MMBT5401
PNP General Purpose Transistor
FEATURES
Epitaxial planar die construction.
Complementary NPN type available
(MMBT5551).
or
Also available in lead free version.
2L
APPLICATIONS
Ideal for medium power amplification and switching
ct
ic
on
du
SOT-23
Parameter
S
Symbol
em
MAXIMUM RATING @ Ta=25℃ unless otherwise specified
Value
UNIT
collector-base voltage
-160
V
VCEO
collector-emitter voltage
-150
V
VEBO
emitter-base voltage
-5
V
IC
collector current (DC)
-0.6
A
PD
Total device dissipation
0.35
W
Thermal resistance,junction to ambient
357
°C/W
-55 to +150
°C
JS
MI
CR
O
VCBO
RθJC
Tj ,Tstg
junction and storage temperature
www.jsmsemi.com
第1/4页
MMBT5401
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Parameter
Test conditions
MIN.
V(BR)CBO
Collector-base breakdown voltage
IC=-100μA,IE=0
-160
V(BR)CEO
Collector-emitter breakdown voltage
IC=-1mA,IB=0
-150
V(BR)EBO
Emitter-base breakdown voltage
IE=-10μA,IC=0
ICBO
collector cut-off current
IE = 0; VCB = -120V
IEBO
emitter cut-off current
IC = 0; VEB = -3V
MAX.
or
Symbol
UNIT
-5
-50
nA
-50
nA
DC current gain
VCE = -5V; IC= -1mA
VCE = -5V;IC = -10mA
VCE = -5V;IC = -50 mA
50
100
50
300
VCE(sat)
collector-emitter saturation voltage
IC = -10 mA; IB = -1 mA
IC = -50 mA; IB = -5 mA
-0.2
-0.5
V
VBE(sat)
base-emitter saturation voltage
-1
-1
V
IC = -10mA; VCE = -10V;
f = 100MHz
100
300
MHz
6.0
pF
Cobo
Output capacitance
CR
O
ic
on
du
transition frequency
S
fT
em
hFE
ct
IE=0; VCB= -10V,
f = 1.0MHz
JS
MI
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
www.jsmsemi.com
第2/4页
JS
MI
CR
O
S
em
ic
on
du
ct
or
MMBT5401
www.jsmsemi.com
第3/4页
MMBT5401
PACKAGE OUTLINE
Plastic surface mounted package
SOT-23
A
SOT-23
Min
Max
A
2.70
3.10
B
1.10
1.50
C
0.90
1.10
D
J
E
0.50
0.35
0.48
H
2.00
H
0.02
0.10
J
0.05
0.15
K
2.20
2.60
All Dimensions in mm
CR
O
S
0.95
1.80
em
ic
C
SOLDERING FOOTPRINT
G
on
G
0.95
0.30
du
D
or
B
K
Dim
ct
E
JS
MI
2.00
0.90
Unit : mm
0.80
PACKAGE INFORMATION
Device
Package
Shipping
MMBT5401
SOT-23
3000/Tape&Reel
www.jsmsemi.com
第4/4页
很抱歉,暂时无法提供与“MMBT5401”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.05400
- 100+0.05040
- 300+0.04680
- 500+0.04320
- 2000+0.04140
- 5000+0.04032
