SMAJ Series
Transient Voltage Suppressors
SMAJxxA(CA)
ROHS
DESCRIPTION:
TVS diodes can be used in a wide range of applications
which like consumer electronic products, automotive
industries, munitions, telecommunications, aerospace
industries, and intelligent control systems.
SMA
FEATURES:
Glass passivated or planar junction
Excellent clamping capability
Repetition rate (duty cycle): 0.01%
Typical IR less than 1μA above 10V.
Low profile package and low inductance
400W Peak Pulse power capability at 10×1000μs waveform.
Fast response time: typically less than 1.0ps from 0V to VBR min.
High temperature soldering: 260℃/10s at terminals.
Symbol
Plastic package has Underwriters Laboratory Flammability 94V-0.
For surface mounted applications in order to optimize board space
ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwise noted)
Parameter
Storage temperature range
Operating junction temperature range
Steady state power dissipation at TL=75℃
Peak pulse power dissipation on 10/1000μs
waveform
Maximum Instantaneous Forward Voltage at
30A for Unidirectional
1/5
Symbol
Value
Tstg
-55 to +150
Unit
Tj
-55 to +150
PM(AV)
3.3
W
PPP
400
W
VF
5.0
V
SMAJ Series
SMAJxxA(CA)
ROHS
ELECTRICAL CHARACTERISTICS (TA=25℃)
Part Number
VR
IR@
VR
VBR@IT
IT
VC@IPP
IPP①
max(V)
A
Uni-Polar
Bi-Polar
V
μA
min(V)
max(V)
mA
SMAJ5.0A
SMAJ5.0CA
5.0
100
6.40
7.00
10
9.2
43.5
SMAJ6.0A
SMAJ6.0CA
6.0
100
6.67
7.37
10
10.3
38.8
SMAJ6.5A
SMAJ6.5CA
6.5
50
7.22
7.98
10
11.2
35.7
SMAJ7.0A
SMAJ7.0CA
7.0
50
7.78
8.60
10
12.0
33.3
SMAJ7.5A
SMAJ7.5CA
7.5
50
8.33
9.21
1
12.9
31.0
SMAJ8.0A
SMAJ8.0CA
8.0
9.83
1
13.6
29.4
SMAJ8.5A
SMAJ8.5CA
8.5
10
9.44
10.40
1
14.4
27.8
SMAJ9.0A
SMAJ9.0CA
9.0
5
10.00
11.10
1
15.4
26.0
SMAJ10A
SMAJ10CA
10.0
2
11.10
12.30
1
17.0
23.5
SMAJ11A
SMAJ11CA
11.0
1
12.20
13.50
1
18.2
22.0
SMAJ12A
SMAJ12CA
12.0
1
13.30
14.70
1
19.9
20.1
SMAJ13A
SMAJ13CA
13.0
1
14.40
15.90
1
21.5
18.6
SMAJ14A
SMAJ14CA
14.0
1
15.60
17.20
1
23.2
17.3
SMAJ15A
SMAJ15CA
15.0
1
16.70
18.50
1
24.4
16.4
SMAJ16A
SMAJ16CA
16.0
1
17.80
19.70
1
26.0
15.4
SMAJ17A
SMAJ17CA
17.0
1
18.90
20.90
1
27.6
14.5
SMAJ18A
SMAJ18CA
18.0
1
20.00
22.10
1
29.2
13.7
SMAJ20A
SMAJ20CA
20.0
1
22.20
24.50
1
32.4
12.4
SMAJ22A
SMAJ22CA
22.0
1
24.40
26.90
1
35.5
11.3
SMAJ24A
SMAJ24CA
24.0
1
26.70
29.50
1
38.9
10.3
SMAJ26A
SMAJ26CA
26.0
1
28.90
31.90
1
42.1
9.5
SMAJ28A
SMAJ28CA
28.0
1
31.10
34.40
1
45.4
8.8
SMAJ30A
SMAJ30CA
30.0
1
33.30
36.80
1
48.4
8.3
SMAJ33A
SMAJ33CA
33.0
1
36.70
40.60
1
53.3
7.5
SMAJ36A
SMAJ36CA
36.0
1
40.00
44.20
1
58.1
6.9
SMAJ40A
SMAJ40CA
40.0
1
44.40
49.10
1
64.5
6.2
SMAJ43A
SMAJ43CA
43.0
1
47.80
52.80
1
69.4
5.8
SMAJ45A
SMAJ45CA
45.0
1
50.00
55.30
1
72.7
5.5
SMAJ48A
SMAJ48CA
48.0
1
53.30
58.90
1
77.4
5.2
SMAJ51A
SMAJ51CA
51.0
1
56.70
62.70
1
82.4
4.9
2/5
SMAJ Series
SMAJxxA(CA)
ROHS
ELECTRICAL CHARACTERISTICS (TA=25℃, continued)
Part Number
VR
IR@
VR
VBR@IT
IT
VC@IPP
IPP①
Uni-Polar
Bi-Polar
V
μA
min(V)
max(V)
mA
max(V)
A
SMAJ54A
SMAJ54CA
54.0
1
60.00
66.30
1
87.1
4.6
SMAJ58A
SMAJ58CA
58.0
1
64.40
71.20
1
93.6
4.3
SMAJ60A
SMAJ60CA
60.0
1
66.70
73.70
1
96.8
4.1
SMAJ64A
SMAJ64CA
64.0
1
71.10
78.60
1
103.0
3.9
SMAJ70A
SMAJ70CA
70.0
1
77.80
86.00
1
113.0
3.6
SMAJ75A
SMAJ75CA
75.0
1
83.30
92.10
1
121.0
3.3
SMAJ78A
SMAJ78CA
78.0
1
86.70
95.80
1
126.0
3.2
SMAJ85A
SMAJ85CA
85.0
1
94.40
104.0
1
137.0
2.9
SMAJ90A
SMAJ90CA
90.0
1
100.0
111.0
1
146.0
2.8
SMAJ100A
SMAJ100CA
100.0
1
111.0
123.0
1
162.0
2.5
SMAJ110A
SMAJ110CA
110.0
1
122.0
135.0
1
177.0
2.3
SMAJ120A
SMAJ120CA
120.0
1
133.0
147.0
1
193.0
2.1
SMAJ130A
SMAJ130CA
130.0
1
144.0
159.0
1
209.0
1.9
SMAJ150A
SMAJ150CA
150.0
1
167.0
185.0
1
243.0
1.7
SMAJ160A
SMAJ160CA
160.0
1
178.0
197.0
1
259.0
1.6
SMAJ170A
SMAJ170CA
170.0
1
189.0
209.0
1
275.0
1.5
SMAJ180A
SMAJ180CA
180.0
1
201.0
222.0
1
292.0
1.4
SMAJ200A
SMAJ200CA
200.0
1
211.0
234.0
1
324.0
1.3
SMAJ220A
SMAJ220CA
220.0
1
246.0
272.0
1
356.0
1.1
SMAJ250A
SMAJ250CA
250.0
1
279.0
309.0
1
405.0
1.0
SMAJ300A
SMAJ300CA
300.0
1
335.0
371.0
1
486.0
0.8
SMAJ350A
SMAJ350CA
350.0
1
391.0
432.0
1
567.0
0.7
SMAJ400A
SMAJ400CA
400.0
1
447.0
494.0
1
648.0
0.6
SMAJ440A
SMAJ440CA
440.0
1
492.0
543.0
1
713.0
0.6
①Surge waveform: 10/1000μs
VR :Stand-off Voltage -- Maximum voltage that can be applied VBR:
Breakdown Voltage
VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR:
Reverse Leakage Current
3/5
SMAJ Series
SMAJxxA(CA)
ROHS
ORDERING INFORMATION
RATINGS AND V-I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted)
FIG.1:V- I curve characteristics
(Uni-directional)
FIG.2:V- I curve characteristics
(Bi-directional)
IPP
VC VBR VR
IT
IR
VC VBR VR
V
VF
VR VBR VC
IPP
IPP
FIG.4: Pulse derating curve
FIG.3: Pulse waveform
PPP derating in percentage(%)
100
IPPM(%IRSM)
150
tr = rise time to peak value
td = decay time to half value
tr=10μs
100
V
IR
IT
80
Peak value
60
Half value
40
50
td
t(ms)
1.0
2.0
3.0
4.0
TA(℃)
25
50
75
100
125
150
175
SMAJ Series
SMAJxxA(CA)
ROHS
SOLDERING PARAMETERS
-Temperature Min (Ts(min))
Pb-Free assembly
(see FIG.5)
+150℃
-Temperature Max(Ts(max))
+200℃
-Time (Min to Max) (ts)
60-180 secs.
Pre
Heat
tp
TP
Critical Zone
TL to TP
Ramp-up
Average ramp up rate (Liquid us Temp
(TL) to peak)
3℃/sec. Max
Ts(max) to TL - Ramp-up Rate
3℃/sec. Max
Reflow
FIG.5: Reflow condition
-Temperature(TL)(Liquid us)
+217℃
-Temperature(tL)
60-150 secs.
TL
tL
TS(max)
Temperature
Reflow Condition
Ramp-down
Preheat
TS(min)
ts
25
Peak Temp (Tp)
+260(+0/-5)℃
Time within 5℃of actual Peak Temp (tp)
30 secs. Max
Ramp-down Rate
6℃/sec. Max
Time 25℃to Peak Temp (TP)
8 min. Max
Do not exceed
+260℃
time to peak temperatue
(t 25℃ to peak)
Time
PACKAGE MECHANICAL DATA
A
Dimensions
C
Ref.
G
D
E
L
J
K
Millimeters
Min.
Max.
Min.
Max.
A
4.25
4.65
0.167
0.183
B
2.50
2.90
0.098
0.114
C
1.35
1.65
0.053
0.065
D
0.76
1.52
0.030
0.060
E
4.93
5.28
0.194
0.208
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
1.98
2.41
0.078
0.095
J
6.80
5/5
L
0.268
2.60
K
DO-214AC (SMA)
Inches
2.40
0.102
0.094
很抱歉,暂时无法提供与“SMAJ28CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.22005
- 10+0.21190
- 100+0.19234
- 500+0.18256
