VBMB1104N
www.VBsemi.com
N-Channel 100-V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
V(BR)DSS (V)
rDS(on) (Ω)
ID (A)
100
0.034 at VGS = 10 V
50a
TrenchFET® Power MOSFET
175 °C Junction Temperature
Low Thermal Resistance Package
100 % Rg Tested
RoHS
COMPLIANT
APPLICATIONS
• Isolated DC/DC Converters
D
TO-220 FULLPAK
G
S
G D S
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS TC = 25 °C, unless otherwise noted
Symbol
Limit
Drain-Source Voltage
VDS
100
Gate-Source Voltage
VGS
± 20
Parameter
Continuous Drain Current (TJ = 175 °C)
TC = 25 °C
TC = 125 °C
Pulsed Drain Current
Avalanche Current
Single Pulse Avalanche Energy
b
Maximum Power Dissipationb
L = 0.1 mH
TC = 25 °C
TA = 25 °C
d
Operating Junction and Storage Temperature Range
ID
Unit
V
50a
28a
IDM
120
IAS
31
EAS
61
A
mJ
c
PD
360
3.70
W
TJ, Tstg
- 55 to 175
°C
Symbol
Limit
Unit
THERMAL RESISTANCE RATINGS
Parameter
Junction-to-Ambient
Junction-to-Case (Drain)
PCB Mount
(TO-263)d
RthJA
40
RthJC
0.4
°C/W
Notes:
a. Package limited.
b. Duty cycle ≤ 1 %.
c. See SOA curve for voltage derating.
d. When Mounted on 1" square PCB (FR-4 material).
1
VBMB1104N
www.VBsemi.com
SPECIFICATIONS TJ = 25 °C, unless otherwise noted
Parameter
Symbol
Test Conditions
Min.
V(BR)DSS
VDS = 0 V, ID = 250 µA
100
VGS(th)
VDS = VGS, ID = 250 µA
1.5
IGSS
VDS = 0 V, VGS = ± 20 V
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
Gate-Threshold Voltage
Gate-Body Leakage
Zero Gate Voltage Drain Current
On-State Drain Currenta
Drain-Source On-State Resistancea
IDSS
± 100
VDS = 100 V, VGS = 0 V
1
VDS = 100 V, VGS = 0 V, TJ = 125 °C
50
VDS = 100 V, VGS = 0 V, TJ = 175 °C
250
VDS ≥ 5 V, VGS = 10 V
ID(on)
rDS(on)
120
0.034
VGS = 10 V, ID = 30 A, TJ = 125 °C
0.063
gfs
VDS = 15 V, ID = 30 A
nA
µA
A
VGS = 10 V, ID = 30 A, TJ = 175 °C
Forward Transconductancea
V
2.5
Ω
0.084
S
25
b
Dynamic
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Chargec
Qg
Gate-Source Chargec
Qgs
c
Gate-Drain Charge
Qgd
Gate Resistance
Rg
Turn-On Delay Timec
Rise Timec
Turn-Off Delay Time
5100
VGS = 0 V, VDS = 25 V, f = 1 MHz
90
VDS = 100 V, VGS = 10 V, ID = 65 A
Fall Timec
td(off)
VDD = 100 V, RL = 1.5 Ω
ID ≅ 65 A, VGEN = 10 V, Rg = 2.5 Ω
tf
35
220
330
45
70
200
300
50
120
Forward Voltagea
VSD
IF = 65 A, VGS = 0 V
trr
IRM(REC)
Qrr
Notes:
a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %.
b. Guaranteed by design, not subject to production testing.
c. Independent of operating temperature.
Ω
ns
°Cb
ISM
Reverse Recovery Charge
2
3.3
24
Pulsed Current
Reverse Recovery Time
nC
1.7
IS
Peak Reverse Recovery Current
130
34
Source-Drain Diode Ratings and Characteristics TC = 25
Continuous Current
pF
23
0.5
td(on)
tr
c
480
210
IF = 50 A, di/dt = 100 A/µs
A
1.0
1.5
V
130
200
ns
8
12
A
1.2
µC
0.52
VBMB1104N
www.VBsemi.com
TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted
140
140
VGS = 10 thru 5 V
4V
120
I D - Drain Current (A)
120
100
80
60
40
100
80
60
TC = 125 °C
40
3V
25 °C
2V
- 55 °C
4
6
10
8
VDS - Drain-to-Source Voltage (V)
2
3
4
5
6
7
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
180
0.060
TC = - 55 °C
r DS(on) - On-Resistance (Ω)
g fs - Transconductance (S)
150
25 °C
120
125 °C
90
60
VGS = 10 V
0.045
0.030
0.015
30
0.000
60
80
100
40
100
120
ID - Drain Current (A)
Transconductance
On-Resistance vs. Drain Current
7000
6000
Ciss
C - Capacitance (pF)
60
5000
4000
3000
2000
Crss
1000
VDS = 100 V
ID = 50A
16
12
8
4
Coss
50
75
100
125
150
50
75
100
Qg - Total Gate Charge (nC)
Capacitance
Gate Charge
125
150
3
VBMB1104N
www.VBsemi.com
3.0
100
VGS = 10 V
ID = 30 A
I S - Source Current (A)
2.0
(Normalized)
rDS(on) - On-Resistance
2.5
1.5
1.0
TJ = 150 °C
TJ = 25 °C
10
0.5
0.0
- 50
- 25
50
75
100
125
150
1
0.3
TJ - Junction Temperature (°C)
0.6
0.9
1.2
VSD - Source-to-Drain Voltage (V)
On-Resistance vs. Junction Temperature
Source-Drain Diode Forward Voltage
1000
240
230
ID = 1.0 mA
100
V(BR)DSS (V)
I Dav (A)
220
IAV (A) at TA = 25 °C
10
210
200
1
190
IAV (A) at TA = 150 °C
0.1
0.00001
0.0001
0.001
0.01
0.1
tin (s)
Avalanche Current vs. Time
4
1
180
- 50
- 25
50
75
100
125
Drain Source Breakdown
150
175
VBMB1104N
www.VBsemi.com
THERMAL RATINGS
1000
75
rDS(on)
Limited*
60
10 µs
100
45
30
100 µs
10
1
15
50
75
100
125
150
0.1
0.1
175
TC = 25 °C
Single Pulse
1
10
1 ms
10 ms
100 ms
DC
100
1000
* VGS > minimum V GS at which rDS(on) is specified
TC - Ambient Temperature (°C)
Maximum Avalanche and Drain Current
vs. Case Temperature
Safe Operating Area
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10-4
10-3
10-2
10-1
1
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Case
5
VBMB1104N
www.VBsemi.com
TO-220 FULLPAK (HIGH VOLTAGE)
A
E
A1
ØP
n
d1
d3
D
u
L1
V
L
b3
A2
b2
c
b
e
INCHES
MILLIMETERS
DIM.
A
A1
A2
b
b2
b3
c
D
d1
d3
E
e
L
L1
n
ØP
u
v
ECN: X09-0126-Rev. B, 26-Oct-09
DWG: 5972
MIN.
4.570
2.570
2.510
0.622
1.229
1.229
0.440
8.650
15.88
12.300
10.360
MAX.
4.830
2.830
2.850
0.890
1.400
1.400
0.629
9.800
16.120
12.920
10.630
MIN.
0.180
0.101
0.099
0.024
0.048
0.048
0.017
0.341
0.622
0.484
0.408
13.730
3.500
6.150
3.450
2.500
0.500
0.520
0.122
0.238
0.120
0.094
0.016
2.54 BSC
13.200
3.100
6.050
3.050
2.400
0.400
MAX.
0.190
0.111
0.112
0.035
0.055
0.055
0.025
0.386
0.635
0.509
0.419
0.100 BSC
0.541
0.138
0.242
0.136
0.098
0.020
Notes
1. To be used only for process drawing.
2. These dimensions apply to all TO-220, FULLPAK leadframe versions 3 leads.
3. All critical dimensions should C meet Cpk > 1.33.
4. All dimensions include burrs and plating thickness.
5. No chipping or package damage.
2
VBMB1104N
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
RoHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
