1N5820-1N5822
3.0 AMP. Schottky Barrier Rectifiers
DO-201AD
Features
Low power loss, high efficiency.
High current capability, Low VF.
High reliability
High surge current capability.
Epitaxial construction.
Guard-ring for transient protection.
For use in low voltage, high frequency
inventor, free wheeling, and polarity protection
application.
Mechanical Data
Cases: DO-201AD molded plastic
Epoxy: UL 94V-0 rate flame retardant
Polarity: Color band denotes cathode end
High temperature soldering guaranteed:
260oC/10 seconds/.375”,(9.5mm) lead
lengths at 5 lbs., (2.3kg) tension
Weight: 1.2 grams
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25 oC ambient temperature unless otherwise specified.
Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
Symbol
1N5820
Type Number
VRRM
VRMS
VDC
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
.375 (9.5mm) Lead Length @TL = 90℃
Peak Forward Surge Current, 8.3 ms Single Half
Sine-wave Superimposed on Rated Load (JEDEC
method )
Maximum Instantaneous Forward Voltage @ 3.0A
Maximum Instantaneous Forward Voltage @ 9.0A
o
Maximum DC Reverse Current @ TA=25 C
o
at Rated DC Blocking Voltage @ TA=100 C
Typical Junction Capacitance (Note 2)
Typical Thermal Resistance (Note 1)
Storage Temperature Range
Revision:20170701-P1
1N5822
Units
30
40
V
14
21
28
V
30
40
V
I(AV)
3.0
A
IFSM
80
A
VF
VF
0.475
0.500
0.525
V
0.850
0.900
0.5
10
200
0.950
V
mA
mA
pF
IR
Cj
RθJA
TJ
Operating Temperature Range
Notes:
1N5821
TSTG
40
-65 to +125
-65 to +125
o
C/W
o
C
o
C
1. Mount on Cu-Pad Size 16mm x 16mm on P.C.B.
2. Measured at 1 MHz and Applied Reverse Voltage of 4.0 V D.C.
ht t p : //
www.lgesemi .c o m
mail:lge@lgesemi.com
1N5820-1N5822
RATINGS AND CHARACTERISTIC CURVES (1N5820 THRU 1N5822)
FIG.1- MAXIMUM FORWARD CURRENT
DERATING CURVE
3
2
Resistive of
Inductive Load
0.375"(9.5mm) Lead Length
1
60
80
100
o
LEAD TEMPERATURE. ( C)
120
70
60
40
30
1
2
5
10
NUMBER OF CYCLES AT 60Hz
50
100
FIG.4- TYPICAL REVERSE CHARACTERISTICS
10
FIG.3- TYPICAL FORWARD CHARACTERISTICS
8.3ms Single Half Sine Wave
JEDEC Method
50
140
1.0
Tj=25oC
Pulse Width=300 s
1% Duty Cycle
0.1
.2
1000
.3
.4
.5
.6
FORWARD VOLTAGE. (V)
.7
.8
.9
INSTANTANEOUS REVERSE CURRENT. (mA)
58
21
~1
N
1N
58
22
58
1N
FIG.5- TYPICAL JUNCTION CAPACITANCE
Tj=100 C
1.0
Tj=75 C
.10
Tj=25 C
.01
400
.001
100
80
60
100
0.1
0.4
1.0
4
10
REVERSE VOLTAGE. (V)
40
100
TRANSIENT THERMAL IMPEDANCE. (OC/W)
INSTANTANEOUS FORWARD CURRENT. (A)
JUNCTION CAPACITANCE.(pF)
80
PEAK FORWARD SURGE CURRENT. (A)
AVERAGE FORWARD CURRENT. (A)
4
FIG.2- MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE. (%)
FIG.6- TYPICAL TRANSIENT THERMAL
CHARACTERISTICS
10
1
0.1
0.01
0.1
1
10
T, PULSE DURATION. (sec)
100
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
DO-27
1250/AMMO
12500
40X26.5X30
14.00
12.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“1N5820”相匹配的价格&库存,您可以联系我们找货
