BC856BS,135
BC856BS,135
    NEXPERIA(安世)
    SOT-363
    通用三极管 65V 100mA PNP+PNP SOT363 200~450
BC856BS,135 数据手册
BC856BS 65 V, 100 mA PNP/PNP general-purpose transistor Rev. 01 — 11 August 2009 Product data sheet 1. Product profile 1.1 General description PNP/PNP general-purpose transistor pair in a very small Surface-Mounted Device (SMD) plastic package. Table 1. Product overview Type number BC856BS Package Nexperia JEITA NPN/NPN complement SOT363 SC-88 BC846BS NPN/PNP complement BC846BPN 1.2 Features n n n n n n Low collector capacitance Low collector-emitter saturation voltage Closely matched current gain Reduces number of components and board space No mutual interference between the transistors AEC-Q101 qualified 1.3 Applications n General-purpose switching and amplification 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter Conditions Min Typ Max Unit open base - - −65 V - - −100 mA 200 290 450 Per transistor VCEO collector-emitter voltage IC collector current hFE DC current gain VCE = −5 V; IC = −2 mA BC856BS Nexperia 65 V, 100 mA PNP/PNP general-purpose transistor 2. Pinning information Table 3. Pinning Pin Description 1 emitter TR1 2 base TR1 3 collector TR2 4 emitter TR2 5 base TR2 6 collector TR1 Simplified outline 6 5 Graphic symbol 6 4 5 4 TR2 TR1 1 2 3 1 2 3 sym018 3. Ordering information Table 4. Ordering information Type number BC856BS Package Name Description Version SC-88 plastic surface-mounted package; 6 leads SOT363 4. Marking Table 5. Marking codes Type number Marking code[1] BC856BS *E6 [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China © BC856BS_1 Product data sheet Rev. 01 — 11 August 2009 Nexperia B.V. 2017. All rights reserved 2 of 12 BC856BS Nexperia 65 V, 100 mA PNP/PNP general-purpose transistor 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Per transistor VCBO collector-base voltage open emitter - −80 V VCEO collector-emitter voltage open base - −65 V VEBO emitter-base voltage open collector - −6 V IC collector current - −100 mA ICM peak collector current single pulse; tp ≤ 1 ms - −200 mA IBM peak base current single pulse; tp ≤ 1 ms - −200 mA Ptot total power dissipation Tamb ≤ 25 °C [1] - 200 mW Ptot total power dissipation Tamb ≤ 25 °C [1] - 300 mW Tj junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C Per device [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 006aab618 500 Ptot (mW) 400 300 200 100 0 −75 −25 25 75 125 175 Tamb (°C) FR4 PCB, standard footprint Fig 1. Per device: Power derating curve SOT363 (SC-88) © BC856BS_1 Product data sheet Rev. 01 — 11 August 2009 Nexperia B.V. 2017. All rights reserved 3 of 12 BC856BS Nexperia 65 V, 100 mA PNP/PNP general-purpose transistor 6. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit - - 625 K/W - - 230 K/W - - 416 K/W Per transistor Rth(j-a) thermal resistance from junction to ambient Rth(j-sp) thermal resistance from junction to solder point in free air [1] Per device thermal resistance from junction to ambient Rth(j-a) [1] in free air [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 006aab619 103 Zth(j-a) (K/W) δ=1 0.75 0.50 0.33 102 0.20 0.10 0.05 0.02 10 0.01 0 1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, standard footprint Fig 2. Per transistor: Transient thermal impedance from junction to ambient as a function of pulse duration; typical values © BC856BS_1 Product data sheet Rev. 01 — 11 August 2009 Nexperia B.V. 2017. All rights reserved 4 of 12 BC856BS Nexperia 65 V, 100 mA PNP/PNP general-purpose transistor 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Per transistor ICBO collector-base cut-off VCB = −50 V; IE = 0 A current VCB = −30 V; IE = 0 A; Tj = 150 °C - - −15 nA - - −5 µA - - −100 nA IC = −10 µA - 270 - IC = −2 mA 200 290 450 IC = −10 mA; IB = −0.5 mA - −55 −100 mV IC = −100 mA; IB = −5 mA - −200 −300 mV IC = −10 mA; IB = −0.5 mA - −755 −850 mV IC = −100 mA; IB = −5 mA - −900 - mV IC = −2 mA −600 −650 −750 mV IC = −10 mA - - −820 mV - 2.3 - pF IEBO emitter-base cut-off current VEB = −6 V; IC = 0 A hFE DC current gain VCE = −5 V VCEsat VBEsat VBE collector-emitter saturation voltage base-emitter saturation voltage base-emitter voltage VCE = −5 V Cc collector capacitance VCB = −10 V; IE = ie = 0 A; f = 1 MHz Ce emitter capacitance VEB = −0.5 V; IC = ic = 0 A; f = 1 MHz - 10 - pF fT transition frequency VCE = −5 V; IC = −10 mA; f = 100 MHz 100 - - MHz NF noise figure VCE = −5 V; IC = −0.2 mA; RS = 2 kΩ; f = 10 Hz to 15.7 kHz - 1.6 - dB VCE = −5 V; IC = −0.2 mA; RS = 2 kΩ; f = 1 kHz; B = 200 Hz - 2.9 - dB © BC856BS_1 Product data sheet Rev. 01 — 11 August 2009 Nexperia B.V. 2017. All rights reserved 5 of 12 BC856BS Nexperia 65 V, 100 mA PNP/PNP general-purpose transistor 006aaa541 600 006aaa540 −0.20 IB (mA) = −2.5 −2.25 −2.0 −1.75 −1.5 −1.25 IC (A) hFE −0.16 (1) 400 −0.12 −1.0 (2) −0.75 −0.08 200 −0.5 (3) −0.25 −0.04 0 −10−2 −10−1 −1 −10 0 −102 −103 IC (mA) 0 VCE = −5 V −2 −4 −6 −8 −10 VCE (V) Tamb = 25 °C (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig 3. Per transistor: DC current gain as a function of collector current; typical values 006aaa544 −1 Fig 4. Per transistor: Collector current as a function of collector-emitter voltage; typical values 006aaa542 −1.3 VBEsat (V) −1.1 VBE (V) −0.9 −0.8 (1) −0.7 (2) (3) −0.5 −0.6 −0.3 −0.4 −10−1 −1 −10 −102 −103 −0.1 −10−1 −1 −10 −102 IC (mA) −103 IC (mA) VCE = −5 V; Tamb = 25 °C IC/IB = 20 (1) Tamb = −55 °C (2) Tamb = 25 °C (3) Tamb = 100 °C Fig 5. Per transistor: Base-emitter voltage as a function of collector current; typical values Fig 6. Per transistor: Base-emitter saturation voltage as a function of collector current; typical values © BC856BS_1 Product data sheet Rev. 01 — 11 August 2009 Nexperia B.V. 2017. All rights reserved 6 of 12 BC856BS Nexperia 65 V, 100 mA PNP/PNP general-purpose transistor 006aaa543 −10 VCEsat (V) 006aaa545 103 fT (MHz) −1 102 −10−1 (1) (2) (3) −10−2 −10−1 −1 −10 −102 10 −103 −10 −1 IC (mA) −102 IC (mA) VCE = −5 V; Tamb = 25 °C IC/IB = 20 (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig 7. Per transistor: Collector-emitter saturation voltage as a function of collector current; typical values 006aab623 10 Cc (pF) Per transistor: Transition frequency as a function of collector current; typical values 8 6 11 4 9 2 7 0 −2 −4 −6 −8 −10 VCB (V) f = 1 MHz; Tamb = 25 °C 006aaa547 15 Ce (pF) 13 0 Fig 9. Fig 8. 5 0 −4 −6 VEB (V) f = 1 MHz; Tamb = 25 °C Per transistor: Collector capacitance as a function of collector-base voltage; typical values Fig 10. Per transistor: Emitter capacitance as a function of emitter-base voltage; typical values © BC856BS_1 Product data sheet −2 Rev. 01 — 11 August 2009 Nexperia B.V. 2017. All rights reserved 7 of 12 BC856BS Nexperia 65 V, 100 mA PNP/PNP general-purpose transistor 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 9. Package outline 2.2 1.8 6 2.2 1.35 2.0 1.15 1.1 0.8 5 4 2 3 0.45 0.15 pin 1 index 1 0.3 0.2 0.65 0.25 0.10 1.3 Dimensions in mm 06-03-16 Fig 11. Package outline SOT363 (SC-88) 10. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number BC856BS Package Description SOT363 3000 10000 4 mm pitch, 8 mm tape and reel; T1 [2] -115 -135 4 mm pitch, 8 mm tape and reel; T2 [3] -125 -165 [1] For further information and the availability of packing methods, see Section 14. [2] T1: normal taping [3] T2: reverse taping © BC856BS_1 Product data sheet Packing quantity Rev. 01 — 11 August 2009 Nexperia B.V. 2017. All rights reserved 8 of 12 BC856BS Nexperia 65 V, 100 mA PNP/PNP general-purpose transistor 11. Soldering 2.65 solder lands 2.35 1.5 0.4 (2×) 0.6 0.5 (4×) (4×) solder resist solder paste 0.5 (4×) 0.6 (2×) occupied area 0.6 (4×) Dimensions in mm 1.8 sot363_fr Fig 12. Reflow soldering footprint SOT363 (SC-88) 1.5 solder lands 0.3 2.5 4.5 solder resist occupied area 1.5 Dimensions in mm 1.3 1.3 preferred transport direction during soldering 2.45 5.3 sot363_fw Fig 13. Wave soldering footprint SOT363 (SC-88) © BC856BS_1 Product data sheet Rev. 01 — 11 August 2009 Nexperia B.V. 2017. All rights reserved 9 of 12 BC856BS Nexperia 65 V, 100 mA PNP/PNP general-purpose transistor 12. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BC856BS_1 20090811 Product data sheet - - © BC856BS_1 Product data sheet Rev. 01 — 11 August 2009 Nexperia B.V. 2017. All rights reserved 10 of 12 BC856BS Nexperia 65 V, 100 mA PNP/PNP general-purpose transistor 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 13.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/ or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http:// www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com © BC856BS_1 Product data sheet Rev. 01 — 11 August 2009 Nexperia B.V. 2017. All rights reserved 11 of 12 Nexperia BC856BS 65 V, 100 mA PNP/PNP general-purpose transistor 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics. . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 8 Quality information . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Packing information. . . . . . . . . . . . . . . . . . . . . . 8 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 11 August 2009
BC856BS,135 价格&库存
很抱歉,暂时无法提供与“BC856BS,135”相匹配的价格&库存,您可以联系我们找货
