SR220-SR2200
2.0 AMP Schottky Barrier Rectifiers
VOLTAGE RANGE: 20 --- 200 V
CURRENT: 2.0 A
Features
Metal-Semiconductor junction with guard ring
Epitaxial construction
Low forward voltage drop,low switching losses
DO-15
High surge capability
For use in low voltage,high frequency inverters free
wheeling,and polarity protection applications
The plastic material carries U/L recognition 94V-0
Mechanical Data
Case:JEDEC DO--15,molded plastic
Terminals: Axial lead ,solderable per
MIL- STD-750,Method 2026
Polarity: Color band denotes cathode
Weight: 0.014ounces,0.39 grams
Mounting position: Any
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25
ambient temperature unless otherwise specified.
Single phase,half wave,60 Hz,resistive or inductive load. For capacitive load,derate by 20%.
SR220 SR230 SR240
SR250
SR260
SR280 SR2100 SR2150 SR2200 UNITS
Maximum recurrent peak reverse voltage
VRRM
40
50
60
80
100
150
200
V
Maximum RMS voltage
VRMS
14
21
28
35
42
56
70
105
140
V
Maximum DC blocking voltage
VDC
40
50
60
80
100
150
200
V
Maximum average forw ard rectified current
9.5mm lead length,
@TA=75
IF(AV)
2.0
A
IFSM
50.0
A
Peak forw ard surge current
8.3ms single half-sine-w ave
superimposed on rated load
@TJ =125
Maximum instantaneous forw ard voltage
@ 2.0A (Note 1)
Maximum reverse current
VF
@TA=25
0.55
0.85
1.0
IR
at rated DC blocking voltage @TA=100
0.7
10.0
Typical junction capacitance
(Note2)
CJ
170
Typical thermal resistance
(Note3)
RθJA
35
TJ
- 55 ---- + 150
TSTG
- 55 ---- + 150
Operating junction temperature range
Storage temperature range
V
mA
pF
/W
NOTE: 1. Pulse test:300us pulse width,1% duty cy cle.
2. Measured at 1.0MHz and applied rev erse v oltage of 4.0V DC.
3.Thermal resistance junction to ambient
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
SR220-SR2200
Ratings AND Charactieristic Curves
FIG.2 -- PEAK FORWARD SURGE CURRENT
1.5
Resistive or
Inductive Load
0.375"(9.5mm)
Lead Length
1.0
0.5
50
75
100
125
150
175
50
40
AMPERES
2.0
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT
FIG.1 -- FORWARD CURRENT DERATING CURVE
30
LEAD TEMPERATURE,
100
10
NUMBER OF CYCLES AT 60Hz
FIG.3 -- TYPICAL INSTANTANEOUS FORWARD
XXXXXXXXX----CHARACTERISTICS
FIG.4 -- TYPICAL JUNCTION CAPACITANCE
50
SR220 - SR240
400
SR280 - SR2200
1
SR250 - SR260
0.1
Pulse Width=300 µs
1% DUTY CYCLE
0.01
0.8 1.0
100
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
10
0.1
1
10
100
1.2 1.4 1.6
REVERSE VOLTAGE,VOLTS
INSTANTANEOUS FORWARD VOLTAGE, VOLTS
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
DO-15
3000/AMMO
30000
42X28X31
12.00
10.00
ht t p : //
CAPACITANCE,pF
10
AMPERES
INSTANTANEOUS FORWARD CURRENT
TJ=TJMAX
8.3ms Single Half
Sine-Wave
www.lgesemi .c o m
很抱歉,暂时无法提供与“SR240”相匹配的价格&库存,您可以联系我们找货
