74AHC377; 74AHCT377
Octal D-type flip-flop with data enable; positive-edge trigger
Rev. 02 — 12 June 2008
Product data sheet
1. General description
The 74AHC377; 74AHCT377 is a high-speed Si-gate CMOS device and is pin compatible
with Low-power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard
No. 7-A.
The 74AHC377; 74AHCT377 has eight edge-triggered, D-type flip-flops with individual D
inputs and Q outputs. A common clock input (CP) loads all flip-flops simultaneously when
the data enable input (E) is LOW. The state of each D input, one set-up time before the
LOW-to-HIGH clock transition, is transferred to the corresponding output (Qn) of the
flip-flop. The E input is only required to be stable one set-up time prior to the
LOW-to-HIGH transition for predictable operation.
For versions associated with the 74AHC377; 74AHCT377, refer to the following:
• For the master reset version, see 74AHC273; 74AHCT273
• For the transparent latch version, see 74AHC373; 74AHCT373
• For the 3-state version, see 74AHC374; 74AHCT374
2. Features
n
n
n
n
n
n
n
Balanced propagation delays
All inputs have Schmitt-trigger actions
Inputs accept voltages higher than VCC
Ideal for addressable register applications
Data enable for address and data synchronization
Eight positive-edge triggered D-type flip-flops
Input levels:
u For 74AHC377: CMOS level
u For 74AHCT377: TTL level
n ESD protection:
u HBM EIA/JESD22-A114E exceeds 2000 V
u MM EIA/JESD22-A115-A exceeds 200 V
u CDM EIA/JESD22-C101C exceeds 1000 V
n Multiple package options
n Specified from −40 °C to +85 °C and from −40 °C to +125 °C
74AHC377; 74AHCT377
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
74AHC377D
−40 °C to +125 °C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
74AHC377PW
−40 °C to +125 °C
TSSOP20
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
74AHCT377D
−40 °C to +125 °C
SO20
body width 7.5 mm
SOT163-1
74AHCT377PW
−40 °C to +125 °C
TSSOP20
body width 4.4 mm
SOT360-1
74AHC377
74AHCT377
4. Functional diagram
3
D0
Q0
2
4
D1
Q1
5
7
D2
Q2
6
Q3
9
8
D3
13 D4
FF1
to
FF8
OUTPUTS
Q4 12
14 D5
Q5 15
17 D6
Q6 16
18 D7
Q7 19
1
E
11 CP
mna606
Fig 1.
Functional diagram
74AHC_AHCT377_2
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 16
74AHC377; 74AHCT377
Nexperia
11
1C2
1
G1
11
3
CP
3
4
7
8
13
14
17
18
D0
Q0
D1
Q1
D2
Q2
D3
Q3
D4
Q4
D5
Q5
D6
Q6
D7
Q7
4
5
6
7
6
9
8
9
12
13
12
14
15
17
16
18
19
5
15
16
19
E
1
Fig 2.
mna919
mna918
Logic symbol
Fig 3.
D0
2
2D
2
D1
D2
D3
IEC logic symbol
D4
D5
D6
D7
E
D
Q
D
Q
D
CP
CP
FF1
Q
D
CP
FF2
Q
D
CP
FF3
Q
D
CP
FF4
Q
D
CP
FF5
Q
D
CP
FF6
Q
CP
FF7
FF8
CP
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
mna610
Fig 4.
Logic diagram
74AHC_AHCT377_2
Product data sheet
3 of 16
74AHC377; 74AHCT377
Nexperia
5. Pinning information
5.1 Pinning
E
1
20 VCC
Q0
2
19 Q7
D0
3
18 D7
D1
4
17 D6
Q1
5
Q2
6
D2
7
14 D5
D3
8
13 D4
Q3
9
12 Q4
GND 10
11 CP
16 Q6
377
15 Q5
mna917
Fig 5.
Pin configuration SO20 and TSSOP20
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
E
1
data enable input (active LOW)
Q0
2
flip-flop output
D0
3
data input
D1
4
data input
Q1
5
flip-flop output
Q2
6
flip-flop output
D2
7
data input
D3
8
data input
Q3
9
flip-flop output
GND
10
ground (0 V)
CP
11
clock input (LOW-to-HIGH, edge triggered)
Q4
12
flip-flop output
D4
13
data input
D5
14
data input
Q5
15
flip-flop output
Q6
16
flip-flop output
D6
17
data input
D7
18
data input
Q7
19
flip-flop output
VCC
supply voltage
74AHC_AHCT377_2
Product data sheet
4 of 16
74AHC377; 74AHCT377
Nexperia
6. Functional description
Table 3.
Function table[1]
Operating mode
Control
Input
Output
E
CP
Dn
Qn
Load 1
l
h
H
Load 0
l
l
L
Hold (do nothing)
h
X
no change
H
X
X
no change
[1]
H = HIGH voltage level;
h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition;
L = LOW voltage level;
l = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition;
↑ = LOW-to-HIGH CP transition;
X = don’t care.
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
VI
Conditions
Min
Max
Unit
supply voltage
−0.5
+7.0
V
input voltage
−0.5
+7.0
V
−20
mA
−20
+20
mA
input clamping current
VI < −0.5 V
[1]
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
VO = −0.5 V to (VCC + 0.5 V)
IIK
IO
output current
−25
+25
mA
ICC
supply current
+75
mA
IGND
ground current
−75
mA
Tstg
storage temperature
−65
+150
°C
500
mW
total power dissipation
Ptot
Tamb = −40 °C to +125 °C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO20 packages: above 70 °C the value of Ptot derates linearly at 8 mW/K.
For TSSOP20 packages: above 60 °C the value of Ptot derates linearly at 5.5 mW/K.
74AHC_AHCT377_2
Product data sheet
5 of 16
74AHC377; 74AHCT377
Nexperia
8. Recommended operating conditions
Table 5.
Operating conditions
Symbol Parameter
Conditions
Min
Typ
Max
Unit
2.0
5.0
5.5
V
74AHC377
VCC
supply voltage
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
input transition rise and fall rate
VCC = 3.0 V to 3.6 V
100
ns/V
VCC = 4.5 V to 5.5 V
ns/V
74AHCT377
VCC
supply voltage
4.5
5.0
5.5
V
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
25 °C
Conditions
−40 °C to +85 °C −40 °C to +125 °C Unit
Min
Typ
Max
Min
Max
Min
Max
74AHC377
VIH
VIL
VOH
VOL
HIGH-level
input voltage
VCC = 2.0 V
1.5
1.5
1.5
V
VCC = 3.0 V
2.1
2.1
2.1
V
VCC = 5.5 V
3.85
3.85
3.85
V
LOW-level
input voltage
VCC = 2.0 V
0.5
0.5
0.5
V
VCC = 3.0 V
0.9
0.9
0.9
V
VCC = 5.5 V
1.65
1.65
1.65
V
HIGH-level
VI = VIH or VIL
output voltage
IO = −50 µA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = −50 µA; VCC = 3.0 V
2.9
3.0
2.9
2.9
V
IO = −50 µA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = −4.0 mA; VCC = 3.0 V
2.58
2.48
2.40
V
IO = −8.0 mA; VCC = 4.5 V
3.94
3.80
3.70
V
LOW-level
VI = VIH or VIL
output voltage
IO = 50 µA; VCC = 2.0 V
0.1
0.1
V
IO = 50 µA; VCC = 3.0 V
0.1
0.1
V
IO = 50 µA; VCC = 4.5 V
0.1
0.1
V
IO = 4.0 mA; VCC = 3.0 V
0.36
0.44
0.55
V
IO = 8.0 mA; VCC = 4.5 V
0.36
0.44
0.55
V
74AHC_AHCT377_2
Product data sheet
6 of 16
74AHC377; 74AHCT377
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
25 °C
Conditions
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
Min
Typ
Max
Min
Max
Min
Max
0.1
1.0
2.0
µA
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
4.0
40
80
µA
CI
input
capacitance
3
10
10
10
pF
VI = VCC or GND
74AHCT377
VIH
HIGH-level
input voltage
2.0
2.0
2.0
V
VIL
LOW-level
input voltage
0.8
0.8
0.8
V
VOH
HIGH-level
VI = VIH or VIL; VCC = 4.5 V
output voltage
IO = −50 µA
4.4
4.5
4.4
4.4
V
3.94
3.80
3.70
V
0.1
0.1
V
0.36
0.44
0.55
V
0.1
1.0
2.0
µA
IO = −8.0 mA
VOL
LOW-level
output voltage
IO = 50 µA
IO = 8.0 mA
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
ICC
VCC = 5.5 V
4.0
40
80
µA
∆ICC
additional
per input pin;
supply current VI = VCC − 2.1 V; other pins
at VCC or GND; IO = 0 A;
1.35
1.5
1.5
mA
CI
input
capacitance
3
10
10
10
pF
VI = VCC or GND
74AHC_AHCT377_2
Product data sheet
7 of 16
74AHC377; 74AHCT377
Nexperia
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 8.
Symbol Parameter
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
CL = 15 pF
5.6
12.8
1.0
15.0
1.0
16.0
ns
CL = 50 pF
8.0
16.0
1.0
18.0
1.0
20.0
ns
CL = 15 pF
3.9
9.0
1.0
10.5
1.0
11.5
ns
CL = 50 pF
5.6
10.5
1.0
12.0
1.0
13.5
ns
CL = 15 pF
80
125
70
70
MHz
CL = 50 pF
50
75
45
45
MHz
CL = 15 pF
125
175
110
110
MHz
CL = 50 pF
85
120
75
75
MHz
5.0
5.0
5.0
ns
5.0
5.0
5.0
ns
5.0
5.0
5.0
ns
4.5
4.5
4.5
ns
1.5
1.5
1.5
ns
74AHC377
tpd
[2]
propagation CP to Qn; see Figure 6
delay
fmax
maximum
frequency
see Figure 6
tW
tsu
th
pulse width
set-up time
hold time
CP HIGH or LOW;
see Figure 6
Dn, E to CP; see Figure 7
CPD
power
fi = 1 MHz; VI = GND to VCC
dissipation
capacitance
[3]
2.0
2.0
2.0
ns
pF
74AHC_AHCT377_2
Product data sheet
8 of 16
74AHC377; 74AHCT377
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
25 °C
Conditions
Min
Typ[1]
Max
Min
Max
Min
Max
4.0
9.0
1.0
10.5
1.0
11.5
ns
5.7
10.5
1.0
12.0
1.0
13.5
ns
CL = 15 pF
90
140
80
80
MHz
CL = 50 pF
85
130
75
75
MHz
74AHCT377; VCC = 4.5 V to 5.5 V
tpd
[2]
delay
CL = 15 pF
CL = 50 pF
fmax
maximum
frequency
see Figure 6
tW
pulse width
CP HIGH or LOW;
see Figure 6
5.0
5.0
5.0
ns
tsu
set-up time
4.5
4.5
4.5
ns
th
hold time
2.0
2.0
2.0
ns
23
pF
CPD
power
dissipation
capacitance
[3]
[1]
Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V).
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
Σ(CL × VCC2 × fo) = sum of the outputs.
74AHC_AHCT377_2
Product data sheet
9 of 16
74AHC377; 74AHCT377
Nexperia
11. Waveforms
1/fmax
VI
CP input
VM
GND
tW
t PHL
t PLH
VOH
VM
Qn output
001aac426
VOL
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 6.
Clock pulse width, maximum frequency and input to output propagation delays
VCC
E input
VM
GND
th
th
tsu
tsu
VCC
Dn input
VM
GND
tsu
th
tW
VCC
CP input
VM
GND
mna609
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig 7.
Data set-up and hold times
Table 8.
Measurement points
Type
Input
Output
VM
VM
74AHC377
0.5 × VCC
0.5 × VCC
74AHCT377
1.5 V
0.5 × VCC
74AHC_AHCT377_2
Product data sheet
10 of 16
74AHC377; 74AHCT377
Nexperia
VI
negative
pulse
tW
90 %
VM
VM
10 %
GND
tr
tf
tr
VI
positive
pulse
GND
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
VO
DUT
RT
CL
001aah768
Test data is given in Table 9.
Definitions test circuit:
RT = termination resistance should be equal to output impedance Zo of the pulse generator.
CL = load capacitance including jig and probe capacitance.
Fig 8.
Load circuitry for measuring switching times
Table 9.
Test data
Type
Input
Load
Test
VI
tr, tf
CL
74AHC377
VCC
≤ 3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHCT377
3.0 V
≤ 3.0 ns
15 pF, 50 pF
tPLH, tPHL
74AHC_AHCT377_2
Product data sheet
11 of 16
74AHC377; 74AHCT377
Nexperia
12. Package outline
SO20: plastic small outline package; 20 leads; body width 7.5 mm
SOT163-1
D
E
A
X
c
HE
y
v M A
Z
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
10
1
e
detail X
w M
bp
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
13.0
12.6
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.01
0.019 0.013
0.014 0.009
0.51
0.49
0.30
0.29
0.05
0.419
0.043
0.055
0.394
0.016
inches
0.1
0.012 0.096
0.004 0.089
0.043
0.039
0.01
0.01
Z
(1)
0.9
0.4
0.035
0.004
0.016
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
Fig 9.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT163-1
075E04
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Package outline SOT163-1 (SO20)
74AHC_AHCT377_2
Product data sheet
12 of 16
74AHC377; 74AHCT377
Nexperia
TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm
SOT360-1
E
D
A
X
c
HE
y
v M A
Z
11
Q
A2
(A 3)
A1
pin 1 index
A
θ
Lp
L
1
10
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
6.6
6.4
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT360-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig 10. Package outline SOT360-1 (TSSOP20)
74AHC_AHCT377_2
Product data sheet
13 of 16
74AHC377; 74AHCT377
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MM
Machine Model
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AHC_AHCT377_2
20080612
Product data sheet
74AHC_AHCT377_1
Modifications:
74AHC_AHCT377_1
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Table 6: the conditions for input leakage current have been changed.
20000815
Product specification
74AHC_AHCT377_2
Product data sheet
14 of 16
74AHC377; 74AHCT377
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
15.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AHC_AHCT377_2
Product data sheet
15 of 16
74AHC377; 74AHCT377
Nexperia
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 4
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 5
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5
Recommended operating conditions. . . . . . . . 6
Static characteristics. . . . . . . . . . . . . . . . . . . . . 6
Dynamic characteristics . . . . . . . . . . . . . . . . . . 8
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 14
Legal information. . . . . . . . . . . . . . . . . . . . . . . 15
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 15
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Date of release: 12 June 2008
很抱歉,暂时无法提供与“74AHC377PW,112”相匹配的价格&库存,您可以联系我们找货
