SS32G THRU SS320G
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200 V Forward Current - 3.0A
Features
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
PINNING
PIN
DESCRIPTION
1
Cathode
2
Anode
1
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• Approx. Weight: 60mg / 0.0021oz
2
Top View
Marking Code: SS32 ~SS320
Simplified outline SMA and symbol
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS32 G
SS34G SS34A G
SS36 G
SS38G SS310G SS312G SS315 G
SS320 G
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
45
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
31.5
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
45
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
Max Instantaneous Forward Voltage at 3 A
VF
T a =100°C
Typical Junction Capacitance (1)
Typical Thermal Resistance
(2)
Operating Junction Temperature Range
Storage Temperature Range
0.55
70
0.70
A
0.95
0.85
V
0.5
5
0.3
3
mA
Cj
450
400
pF
RθJA
70
°C/W
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
REV.08
80
IR
Maximum DC Reverse Current T a = 25°C
at Rated DC Reverse Voltage
A
3.0
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
1 of 3
SS32G THRU SS320G
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
3.5
3.0
2.4
1.8
1.2
0.6
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
10 4
SS32G - SS36G
10
T J =25°C
10 0
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
1.0
SS32G /SS34G
SS34AG /SS38G
SS310G /SS312 G
SS315 G /SS320 G
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
500
200
100
G
SS32
SS3G ~SS38
2F~SS3
6F
SS310
SS3 G8F~SS320F
~SS320G
10
1.8
1
0.1
100
10
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.5- Typical Transient Thermal Impedance
100
SS32 G -SS38G
SS310G -SS320G
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
1000
Instaneous Forward Voltage (V)
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
SS38G -SS320G
1
Fig.3 Typical Forward Characteristic
Peak Forward Surage Current (A)
T J =75°C
10 2
Case Temperature (°C)
10
100
Number of Cycles at 60Hz
REV.08
T J =100°C
10 3
100
10
1
0.01
0.1
1
10
t, Pulse Duration(sec)
2 of 3
100
SS32G THRU SS320G
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
SMA
c
VM
A
HE
e
E
g
A
D
E
HE
c
e
g
max
2.2
4.83
2.9
5.4
0.31
1.7
1.5
min
1.9
4.32
2.3
4.7
0.12
1.2
0.9
max
87
190
114
213
12
67
59
min
75
170
91
185
5
47
35
UNIT
mm
mil
e
g
A
D
SS26F
The recommended mounting pad size
Marking
Type number
SS22F
SS24F
2.2
(86)
mm
Unit :
(mil)
REV.08
SS32 G
SS32
1.8
(71)
1.8
(71)
1.8
(71)
Marking code
3 of 3
SS34G
SS34
SS34A G
SS34A
SS36G
SS36
SS38G
SS38
SS310G
SS310
SS312G
SS312
SS315 G
SS315
SS320 G
SS320
很抱歉,暂时无法提供与“SS32G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.37111
- 100+0.30286
- 300+0.26873
- 1000+0.24313
- 5000+0.22266
- 10000+0.21242
