5KP Series 5000W Transient Voltage Suppressor
DESCRIPTION:
The 5KP series of high current uni/bi-directional transient
suppressors are designed for A.C. line protection and high
power DC bus clamping applications. These devices offer
uni/bi-directional port protection from 5.0 volts to 250 volts.
They provide a clamping voltage lower than the avalanche
voltage. Therefore, any voltage rise due to increased
current conduction is contained to a minimum, providing
the best possible protection level. They can also be
connected in series and/or parallel to create very high
capacity protection solutions.
FEATURES:
Low zener impedance.
Excellent clamping capability.
JEDEC R-6/P-600 Molded Plastic.
Repetition rate (duty cycle): 0.01%.
Color band denoted cathode except bidirectional.
High temperature soldering: 260℃/10s at terminals.
Glass passivated chip junction in R-6/P600 package.
5000W Peak Pulse power capability at 10×1000μs waveform.
Fast response time: typically less than 1.0ps from 0V to VBR min.
AEC-Q101 qualified.
Symbol
ABSOLUTE MAXIMUM RATINGS (TA=25ºC, RH=45%-75%, unless otherwise noted)
Parameter
Symbol
Value
Unit
PPP
5000
W
IPP
See next table
A
PM(AV)
8
W
TSTG, TJ
-55 to +125
IFSM
400
A
Peak pulse power dissipation on 10/1000μs
waveform
Peak pulse current of on 10/1000μs
waveform
Steady state power dissipation at TL=75℃
Operating junction and Storage temperature
range
Peak forward surge current, 8.3ms single
half sine-wave
Rev : 01.06.2014
1/5
www.leiditech.com
ELECTRICAL CHARACTERISTICS (TA=25℃)
Part Number
VR
IR@VR
VBR@IT
IT
VC@IPP
IPP①
Uni-Polar
Bi-Polar
V
μA
min(V)
max(V)
mA
max(V)
A
5KP5.0A
5KP5.0CA
5.0
150
6.40
7.00
10
9.2
544.0
5KP6.0A
5KP6.0CA
6.0
100
6.67
7.37
10
10.3
486.0
5KP6.5A
5KP6.5CA
6.5
50
7.22
7.98
10
11.2
448.0
5KP7.0A
5KP7.0CA
7.0
8.60
10
12.0
417.0
5KP7.5A
5KP7.5CA
7.5
10
8.33
9.21
1
12.9
388.0
5KP8.0A
5KP8.0CA
8.0
10
8.89
9.83
1
13.6
367.0
5KP8.5A
5KP8.5CA
8.5
10
9.44
10.40
1
14.4
347.0
5KP9.0A
5KP9.0CA
9.0
10
10.00
11.10
1
15.4
325.0
5KP10A
5KP10CA
10.0
5
11.10
12.30
1
17.0
294.0
5KP11A
5KP11CA
11.0
5
12.20
13.50
1
18.2
275.0
5KP12A
5KP12CA
12.0
2
13.30
14.70
1
19.9
252.0
5KP13A
5KP13CA
13.0
2
14.40
15.90
1
21.5
233.0
5KP14A
5KP14CA
14.0
1
15.60
17.20
1
23.2
216.0
5KP15A
5KP15CA
15.0
1
16.70
18.50
1
24.4
205.0
5KP16A
5KP16CA
16.0
1
17.80
19.70
1
26.0
193.0
5KP17A
5KP17CA
17.0
1
18.90
20.90
1
27.6
181.0
5KP18A
5KP18CA
18.0
1
20.00
22.10
1
29.2
172.0
5KP20A
5KP20CA
20.0
1
22.20
24.50
1
32.4
155.0
5KP22A
5KP22CA
22.0
1
24.40
26.90
1
35.5
141.0
5KP24A
5KP24CA
24.0
1
26.70
29.50
1
38.9
129.0
5KP26A
5KP26CA
26.0
1
28.90
31.90
1
42.1
119.0
5KP28A
5KP28CA
28.0
1
31.10
34.40
1
45.4
110.0
5KP30A
5KP30CA
30.0
1
33.30
36.80
1
48.4
103.0
5KP33A
5KP33CA
33.0
1
36.70
40.60
1
53.3
93.9
5KP36A
5KP36CA
36.0
1
40.00
44.20
1
58.1
86.1
5KP40A
5KP40CA
40.0
1
44.40
49.10
1
64.5
77.6
5KP43A
5KP43CA
43.0
1
47.80
52.80
1
69.4
72.1
5KP45A
5KP45CA
45.0
1
50.00
55.30
1
72.7
68.8
5KP48A
5KP48CA
48.0
1
53.30
58.90
1
77.4
64.7
5KP51A
5KP51CA
51.0
1
56.70
62.70
1
82.4
60.7
Rev : 01.06.2014
2/5
www.leiditech.com
ELECTRICAL CHARACTERISTICS (TA=25℃, continued)
Part Number
VR
IR@VR
VBR@IT
IT
VC@IPP
IPP①
Uni-Polar
Bi-Polar
V
μA
min(V)
max(V)
mA
max(V)
A
5KP54A
5KP54CA
54.0
1
60.00
66.30
1
87.1
57.5
5KP58A
5KP58CA
58.0
1
64.40
71.20
1
93.6
53.5
5KP60A
5KP60CA
60.0
1
66.70
73.70
1
96.8
51.7
5KP64A
5KP64CA
64.0
1
71.10
78.60
1
103.0
48.6
5KP70A
5KP70CA
70.0
1
77.80
86.00
1
113.0
44.3
5KP75A
5KP75CA
75.0
1
83.30
92.10
1
121.0
41.4
5KP78A
5KP78CA
78.0
1
86.70
95.80
1
126.0
39.7
5KP85A
5KP85CA
85.0
1
94.40
104.0
1
137.0
36.5
5KP90A
5KP90CA
90.0
1
100.0
111.0
1
146.0
34.3
5KP100A
5KP100CA
100.0
1
100.0
111.0
1
162.0
30.9
5KP110A
5KP110CA
110.0
1
111.0
123.0
1
177.0
28.3
5KP120A
5KP120CA
120.0
1
122.0
135.0
1
193.0
26.0
5KP130A
5KP130CA
130.0
1
133.0
147.0
1
209.0
24.0
5KP150A
5KP150CA
150.0
1
144.0
159.0
1
243.0
20.6
5KP160A
5KP160CA
160.0
1
167.0
185.0
1
259.0
19.3
5KP170A
5KP170CA
170.0
1
178.0
197.0
1
275.0
18.2
5KP180A
5KP180CA
180.0
1
189.0
209.0
1
292.0
17.5
5KP190A
5KP190CA
190.0
1
211.0
233.0
1
310.0
16.5
5KP200A
5KP200CA
200.0
1
224.0
247.0
1
329.2
15.5
5KP210A
5KP210CA
210.0
1
237.0
263.0
1
349.5
14.6
5KP220A
5KP220CA
220.0
1
246.0
272.0
1
371.1
13.7
5KP250A
5KP250CA
250.0
1
277.0
306.0
1
425.0
12.0
① Surge waveform: 10/1000μs
VR :Stand-off Voltage -- Maximum voltage that can be applied
VBR:Breakdown Voltage
VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp
IR:Reverse Leakage Current
Rev : 01.06.2014
3/5
www.leiditech.com
RATINGS AND V-I CHARACTERISTICS CURVES (TA=25ºC, unless otherwise noted)
F IG .1:V - I cu rve ch aracteristics
(U n i-d irectio n al)
F IG .2:V - I cu rve ch aracteristics
(B i-d irectio n al)
IP P
V
V C V BR V R
IT
IR
V C VBR VR
V
IR
IT
VF
V R V BR V C
I PP
IP P
FIG.4: Pulse derating curve
FIG.3: Pulse waveform
P PP derating in percentage(%)
100
IPPM (%IRSM )
150
tr = rise time to peak value
td = decay time to half value
tr=10μs
100
80
Peak value
60
Half value
40
50
td
t(ms)
2.0
3.0
4.0
50
T A (℃ )
75
100
125
150
175
SOLDERING PARAMETERS
Reflow Condition
+150℃
-Temperature Max(Ts(max))
+200℃
TP
-Time (Min to Max) (ts)
60-180 secs.
TL
Average ramp up rate (Liquid us Temp
(TL) to peak)
3℃/sec. Max
Ts(max) to TL - Ramp-up Rate
3℃/sec. Max
Reflow
tp
Critical Zone
TL to TP
Ramp-up
tL
TS(max)
-Temperature(TL)(Liquid us)
+217℃
-Temperature(tL)
60-150 secs.
Peak Temp (Tp)
+260(+0/-5)℃
Time within 5℃ of actual Peak Temp (tp)
30 secs. Max
Ramp-down Rate
6℃/sec. Max
Time 25℃ to Peak Temp (TP)
8 min. Max
Do not exceed
+260℃
Rev : 01.06.2014
FIG.5: Reflow condition
-Temperature Min (Ts(min))
4/5
Temperature
Pre
Heat
Pb-Free assembly
(see FIG.5)
Ramp-down
Preheat
TS(min)
25
ts
time to peak temperatue
(t 25℃ to peak)
Time
www.leiditech.com
MARKING & ORDERING INFORMATION
5KP
XX
C
A
(1)
(2)
(3)
(4)
(1)Series:5000 watts series
(2)Reverse Stand-off Voltage
(3)Bi-directional
(4)5% V BR Voltage tolerance
Cathode Band
Logo
Product Type
5KPxxCA
PACKAGE MECHANICAL DATA
Dimensions
A
B
A
Ref.
Min.
C
D
Millimeters
Inches
Max.
Min.
Max.
25.40
A
1.000
B
0.339
0.370
8.60
9.40
C
0.048
0.052
1.20
1.40
D
0.340
0.360
8.60
9.10
Part Number
Case Type
Quantity
Packing Option
5KPXXCA/A
R6/P600
300
Box
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2014
5/5
www.leiditech.com
很抱歉,暂时无法提供与“5KP5.0A”相匹配的价格&库存,您可以联系我们找货
