2PC4617xMB series
50 V, 100 mA NPN general-purpose transistors
Rev. 1 — 26 March 2012
Product data sheet
1. Product profile
1.1 General description
NPN general-purpose transistors in a leadless ultra small DFN1006B-3 (SOT883B)
Surface-Mounted Device (SMD) plastic package.
Table 1.
Product overview
Type number
Package
PNP complement
Nexperia
JEITA
JEDEC
2PC4617QMB
SOT883B
2PA1774QMB
2PC4617RMB
SOT883B
2PA1774RMB
1.2 Features and benefits
Leadless ultra small SMD plastic
package
Low package height of 0.37 mm
Power dissipation comparable to SOT23
AEC-Q101 qualified
1.3 Applications
General-purpose switching and amplification
Mobile applications
1.4 Quick reference data
Table 2.
Symbol
Parameter
Conditions
Min
Typ
Max Unit
VCEO
collector-emitter voltage
open base
50
V
IC
collector current
100
mA
hFE
DC current gain
2PC4617QMB
120
270
2PC4617RMB
180
390
VCE = 6 V; IC = 1 mA
2PC4617xMB series
Nexperia
2. Pinning information
Table 3.
Pinning
Pin
Description
1
base
2
emitter
Simplified outline
Graphic symbol
3
1
3
3
collector
1
2
Transparent
top view
2
sym021
3. Ordering information
Table 4.
Type number
Package
Name
2PC4617xMB series DFN1006B-3
Description
Version
leadless ultra small plastic package;
3 solder lands; body 1.0 0.6 0.37 mm
SOT883B
4. Marking
Table 5.
Marking codes
Type number
Marking code[1]
2PC4617QMB
0000 1111
2PC4617RMB
0001 0000
[1]
For DFN1006B-3 (SOT883B) binary marking code description see Figure 1.
4.1 Binary marking code description
PIN 1 INDICATION
READING DIRECTION
READING EXAMPLE:
0111
1011
MARKING CODE
(EXAMPLE)
READING DIRECTION
006aac673
Fig 1.
2PC4617XMB_SER
Product data sheet
All information provided in this document is subject to legal disclaimers.
2 of 10
Nexperia B.V. 2017. All rights reserved
2PC4617xMB series
Nexperia
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
2PC4617XMB_SER
Product data sheet
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
50
V
VCEO
open base
50
V
VEBO
emitter-base voltage
open collector
5
V
IC
collector current
100
mA
ICM
peak collector current
single pulse;
tp 1 ms
200
mA
IBM
peak base current
single pulse;
tp 1 ms
100
mA
Ptot
total power dissipation
Tamb 25 C
[1][2]
250
mW
[3][2]
590
mW
Tj
junction temperature
150
C
Tamb
ambient temperature
55
+150
C
Tstg
storage temperature
65
+150
C
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
[2]
Reflow soldering is the only recommended soldering method.
[3]
Device mounted on an FR4 PCB, single-sided copper, mounting pad for collector 1 cm2.
3 of 10
2PC4617xMB series
Nexperia
6. Thermal characteristics
Table 7.
Symbol
Parameter
Rth(j-a)
Conditions
thermal resistance from
junction to ambient
in free air
Min
Typ
Max
Unit
[1][2]
500
K/W
[3][2]
212
K/W
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[2]
[3]
006aab603
103
duty cycle =
1
Zth(j-a)
(K/W)
0.75
0.5
0.33
102
0.2
0.1
0.05
0.02
10
0.01
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
FR4 PCB, standard footprint
Fig 2.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
2PC4617XMB_SER
Product data sheet
4 of 10
2PC4617xMB series
Nexperia
7. Characteristics
Table 8.
Characteristics
Tamb = 25 C unless otherwise specified.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
collector-base
cut-off current
VCB = 30 V; IE = 0 A
100
nA
VCB = 30 V; IE = 0 A;
Tj = 150 C
5
A
IEBO
emitter-base
cut-off current
VEB = 4 V; IC = 0 A
100
nA
hFE
DC current gain
120
270
180
390
200
mV
100
MHz
1.5
pF
ICBO
2PC4617QMB
2PC4617RMB
VCEsat
collector-emitter
saturation voltage
IC = 50 mA; IB = 5 mA
fT
transition frequency
VCE = 12 V; IC = 2 mA;
f = 100 MHz
Cc
collector capacitance VCB = 12 V; IE = ie = 0 A;
f = 1 MHz
[1]
[1]
Pulse test: tp 300 s; 0.02.
8. Test information
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
9. Package outline
0.65
0.55
0.40
0.34
0.35
0.20
0.12
1
0.04 max
2
0.30
0.22
1.05
0.65
0.95
0.30
0.22
3
0.55
0.47
Dimensions in mm
Fig 3.
2PC4617XMB_SER
Product data sheet
11-11-02
Package outline DFN1006B-3 (SOT883B)
5 of 10
2PC4617xMB series
Nexperia
10. Packing information
Table 9.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
Package
Description
Packing quantity
10000
2PC4617xMB series DFN1006B-3 2 mm pitch, 8 mm tape and reel
(SOT883B)
[1]
-315
For further information and the availability of packing methods, see Section 14.
11. Soldering
Footprint information for reflow soldering
SOT883B
1.3
0.7
R0.05 (8x)
0.9
0.6
0.7
0.25
(2x)
0.3
(2x)
0.3
0.4
(2x)
0.4
solder land
solder land plus solder paste
solder paste deposit
solder resist
occupied area
Dimensions in mm
sot883b_fr
Fig 4.
Reflow soldering footprint DFN1006B-3 (SOT883B)
2PC4617XMB_SER
Product data sheet
6 of 10
2PC4617xMB series
Nexperia
12. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
2PC4617XMB_SER v.1
20120326
Product data sheet
2PC4617XMB_SER
Product data sheet
7 of 10
2PC4617xMB series
Nexperia
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
Definition
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
13.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
2PC4617XMB_SER
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
8 of 10
2PC4617xMB series
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
2PC4617XMB_SER
Product data sheet
9 of 10
Nexperia
2PC4617xMB series
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
4.1
5
6
7
8
8.1
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Binary marking code description. . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Thermal characteristics . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 5
Quality information . . . . . . . . . . . . . . . . . . . . . . 5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 5
Packing information . . . . . . . . . . . . . . . . . . . . . 6
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 7
Legal information. . . . . . . . . . . . . . . . . . . . . . . . 8
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 8
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Contact information. . . . . . . . . . . . . . . . . . . . . . 9
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Date of release: 26 March 2012
