PESD1642U005
PESD1642U005
    LEIDITECH(雷卯电子)
    0402的ESD保护二极管
PESD1642U005 数据手册
 PESD1642U005 Ultal Low Capacitance ESD Protection Diode in 0402 Features 䕔 (6'SURWHFWLRQIRUKLJKVSHHGGDWDOLQHVWR  ,(& 䕔 (6'FRQWDFWGLVFKDUJHW\SLFDO.9PD[.9 䕔 (6'DLUGLVFKDUJHW\SLFDO.9PD[.9 1 2 䕔 6XUIDFHPRXQW 䕔 ([WUHPHO\ORZFDSDFLWDQFH 䕔 9HU\ORZOHDNDJHFXUUHQW 䕔 )DVWUHVSRQVHWLPH 䕔 %LGLUHFWLRQDO(6'SURWHFWLRQ 䕔 /HDGIUHHVROGHUWHUPLQDWLRQ 䕔 7KHEHVW(6'SURWHFWLRQIRUKLJKIUHTXHQF\ORZYROWDJHDSSOLFDWLRQV Mechanical Data Applications  (plastic package). Lead free; RoHS compliant 䕔 Case: 䕔 USB3.0, Firewire, DVI, HDMI, S-ATA 䕔 Thunderbolt, Display Port 䕔 Molding Compound Flammability Rating: UL 94 V-0 䕔 Mobile HDMI Link, MDDI, MIPI, SWP / NFC 䕔 Terminals: High temperature soldering guaranteed: 260 °C/10 sec. at terminals Absolute Maximum Ratings Ratings at 25 °C, ambient temperature unless otherwise specified 3DUDPHWHU 6\PERO 9DOXH 8QLW 0D[LPXP&RQWDFWGLVFKDUJHYROWDJH3HU,(&  .9 9 0D[LPXP$LUGLVFKDUJHYROWDJH3HU,(&  .9 9 0D[LPXP2SHUDWLQJWHPSHUDWXUH 723(5 WR Я 0D[LPXP6WRUDJHWHPSHUDWXUH 767* WR Я 0D[LPXPOHDGWHPSHUDWXUHIRUVROGHULQJGXULQJV 7/  Я Electrical Characteristics (TA = 25 °C unless otherwise specified) 3DUDPHWHU 6\PERO 7HVW&RQGLWLRQV 5DWHG9ROWDJH 95    16 9 7ULJJHUYROWDJH 97 ,(&.9FRQWDFWGLVFKDUJH    9 &ODPSLQJYROWDJH 9& ,(&.9FRQWDFWGLVFKDUJH    9 /HDNDJHFXUUHQW ,/  '&9VKDOOEHDSSOLHGRQFRPSRQHQW   X$ &DSDFLWDQFH &3 95 9I 0+]  Note: 0LQ 7\S 0D[  8QLWV S) 1 Trigger and clamping voltage are measured per IEC 61000-4-2, 8KV contact discharge method. 2 After reliability tests such as high temp storage, temp cycles, continuous ESD strike etc, the maximum leakage current is less than 10uA. Rev : 01.06.2015 1/3 www.leiditech.com PESD1642U005 (6'&ODPSLQJ7HVW (6'7(67(5 5= ȍ *+]',*,7$/ 5*8 ȍFRD[ î 26&,//26&23( $77(18$725 &= ȍ '87 '(9,&(81'(57(67  ,(&QHWZRUN &= S)5= ȍ 450 400 350 300 250 200 150 100 50 0 -50 Typical Device Capacitance VS. Frequency 0.06 0.05 Capacitance(pF) Voltage ( V ) Typical ESD Response (IEC 61000-4-2, 8KV contact discharge) 0 10 20 30 40 50 60 70 0.04 0.03 0.02 0.01 0 1.0E+07 80 90 Time(ns) 1.0E+08 1.0E+09 1.0E+10 Frequency(Hz) Eye Diagram Measurement USB3.0 Mask at 5.0 Gbps HDMI Mask at 3.4 Gbps Rev : 01.06.2015 2/3 www.leiditech.com PESD1642U005 ESD Protection for Signal Line The CESD is designed for the protection of one bidirectional data line from ESD damage.  Place the CESD as close to the input terminal or connector as possible.  Minimize the path length between the CESD and the protected signal line.  Use ground planes whenever possible. USB Port Signal line to be protected Vbus DD+ GND USB 3.0 Host/ Controller RXRX+ GND TXTX+ GND GND 3URGXFW'LPHQVLRQ 'LP PLOOPHWHUV PLQ PD[ $   %   &   '   ( ) * + 5()   %6&   Ordering inormation Order code PESD1642U005 Package  Packaging option Base quantity Packaging specification Tape and reel 1000pcs / reel EIA STD RS-481 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2015 3/3 www.leiditech.com
PESD1642U005 价格&库存
很抱歉,暂时无法提供与“PESD1642U005”相匹配的价格&库存,您可以联系我们找货
PESD1642U005
