubular light application(用于日光灯管)
2
1
1.45 [0.06]
0.95 [0.04]
■ Backlight for LCD, switch and Symbol, display
0.40 [0.02]
Recommended Soldering Pattern
(建议焊盘尺寸图)
0.50 [0.02]
1
2
0.95 [0.04]
0.75 [0.03]
2
0.70 [0.03]
■ General use(一般应用)
1
Notes:(备注)
1. All dimension units are millimeters.(所有标注尺寸单位为毫米)
2.All dimension tolerance is ±0.15mm unless otherwise noted.(除特别标注外,所有尺寸允许公差±0.15mm )
SPEC NO:B-17-A-1547
REV NO: A/2
DATE: May/07/2018
PAGE: 2 OF 13
Under Development
Mass production
Selection Guide(选择指南)
Part No. 型号
Chip Materials 芯片材料
Lens Type 胶体类型
(改良无孔)
InGaN
Yellow Diffused
Mass Production list(批量生产目录)
Part No. 型号
CCT(K)
Min
CCT(K)
Typ
CCT(K)
Max
Φ(lm)
Min
Φ(lm)
Typ
Test Conditions
测试条件
6000
6500
7000
23
25
IF=60mA
5700
6000
6500
23
25
IF=60mA
4750
5000
5300
23
25
IF=60mA
3800
4000
4250
23
25
IF=60mA
3250
3400
3650
22
24
IF=60mA
2800
3000
3100
22
24
IF=60mA
2600
2700
2800
21
23
IF=60mA
HL-A-4014H489WS1-HR3-DM-HL(改良
无孔)
Electrical / Optical Characteristics at Ta=25°C
电性与光学特性
Parameter(参数)
Symbol
(符号)
Min.
(最小)
Typ.
(平均)
Max.
(最大)
Units
(单位)
Test Conditions
测试条件
Forward Voltage
正向电压
VF
2.8
3.4
V
IF=60mA
Viewing Angle
角度
2θ1/2
120
Deg
IF=60mA
Color Rendering Index
显色性指数
Ra
80
IF=60mA
Note:(备注)
21/2 is the angle from optical centerline where the luminous intensity is 1/2 the optical centerline value.
21/2 是半值角,指光强是光学中心线光强的1/2处到光学中心线的角度
2. The above luminous flux measurement allowance tolerance is ±10%.
上述发光通量的测试允许公差为±10%
3. The above Color Rendering Index measurement allowance tolerance is ±
2
以上显色性指数的测试允许公差为±
2
4. The above forward voltage measurement allowance tolerance is ±
0.1V.
以上所示电压测量误差±
0.1V
5. The above color coordinates measurement allowance tolerance is ±0.003.
以上所示坐标测量误差±
0.003
SPEC NO:B-17-A-1547
REV NO: A/2
DATE: May/07/2018
PAGE: 3 OF 13
Under Development
Mass production
Absolute Maximum Ratings at Ta=25°C
绝对最大额定值
Parameter(参数)
Symbol(符号)
Rating(值)
Units(单位)
Power Dissipation(功耗)
Pd
306
mW
Forward Current(正向电流)
IF
90
mA
Peak Forward Current [1](峰值正向电流)
IFP
135
mA
Reverse Voltage(反向电压)
VR
5
V
Reverse Current
反向电流
IR
10
uA
Electrostatic Discharge (HBM)(静电)
ESD
1000
V
Operating Temperature(操作温度)
Topr
-40 ~ +85
Storage Temperature(保存温度)
Tstg
-40 ~ +100
Junction Temperature结温
Tj
115
Note:(备注)
1. 1/10 Duty cycle, 0.1ms pulse width.(脉宽0.1ms,周期1/10)
SPEC NO:B-17-A-1547
REV NO: A/2
DATE: May/07/2018
PAGE: 4 OF 13
Under Development
Mass production
Typical optical characteristics curves 典型光学特性曲线
Ambient Temperature VS Allowable Forward
Current 周围温度与允许电流特性
Forward Current VS. Relative Intensity
正向电流与相对光强特性曲线
Rthj-s=80℃/W
Forward Voltage VS. Forward Current
正向电压与正向电流特性曲线
SPEC NO:B-17-A-1547
REV NO: A/2
Ambient Temperature VS. Relative Intensity
环境温度与相对光强特性曲线
DATE: May/07/2018
PAGE: 5 OF 13
Under Development
Mass production
Relative spectral emission
Radiation diagram
SPEC NO:B-17-A-1547
REV NO: A/2
相对光谱分布特性曲线
辐射图特性曲线
DATE: May/07/2018
PAGE: 6 OF 13
Under Development
Mass production
0.44
2700K
0.42
OS
3000K
3500K
0.40
NS2
WS
4000K
NS1
0.38
5000K
0.36
CS2
6500K
0.34
CS1
6000K
60-5
0.32
0.30
0.30
0.32
0.34
0.36
0.38
0.40
0.42
0.44
0.46
0.48
Bin Range of Chromaticity Coordinate Bin区分类及色坐标范围
Nominal
CCT
Bin Code
Target Center Point
(cx,cy)
Major Axis,
a
Major Axis,
b
Ellipse Rotation
6500K
CS1
0.313,0.337
0.01115
0.00475
58.23°
Sing 5-step
6000K
60-5
0.3220,0.3365
0.01179
0.00504
59.21
Sing 5-step
5000K
CS2
0.346,0.359
0.01370
0.00590
59.37°
Sing 5-step
4000K
NS1
0.380,0.380
0.01565
0.00670
54.00°
Sing 5-step
3400K
NS2
0.409,0.394
0.01585
0.00695
52.58°
Sing 5-step
3000K
WS
0.440,0.403
0.01390
0.00680
53.10°
Sing 5-step
2700K
OS
0.463,0.420
0.01290
0.00685
53.17°
Sing 5-step
SPEC NO:B-17-A-1547
REV NO: A/2
DATE: May/07/2018
Angle,θ
Color Space
PAGE: 7 OF 13
Under Development
Mass production
Reliability Test Items And Conditions 信赖性测试项目及条件
Test Items
项目
Ref. Standard
参考标准
Test Condition
测试条件
Time
时间
Quantity
数量
Ac/Re
接收/拒收
Reflow
回流焊
JESD22-B106
Temp:260℃max
T=10 sec
3 times.
22Pcs.
0/1
Temperature Cycle
温度循环
JESD22-A104
120℃±5℃ 30 min.
↑↓5 min
-40℃±5℃ 30 min.
100 Cycles
22Pcs.
0/1
High Temperature Storage
高温保存
JESD22-A103
Temp:100℃±5℃
1000Hrs.
11Pcs.
0/1
Low Temperature Storage
低温保存
JESD22-A119
Temp:-40℃±5℃
1000Hrs.
11Pcs.
0/1
Life Test
常温通电
JESD22-A108
Ta=25℃±5℃
IF=60mA
1000Hrs.
11Pcs.
0/1
High Temperature
High Humidity Life Test
高温高湿通电
JESD22-A101
85℃±5℃/ 85%RH
IF=30mA
1000Hrs.
11Pcs.
0/1
Failure Criteria 失效判定标准
Test Items
项目
Symbol
符号
Failure Criteria
判定标准
Test Condition
测试条件
Min. 最小
Max. 最大
Forward Voltage
正向电压
VF
IF=60mA
U.S.L*)x1.1
Reverse Current
反向电流
IR
VR = 5V
10uA
Luminous Flux
光通量
lm
IF=60mA
L.S.L*)x0.7
U.S.L: Upper Specification Limit 规格上限
L.S.L: Lower Specification Limit 规格下限
*The technical information shown in the data sheets is limited to the typical characteristics and circuit examples of the referenced products. It does not constitute the warranting of industrial property nor the granting of any license.
数据工作表中所示的技术信息仅限于典型特征和电路实例引用的产品.它既不构成工业特性的保证,也不构成任何许可的
授权.
SPEC NO:B-17-A-1547
REV NO: A/2
DATE: May/07/2018
PAGE: 8 OF 13
Under Development
Mass production
SMT Reflow Soldering Instructions SMT回流焊说明
1.Reflow soldering should not be done more than two times. 回流焊不可以做两次以上
2.When soldering , do not put stress on the LEDs during heating
当焊接时,不要在材料受热时用力压胶体表面
Soldering iron 烙铁焊接
1.When hand soldering, keep the temperature of iron below less 300℃ less than 3 seconds
当手工焊接时,烙铁的温度必须小于300℃,时间不可超过3秒
2.The hand solder should be done only one times
手工焊接只可焊接一次
Repairing 修补
Repair should not be done after the LEDs have been soldered. When repairing is unavoidable,
a double-head soldering iron should be used (as below figure). It should be confirmed in advance
whether the characteristics of LEDs will or will not be damaged by repairing.
LED回流焊后不应该修复,当修复是不可避免时,必须使用双头烙铁(如下图),但必须事先确认此种方式会或不会
损坏LED本身的特性。
Cautions 注意事项
The encapsulated material of the LEDs is silicone. Therefore the LEDs have a soft surface on
the top of package. The pressure to the top surface will be influence to the reliability of the LEDs.
Precautions should be taken to avoid the strong pressure on the encapsulated part. So when use
the picking up nozzle, the pressure on the silicone resin should be proper.
LED封装为硅胶,故LED胶体表面较软,用力按压胶体表面会影响LED可靠性,因此应有预防措施避免在封装的零件上的
强大压力,当使用吸嘴时,胶体表面的压力应是恰当的。
SPEC NO:B-17-A-1547
REV NO: A/2
DATE: May/07/2018
PAGE: 9 OF 13
Under Development
Mass production
Handling Precautions 处理防备措施
Compare to epoxy encapsulant that is hard and brittle, silicone is softer and flexible. Although its
characteristic significantly reduces thermal stress, it is more prone to damage by external mechanical force . As a result, Special handling precautions must be observed during assembling using silicone encapsulated LED products, Failure to comply might leads to damage and premature failure of
the LED.
相对环氧树脂较脆较硬而言,硅胶封装较柔软且有弹性,虽然它的特性大大减少了热应力,但易受机械外力损坏,因此
在手工处理方面须要对硅胶封装材料做预防措施,若未按要求操作,可能会导致LED损坏和光衰
1.Handle the component along the side surface by using forceps or appropriate tools; do not directly
touch or Handle the silicone lens surface, it may damage the internal circuitry.
通过使用适当的工具从材料侧面夹取,不可直接用手或尖锐金属压胶体表面,它可能会损坏内部电路
3528
2.The outer diameter of the SMD pickup nozzle should not exceed the size
of the LED to prevent air leaks. The inner diameter of the nozzle should be
as large as possible. A pliable material is suggested for the nozzle tip to avoid
scratching or damaging the LED surface during pickup. The dimensions of the
component must be accurately programmed in the pick-and-place machine to
insure precise pickup and avoid damage during production.
为防止气压泄漏,SMD吸咀外径不可以超过LED尺寸,吸咀内径尺寸应尽可能大,吸咀顶端材
质建议采用柔软材料以防在吸取期间刮伤或损坏LED胶体表面,元件的尺寸必须在取放机里准
确的编程好,以确保精确的吸取和避免生产过程中的损害
3.Do not stack together assembled PCBs containing
LEDs. Impact may scratch the silicone lens or damage
4.Not suitable to operate in acidic environment, PH
HL-A-4014H489W-S1-HR3-DM-HL(4750K-5300K) 价格&库存
很抱歉,暂时无法提供与“HL-A-4014H489W-S1-HR3-DM-HL(4750K-5300K)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.04454
- 10+0.04289
- 100+0.03894
- 500+0.03696
