SMD Aluminum Electrolytic Capacitors
VEJ
VEJ Series
Features
‧4φ ~ 18φ, 105℃, 2,000 hours assured
‧Designed for surface mounting on high density PC board
‧RoHS compliance
Marking color: Black
Specifications
Items
Performance
160 ~ 400V
-40℃ ~ +105℃
±20%
6.3 ~ 100V
-55℃ ~ +105℃
Category Temperature Range
Capacitance Tolerance
450V
-25℃ ~ +105℃
(at 120 Hz, 20℃)
Rated voltage
Time
Case size
6.3 ~ 100V
160 ~ 450V
after 2 minutes
after 5 minutes
4 ~ 10φ
12.5 ~ 18φ
12.5 ~ 18φ
I = 0.01CV or 3µA,
I = 0.03CV or 4µA,
Leakage Current
I = 0.04CV + 100µA
whichever is greater
Where, C = rated capacitance in µF, V = rated DC working voltage in V
Leakage Current (at 20℃)
Rated Voltage 6.3
10
16
25
35
50
63
100
160 ~ 250
400 ~ 450
4 ~ 10φ
0.45 0.35 0.28 0.18 0.16 0.14 0.12 0.12
12.5 ~ 18φ
0.40 0.38 0.34 0.26 0.22 0.18 0.14 0.10
0.20
0.25
When the capacitance exceeds 1,000µF, 0.02 shall be added every 1,000µF increase.
Impedance ratio shall not exceed the values given in the table below.
Rated Voltage
6.3 10
16
25
35
50
63 100 160 200 250 400
φD<12.5
Z(-25℃)
4
4
3
2
2
2
2
3
φD≧12.5
/Z(+20℃)
5
4
3
2
2
2
2
2
3
3
3
6
Impedance
Ratio
Z(-55/-40℃) φD<12.5 12
8
6
4
3
3
3
4
φD≧12.5 10
/Z(+20℃)
8
6
4
3
3
3
3
6
6
6
10
Note: The ratio value with “ * ” is only available for 400V.
Tanδ (at 120 Hz, 20℃)
Low Temperature
Characteristics (at 120 Hz)
450
6
Test Time
2,000 Hrs
Within ±25% of initial value for φD ≦ 6.3 mm;
Within ±20% of initial value for φD ≧ 8 mm
Less than 300% of specified value for φD ≦ 6.3 mm;
Tanδ
Less than 200% of specified value for φD ≧ 8 mm
Leakage Current
Within specified value
* The above specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage applied for 2,000
hours at 105℃.
Test time: 1,000 hours; other items are the same as those for the Endurance.
The rated voltage shall be applied to the capacitors before the measurements for 160 ~ 450V (Refer to JIS C 5101-4 4.1).
Capacitance Change
Endurance
Shelf Life Test
Freq. (Hz)
Cap. (µF)
≦ 1,000
1,000 < C ≦ 8,200
Ripple Current and
Frequency Multipliers
50
120
1k
10k up
0.80
0.85
1.00
1.00
1.25
1.15
1.40
1.25
Diagram of Dimensions
Fig. 1
Lead Spacing and Diameter
Vent≧ 8 φ ×10L
B±0.2
φ D±0.5
A±0.2
W
0.3 max.
L
0.5 max.(*)
P
C± 0.2
Fig. 2
φD±0.5
Vent
B±0.2
W
0.4 max.
L
A±0.2
1.0 max.
P
C±0.2
Unit: mm
φD
L
A
B
C
W
4
5.7 ± 0.3
4.3
4.3
5.1
0.5 ~ 0.8
1.0
1
5
5.7 ± 0.3
5.3
5.3
5.9
0.5 ~ 0.8
1.5
1
6.3
5.7 ± 0.3
6.6
6.6
7.2
0.5 ~ 0.8
2.0
1
6.3
7.7 ± 0.3
6.6
6.6
7.2
0.5 ~ 0.8
2.0
1
8
6.5 ± 0.3
8.3
8.3
9.0
0.5 ~ 0.8
2.3
1
8
10 ± 0.5
8.3
8.3
9.0
0.7 ~ 1.1
3.1
1
10
7.7 ± 0.3 10.3
10.3
11.0
0.7 ~ 1.3
4.7
1
10
10 ± 0.5 10.3
10.3
11.0
0.7 ~ 1.3
4.7
1
12.5 13.5 ± 0.5 13.0
13.0
13.7
1.1 ~ 1.4
4.4
2
12.5 16 ± 0.5 13.0
13.0
13.7
1.1 ~ 1.4
4.4
2
P ± 0.2 Fig. No.
16
16.5 ± 0.5 17.0
17.0
18.0
1.1 ~ 1.4
6.4
2
16
21.5 ± 0.5 17.0
17.0
18.0
1.1 ~ 1.4
6.4
2
18
16.5 ± 0.5 19.0
19.0
20.0
1.1 ~ 1.4
6.4
2
18 21.5 ± 0.5 19.0 19.0
(*): For 4 ~ 6.3φ is 0.4 max.
20.0
1.1 ~ 1.4
6.4
2
All product specifications in the catalog are subject to change without notice. (CAT. 2021E2)
111
VEJ
Marking
φD ≦ 6.3 mm
Negative
polarity
φD = 8 ~ 10 mm
Negative
polarity
Rated cap.
Date code
A2
VEJ
470
6.3V
Date code
A2
10
16J
φD ≧ 12.5 mm
Rated voltage
& Series code
Series name
A2
VEJ
2200
6.3V
Negative
polarity
Rated cap.
Rated voltage
Dimension: φD × L(mm)
Ripple Current: mA/rms at 120 Hz, 105℃
Dimension and Permissible Ripple Current
Rated Volt. (VDC)
6.3V (0J)
φD×L
Cap. (µF) Contents
mA
10V (1A)
φD×L
mA
Date
code
Series
name
Rated
cap.
Rated
voltage
16V (1C)
φD×L
25V (1E)
φD×L
mA
mA
35V (1V)
φD×L
mA
50V (1H)
φD×L
63V (1J)
mA
φD×L
mA
1
010
4×5.7
8
4×5.7
8
2.2
2R2
4×5.7
12
4×5.7
12
3.3
3R3
4×5.7
14
5×5.7
17
4.7
4R7
5×5.7
6.3×5.7
22
32
51
10
100
22
220
33
47
4×5.7
4×5.7
330
22
5×5.7
470
34
5×5.7
4×5.7
22
5×5.7
34
4×5.7
4×5.7
5×5.7
27
6.3×5.7
32
6.3×5.7
8×6.5
5×5.7
30
5×5.7
30
6.3×5.7
44
6.3×5.7
8×6.5
38
67
6.3×7.7
58
8×10
100
46
76
6.3×7.7
65
8×10
140
10×10
150
5×5.7
250
8×10
210
10×10
310
12.5×13.5
380
120
6.3×7.7
120
8×10
10×7.7
270
270
8×10
270
10×10
330
12.5×13.5
470
16×16.5
450
8×10
10×7.7
290
290
590
750
980
8×10
290
10×10
370
12.5×13.5
490
16×16.5
650
18×16.5
16×21.5
380
10×10
380
12.5×13.5
520
12.5×16
550
16×16.5
700
18×21.5
500
12.5×16
550
16×16.5
800
18×16.5
990
16×16.5
900
16×16.5
900
18×16.5
1,050
16×16.5
950
18×16.5
16×21.5
1,150
1,200
18×16.5
16×21.5
1,225
1,275
18×21.5
1,300
290
8×10
290
470
471
8×10
320
8×10
10×7.7
320
320
10×10
1,000
102
10×10
410
10×10
410
12.5×13.5
2,200
222
12.5×13.5
680
12.5×13.5
680
3,300
332
12.5×16
850
16×16.5
950
4,700
472
16×16.5
1,000
16×16.5
1,000
6,800
682
18×16.5
16×21.5
1,290
1,350
18×16.5
16×21.5
1,290
1,350
8,200
822
18×21.5
1,450
18×21.5
1,450
160V (2C)
mA
101
12.5×13.5
240
8×10
100
170
8×10
331
470
8×10
100
330
47
70
6.3×7.7
6.3×7.7
12.5×13.5
6.3×7.7
69
120
120
330
80
6.3×5.7
6.3×7.7
8×6.5
33
6.3×7.7
48
221
22
48
79
6.3×5.7
220
10
46
69
90
69
4R7
6.3×5.7
38
6.3×5.7
4.7
34
6.3×5.7
8×6.5
5×5.7
101
φD×L
17
38
100
Rated Volt. (VDC)
4×5.7
200V (2D)
φD×L
mA
250V (2E)
400V (2G)
450V (2W)
φD×L
mA
φD×L
mA
φD×L
mA
12.5×13.5
65
12.5×13.5
45
12.5×13.5
45
75
100
12.5×13.5
80
12.5×13.5
70
12.5×13.5
50
12.5×16
220
12.5×16
110
12.5×13.5
105
16×16.5
85
16×16.5
85
95
12.5×16
120
16×16.5
180
18×16.5
100
18×16.5
100
12.5×16
205
16×16.5
220
16×16.5
220
18×21.5
130
16×16.5
250
18×16.5
280
18×21.5
290
Part Numbering System
VEJ Series
470µF
±20%
6.3V
Carrier
Tape
8φ×10L
VEJ
471
M
0J
TR
0810
Series Name
Capacitance
Capacitance
Tolerance
Rated
Voltage
Package
Type
Terminal
Type
Case size
Pb-free and PET
coating case
Lead Wire and
Coating Type
Note: For more details, please refer to “Part Numbering System (SMD Type)” on page 15.
112
mA
6.3×5.7
8×6.5
6.3×5.7
8×6.5
Cap. (µF) Contents
17
100V (2A)
φD×L
很抱歉,暂时无法提供与“VEJ101M1CTR-0605”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.29367
- 100+0.26713
- 500+0.24060
- 1000+0.21406
- 2000+0.19637
- 4000+0.19106
