PMBTA44
400 V, 0.3 A NPN high-voltage low VCEsat transistor
1 January 2023
Product data sheet
1. General description
NPN high-voltage low VCEsat transistor in a SOT23 (TO-236AB) small Surface-Mounted Device
(SMD) plastic package.
2. Features and benefits
Low current (max. 300 mA)
High voltage (max. 400 V)
3. Applications
LED driver for LED chain module
LCD backlighting
High Intensity Discharge (HID) front lighting
Hook switch for wired telecom
Switch Mode Power Supply (SMPS)
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCEO
collector-emitter
voltage
open base
400
V
IC
collector current
300
mA
hFE
DC current gain
50
200
VCE = 10 V; IC = 10 mA; Tamb = 25 °C
5. Pinning information
Table 2. Pinning information
Pin
Symbol
Description
1
B
base
2
E
emitter
3
C
collector
Simplified outline
Graphic symbol
3
C
B
1
2
SOT23
E
sym021
PMBTA44
Nexperia
6. Ordering information
Table 3. Ordering information
Type number
Package
PMBTA44
Name
Description
Version
SOT23
plastic, surface-mounted package; 3 terminals; 1.9 mm
pitch; 2.9 mm x 1.3 mm x 1 mm body
SOT23
7. Marking
Table 4. Marking codes
Type number
Marking code[1]
PMBTA44
W3%
[1]
% = placeholder for manufacturing site code
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
500
V
VCEO
collector-emitter voltage
open base
400
V
VEBO
emitter-base voltage
open collector
6
V
IC
collector current
300
mA
ICM
peak collector current
300
mA
IBM
peak base current
100
mA
Ptot
total power dissipation
250
mW
Tj
junction temperature
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
[1]
single pulse; tp ≤ 1 ms
Tamb ≤ 25 °C
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
PMBTA44
Product data sheet
All information provided in this document is subject to legal disclaimers.
1 January 2023
Nexperia B.V. 2023. All rights reserved
2 / 10
PMBTA44
Nexperia
006aab196
300
Ptot
(mW)
200
100
- 25
25
75
125
175
Tamb (°C)
FR4 PCB, standard footprint
Fig. 1.
Power derating curve SOT23 (TO-236AB)
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Rth(j-a)
[1]
Conditions
thermal resistance from in free air
junction to ambient
[1]
Min
Typ
Max
Unit
500
K/W
006aab151
103
duty cycle = 1
Zth(j-a)
(K/W)
0.75
102
0.33
0.5
0.2
0.1
0.05
10
1
0.02
0.01
10- 5
10- 4
10- 3
10- 2
10- 1
1
10
102
tp (s)
103
Fig. 2.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
PMBTA44
Product data sheet
1 January 2023
3 / 10
PMBTA44
Nexperia
10. Characteristics
Table 7. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ICBO
collector-base cut-off
current
VCB = 320 V; IE = 0 A; Tamb = 25 °C
100
nA
VCB = 320 V; IE = 0 A; Tj = 150 °C
10
µA
IEBO
emitter-base cut-off
current
VEB = 4 V; IC = 0 A; Tamb = 25 °C
100
nA
hFE
DC current gain
50
200
VCE = 10 V; IC = 50 mA; pulsed; tp ≤
300 µs; δ ≤ 0.02; Tamb = 25 °C
45
VCE = 10 V; IC = 100 mA; pulsed; tp ≤
40
IC = 1 mA; IB = 0.1 mA; Tamb = 25 °C
400
mV
IC = 10 mA; IB = 1 mA; Tamb = 25 °C
500
mV
IC = 50 mA; IB = 5 mA; pulsed; tp ≤
750
mV
VBEsat
base-emitter saturation IC = 10 mA; IB = 1 mA; pulsed; tp ≤
voltage
850
mV
fT
transition frequency
VCE = 10 V; IC = 10 mA; f = 100 MHz;
Tamb = 25 °C
MHz
Cc
collector capacitance
VCB = 20 V; IE = 0 A; ie = 0 A; f = 1 MHz;
Tamb = 25 °C
7
pF
Ce
emitter capacitance
VEB = 0.5 V; IC = 0 A; ic = 0 A;
f = 1 MHz; Tamb = 25 °C
180
pF
VCEsat
collector-emitter
saturation voltage
006aab190
200
006aab191
0.3
hFE
IB (mA) = 26
IC
(A)
150
23.4 20.8
18.2
(1)
0.2
13
10.4
(2)
15.6
7.8
100
5.2
0.1
(3)
2.6
50
1
10
102
IC (mA)
VCE = 10 V
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = -55 °C
Fig. 3.
2
3
4
VCE (V)
5
Tamb = 25 °C
Fig. 4.
Collector current as a function of collectoremitter voltage; typical values
DC current gain as a function of collector
current; typical values
PMBTA44
Product data sheet
1 January 2023
4 / 10
PMBTA44
Nexperia
006aab192
1.2
006aab193
1.2
VBE
(V)
VBEsat
(V)
(1)
0.8
(1)
0.8
(2)
(2)
(3)
(3)
0.4
0.4
1
10
102
IC (mA)
103
VCE = 10 V
(1) Tamb = -55 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
Fig. 5.
1
10
102
IC (mA)
103
IC/IB = 5
(1) Tamb = -55 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
Base-emitter voltage as a function of collector
Fig. 6.
006aab194
1
Base-emitter saturation voltage as a function of
collector current; typical values
006aab195
103
RCEsat
(Ω)
VCEsat
(V)
102
10- 1
10
(1)
(2)
(3)
(1)
(2)
(3)
1
10- 2
10- 1
1
10
102
IC (mA)
10- 1
10- 1
103
IC/IB = 5
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = -55 °C
Fig. 7.
Product data sheet
10
102
IC (mA)
103
IC/IB = 5
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = -55 °C
Collector-emitter saturation voltage as a
function of collector current; typical values
PMBTA44
1
Fig. 8.
Collector-emitter saturation resistance as a
1 January 2023
5 / 10
PMBTA44
Nexperia
11. Package outline
3.0
2.8
1.1
0.9
3
0.45
0.15
2.5 1.4
2.1 1.2
1
2
0.48
0.38
1.9
Dimensions in mm
Fig. 9.
0.15
0.09
18-03-12
Package outline SOT23
12. Soldering
3.3
2.9
1.9
solder lands
3
2
1.7
solder resist
solder paste
0.6
(3×)
0.7
(3×)
occupied area
Dimensions in mm
0.5
(3×)
0.6
(3×)
1
sot023_fr
Fig. 10. Reflow soldering footprint for SOT23
PMBTA44
Product data sheet
1 January 2023
6 / 10
PMBTA44
Nexperia
2.2
1.2
(2×)
1.4
(2×)
solder lands
4.6
solder resist
2.6
occupied area
Dimensions in mm
1.4
preferred transport direction during soldering
2.8
4.5
sot023_fw
Fig. 11. Wave soldering footprint for SOT23
PMBTA44
Product data sheet
1 January 2023
7 / 10
PMBTA44
Nexperia
13. Revision history
Table 8. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PMBTA44 v.2
20230101
Product data sheet
PMBTA44 v.1
Modifications:
PMBTA44 v.1
PMBTA44
Product data sheet
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Product changed to non-automotive qualification. Please refer to nexperia.com for automotive
(-Q) product alternative(s).
20080222
Product data sheet
1 January 2023
8 / 10
PMBTA44
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
PMBTA44
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
1 January 2023
9 / 10
PMBTA44
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................1
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 2
9. Thermal characteristics............................................... 3
10. Characteristics............................................................ 4
11. Package outline.......................................................... 6
12. Soldering..................................................................... 6
13. Revision history..........................................................8
14. Legal information........................................................9
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 1 January 2023
PMBTA44
Product data sheet
1 January 2023
10 / 10
