SS310FA
SS310FA
    LGE(鲁光)
    SMAF
    鲁光 SMAF Io: 3A IR: 0.5mA VF: 0.85V
SS310FA 数据手册
SS32FA--SS310FA SURFACE MOUNT SCHOTTKY SMAF Cathode Band Top View FEATURES 0.110(2.80) 0.094(2.40)  Schottky barrier rectifier 0.059(1.50) 0.051(1.30)  Guarding protection 0.145(3.70) 0.128(3.25)  Low forward voltage 0.012(0.30) 0.004(0.10) 0.059(1.50) 0.039(1.00)  Reverse energy tested 0.047(1.20) 0.028(0.60)  High current capability  Extremely low thermal resistance  This product not contains Antimony and Bromine compounds (rFR) 0.190(4.85) 0.172(4.35) MECHANICAL DATA  Case: SMAFL molded plastic body Dimensions in inches and (millimeters)  Polarity: Color band denotes cathode end  Mounting position: ANY MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified SS32 SS33 SS34 SS35 SS36 SS38 SS39 SS310 FA FA FA FA FA FA FA FA SS32 SS33 SS34 SS35 SS36 SS38 SS39 Device marking code UNITS SS310 Maximum repetitive peak reverse voltage VRRM 20 30 40 50 60 80 90 100 V Maximum RMS voltage VRWS 14 21 28 35 42 56 63 70 V Maximum DC blocking voltage VDC 20 30 40 50 60 80 90 100 V Maximum average forward rectified current at TL=90℃ Peak forward surge current 8.3ms single half-sine-wave Maximum instantaneous forward voltage at IFM=3.0A (NOTE1) Maximum DC reverse current TJ=25℃ at rated DC blocking voltage TJ=125℃ IF(AV) 3.0 A IFSM 100.0 A VF 0.50 0.75 0.85 0.5 IR 20 V mA 10 Maximum thermal resistance R θ JL 17.0 ℃/W Operating temperature range TJ -55----+125 ℃ TSTG -55----+125 ℃ Storage temperature range NOTE: 1.Pulse test: Pulse width 300us, duty cycle 1 % ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com SS32FA--SS310FA SURFACE MOUNT SCHOTTKY PACKAGE SMAF SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG 3000/REEL 80000 36X30.6X31 12.00 11.00 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
SS310FA 价格&库存
很抱歉,暂时无法提供与“SS310FA”相匹配的价格&库存,您可以联系我们找货
