DZL4734
DZL4734
    LGE(鲁光)
    SOD123FL
    Zener diode 5.6v 1W 10 μ A@ 2V
DZL4734 数据手册
DZL4728 thru DZL4764 Glass Passivated Zener SOD-123FL Features  For surface mounted applications in order to optimize board space Low profile space  Glass passivated chip  High reliability  For use in stabilizing and clipping 0.114(2.9) 0.098(2.5) circuits with high power rating.  0.043(1.09) 0.035(0.89) 0.075(1.90) 0.067(1.70)  0.008(0.20) 0.004(0.10) 0.047(1.19) 0.043(1.09) Component in accordance to RoHS 2002/95/EC and WEEE 2002/96/EC 0.030(0.76) 0.018(0.45) Mechanical Date  Case: JEDEC SOD-123FL molded plastic over passivated chip  Terminals: Solder plated, solderable per MIL-STD-750 Method 2026  Polarity: types the band by laser 0.154(3.9) 0.138(3.5) Dimensions in inches and(millimeters) denotes the cathode  Weight: 0.017gram Applications  Voltage stabilization Maximum Ratings & Thermal Characteristics (TA = 25 °C unless otherwise noted) power dissipation Symbol VALUE UNIT P 1.0 W Typical thermal resistance, junction to ambient RθJA °C / W Typical thermal resistance, junction to lead RθJL °C / W Junction temperature TJ 150 °C storage temperature range TSTG –55 to +150 °C ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com DZL4728 thru DZL4764 Glass Passivated Zener Electrical Characteristics TA =25℃ unless otherwise noted. Zener Voltage DEVICE House No. Leakage Current Zener Impedance VZ(Volts) @IZT ZZT@IZT ZZK@IZK IR@VR Min Nom Max mA Ω Ω mA uA Volts DZL4728 3.13 3.3 3.47 76 10 400 1.0 100 1.0 DZL4729 3.42 3.6 3.78 69 10 400 1.0 100 1.0 DZL4730 3.70 3.9 4.10 64 9 400 1.0 50 1.0 DZL4731 4.08 4.3 4.52 58 9 400 1.0 50 1.0 DZL4732 4.46 4.7 4.94 53 8 500 1.0 10 1.0 DZL4733 4.84 5.1 5.36 49 7 550 1.0 10 1.0 DZL4734 5.32 5.6 5.88 45 5 600 1.0 10 2.0 DZL4735 5.89 6.2 6.51 41 2 700 1.0 10 3.0 DZL4736 6.46 6.8 7.14 37 3.5 700 1.0 10 4.0 DZL4737 7.12 7.5 7.88 34 4 700 0.5 10 5.0 DZL4738 7.79 8.2 8.61 31 4.5 700 0.5 10 6.0 DZL4739 8.64 9.1 9.56 28 5 700 0.5 10 7.0 DZL4740 9.50 10 10.50 25 7 700 0.25 10 7.6 DZL4741 10.45 11 11.55 23 8 700 0.25 5 8.4 DZL4742 11.40 12 12.60 21 9 700 0.25 5 9.1 DZL4743 12.35 13 13.65 19 10 700 0.25 5 9.9 DZL4744 14.25 15 15.75 17 14 700 0.25 5 11.4 DZL4745 15.20 16 16.80 15.5 16 700 0.25 5 12.2 DZL4746 17.10 18 18.90 14 20 750 0.25 5 13.7 DZL4747 19.00 20 21.00 12.5 22 750 0.25 5 15.2 DZL4748 20.90 22 23.10 11.5 23 750 0.25 5 16.7 DZL4749 22.80 24 25.20 10.5 25 750 0.25 5 18.2 DZL4750 25.65 27 28.35 9.5 35 750 0.25 5 20.6 DZL4751 28.50 30 31.50 8.5 40 1000 0.25 5 22.8 DZL4752 31.35 33 34.65 7.5 45 1000 0.25 5 25.1 DZL4753 34.20 36 37.80 7 50 1000 0.25 5 27.4 DZL4754 37.05 39 40.95 6.5 60 1500 0.25 5 29.7 DZL4755 40.85 43 45.15 6 70 1500 0.25 5 32.7 DZL4756 44.65 47 49.35 5.5 80 1500 0.25 5 35.8 DZL4757 48.45 51 53.55 5 95 1500 0.25 5 38.8 DZL4758 53.20 56 58.80 4.5 110 2000 0.25 5 42.6 DZL4759 58.90 62 65.10 4 125 2000 0.25 5 47.1 DZL4760 64.60 68 71.40 3.7 150 2000 0.25 5 51.7 DZL4761 71.25 75 78.75 3.3 175 2000 0.25 5 56.0 DZL4762 77.90 82 86.10 3 200 3000 0.25 5 62.2 DZL4763 86.45 91 95.55 2.8 250 3000 0.25 5 69.2 DZL4764 95.00 100 105.00 2.5 350 3000 0.25 5 76.0 PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SOD-123FL 3000/REEL 90000 40X20X22 5.00 4.00 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
DZL4734 价格&库存
很抱歉,暂时无法提供与“DZL4734”相匹配的价格&库存,您可以联系我们找货
DZL4734
    • 1+0.22499
    • 100+0.20999
    • 300+0.19499
    • 500+0.18000
    • 2000+0.17250
    • 5000+0.16800
    DZL4734
      • 1+0.35500
      库存:5
