BC846BS
65 V, 100 mA NPN/NPN general-purpose transistor
Rev. 01 — 24 August 2009
Product data sheet
1. Product profile
1.1 General description
NPN/NPN general-purpose transistor pair in a very small Surface-Mounted Device (SMD)
plastic package.
Table 1.
Product overview
Type number
BC846BS
Package
Nexperia
JEITA
PNP/PNP
complement
SOT363
SC-88
BC856BS
NPN/PNP
complement
BC846BPN
1.2 Features
n
n
n
n
n
n
Low collector capacitance
Low collector-emitter saturation voltage
Closely matched current gain
Reduces number of components and board space
No mutual interference between the transistors
AEC-Q101 qualified
1.3 Applications
n General-purpose switching and amplification
1.4 Quick reference data
Table 2.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
open base
65
V
100
mA
200
300
450
Per transistor
VCEO
collector-emitter voltage
IC
collector current
hFE
DC current gain
VCE =5 V; IC = 2 mA
BC846BS
Nexperia
2. Pinning information
Table 3.
Pinning
Pin
Description
1
emitter TR1
2
base TR1
3
collector TR2
4
emitter TR2
5
base TR2
6
collector TR1
Simplified outline
6
5
Graphic symbol
6
4
5
4
TR2
TR1
1
2
3
1
2
3
sym020
3. Ordering information
Table 4.
Type number
BC846BS
Package
Name
Description
Version
SC-88
plastic surface-mounted package; 6 leads
SOT363
4. Marking
Table 5.
Marking codes
Type number
Marking code[1]
BC846BS
*E5
[1]
* = -: made in Hong Kong
* = p: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
Per transistor
VCBO
collector-base voltage
open emitter
80
V
VCEO
open base
65
V
VEBO
emitter-base voltage
open collector
6
V
IC
collector current
100
mA
ICM
peak collector current
single pulse;
tp ≤ 1 ms
200
mA
IBM
peak base current
single pulse;
tp ≤ 1 ms
200
mA
Ptot
total power dissipation
Tamb ≤ 25 °C
200
mW
BC846BS
Product data sheet
[1]
© Nexperia B.V. 2009. All rights reserved.
2 of 12
BC846BS
Nexperia
Table 6.
Limiting values …continued
Symbol
Parameter
Conditions
Min
Max
Unit
Ptot
Tamb ≤ 25 °C
300
mW
Tj
Tamb
junction temperature
150
°C
ambient temperature
−55
+150
°C
Tstg
storage temperature
−65
+150
°C
Per device
[1]
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
006aab618
500
Ptot
(mW)
400
300
200
100
−75
−25
25
75
125
175
Tamb (°C)
FR4 PCB, standard footprint
Fig 1.
Per device: Power derating curve SOT363 (SC-88)
6. Thermal characteristics
Table 7.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
625
K/W
230
K/W
416
K/W
Per transistor
Rth(j-a)
thermal resistance from
junction to ambient
Rth(j-sp)
junction to solder point
in free air
[1]
Per device
Rth(j-a)
[1]
junction to ambient
in free air
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
BC846BS
Product data sheet
[1]
3 of 12
BC846BS
Nexperia
006aab619
103
Zth(j-a)
(K/W)
102
δ=1
0.50
0.75
0.33
0.20
0.10
0.05
10
0.02
0.01
10−5
10−4
10−3
10−2
10−1
1
102
10
tp (s)
103
Fig 2.
Per transistor: Transient thermal impedance from junction to ambient as a function of pulse duration;
typical values
7. Characteristics
Table 8.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
collector-base cut-off VCB =50 V; IE = 0 A
current
VCB =30 V; IE = 0 A;
Tj = 150 °C
15
nA
5
µA
IEBO
emitter-base cut-off
current
VEB =6 V; IC = 0 A
100
nA
hFE
DC current gain
VCE = 5 V
IC = 10 µA
280
IC = 2 mA
200
300
450
Per transistor
ICBO
VCEsat
collector-emitter
saturation voltage
IC = 10 mA; IB = 0.5 mA
55
100
mV
IC = 100 mA; IB = 5 mA
200
300
mV
VBEsat
base-emitter
saturation voltage
755
850
mV
1000
mV
IC = 2 mA
580
650
700
mV
IC = 10 mA
770
mV
VBE
base-emitter voltage VCE = 5 V
BC846BS
Product data sheet
4 of 12
BC846BS
Nexperia
Table 8.
Characteristics …continued
Symbol Parameter
Conditions
Typ
Max
Unit
Cc
collector capacitance VCB =10 V; IE = ie = 0 A;
f = 1 MHz
1.9
pF
Ce
emitter capacitance
VEB = 0.5 V; IC = ic = 0 A;
f = 1 MHz
11
pF
fT
transition frequency
VCE =5 V; IC = 10 mA;
f = 100 MHz
100
MHz
NF
noise figure
VCE =5 V; IC = 0.2 mA;
RS = 2 kΩ;
f = 10 Hz to 15.7 kHz
1.9
dB
RS = 2 kΩ; f = 1 kHz;
B = 200 Hz
3.1
dB
006aaa533
600
0.20
IC
(A)
hFE
0.16
400
Min
006aaa532
IB (mA) = 4.50
4.05
3.60
3.15
2.70
2.25
1.80
1.35
(1)
0.12
0.90
(2)
0.08
200
0.45
(3)
0.04
10−2
10−1
1
10
103
IC (mA)
VCE = 5 V
4
6
8
10
VCE (V)
Tamb = 25 °C
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig 3.
Per transistor: DC current gain as a function of
collector current; typical values
Fig 4.
Per transistor: Collector current as a function
of collector-emitter voltage; typical values
BC846BS
Product data sheet
5 of 12
BC846BS
Nexperia
006aaa536
1
006aaa534
1.3
VBEsat
(V)
1.1
VBE
(V)
0.9
0.8
(1)
(2)
0.7
(3)
0.5
0.6
0.3
0.4
10−1
1
10
102
IC (mA)
0.1
10−1
103
VCE =5 V; Tamb =25 °C
1
10
102
IC (mA)
103
IC/IB = 20
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
Fig 5.
Per transistor: Base-emitter voltage as a
function of collector current; typical values
006aaa535
10
VCEsat
(V)
Fig 6.
Per transistor: Base-emitter saturation voltage
as a function of collector current; typical
values
006aaa537
103
fT
(MHz)
1
102
10−1
(1)
(2)
(3)
10−2
10−1
1
10
102
IC (mA)
10
103
IC/IB = 20
1
10
IC (mA)
102
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig 7.
Per transistor: Collector-emitter saturation
voltage as a function of collector current;
typical values
Fig 8.
Per transistor: Transition frequency as a
BC846BS
Product data sheet
6 of 12
BC846BS
Nexperia
006aab620
6
006aaa539
15
Ce
(pF)
13
Cc
(pF)
4
11
9
2
7
4
6
8
10
VCB (V)
f = 1 MHz; Tamb = 25 °C
Fig 9.
5
VEB (V)
6
Per transistor: Collector capacitance as a
function of collector-base voltage; typical
values
Fig 10. Per transistor: Emitter capacitance as a
function of emitter-base voltage; typical values
BC846BS
Product data sheet
2
7 of 12
BC846BS
Nexperia
8. Test information
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
9. Package outline
2.2
1.8
6
2.2 1.35
2.0 1.15
1.1
0.8
5
4
2
3
0.45
0.15
pin 1
index
1
0.65
1.3
Dimensions in mm
0.3
0.2
0.25
0.10
06-03-16
Fig 11. Package outline SOT363 (SC-88)
10. Packing information
Please refer to packing information on www.nexperia.com.
BC846BS
Product data sheet
8 of 12
BC846BS
Nexperia
11. Soldering
2.65
solder lands
2.35 1.5
0.4 (2×)
0.6 0.5
(4×) (4×)
solder resist
solder paste
0.5
(4×)
0.6
(2×)
occupied area
0.6
(4×)
Dimensions in mm
1.8
sot363_fr
Fig 12. Reflow soldering footprint SOT363 (SC-88)
1.5
solder lands
0.3 2.5
4.5
solder resist
occupied area
1.5
Dimensions in mm
1.3
1.3
preferred transport
direction during soldering
2.45
5.3
sot363_fw
Fig 13. Wave soldering footprint SOT363 (SC-88)
BC846BS
Product data sheet
9 of 12
BC846BS
Nexperia
12. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BC846BS
20090824
Product data sheet
BC846BS
Product data sheet
10 of 12
BC846BS
Nexperia
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
13.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or warranties,
expressed or implied, as to the accuracy or completeness of such information
Right to make changes — Nexperia reserves the right to make changes to
information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in medical, military, aircraft, space or life
support equipment, nor in applications where failure or malfunction of an
Nexperia product can reasonably be expected to result in personal injury,
death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of Nexperia
products in such equipment or applications and therefore such inclusion and/
or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold subject to the
general terms and conditions of commercial sale, as published at http://
www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of any
inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
BC846BS
Product data sheet
11 of 12
BC846BS
Nexperia
14. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
13
13.1
13.2
13.3
13.4
14
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description. . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data. . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2
Thermal characteristics. . . . . . . . . . . . . . . . . . . 3
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 8
Quality information . . . . . . . . . . . . . . . . . . . . . . 8
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Packing information. . . . . . . . . . . . . . . . . . . . . . 8
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10
Legal information. . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to:
salesaddresses@nexperia.com
Date of release: 24 August 2009
Document identifier: BC846BS
