ESD5Z5L
ESD5Z5L
    LEIDITECH(雷卯电子)
    SOD-523
    雷卯 SOD-523 20W 5V
ESD5Z5L 数据手册
ESD5Z5L Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 5V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±10kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 1A (8/20μs) RoHS Compliant Dimensions SOD-523 Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet 1 2 PIN 1. CATHODE 2. ANODE Mechanical Characteristics ● Package: SOD-523 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp VESD Value Unit 200 W ± 15 Kv ± 10 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2019 1/4 www.leiditech.com ESD5Z5L Electrical Characteristics(TA=25°C unless otherwise specified) Part Number Device Marking VRWM (V) 5L 5 ESD5Z5L Rev : 01.06.2019 VBR (V) 5.4 IT (mA) VC @1A 1 9.8 2/4 Vc (Max) 9.8 (@A) 1 IR μA (Max) C (Pf) (Typ.) 1 0.5 www.leiditech.com ESD5Z5L Typical Performance Characteristics (TA=25°C unless otherwise Specified) Figure 1. ESD Clamping Voltage Screenshot Positive 8 kV Contact per IEC61000−4−2 Rev : 01.06.2019 Figure 2. ESD Clamping Voltage Screenshot Negative 8 kV Contact per IEC61000−4−2 3/4 www.leiditech.com ESD5Z5L SOD-523 Package Outline & Dimensions NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: MILLIMETER. 3. MAXIMUM LEAD THICKNESS INCLUDES LEAD FINISH THICKNESS. MINIMUM LEAD THICKNESS IS THE MINIMUM THICKNESS OF BASE MATERIAL. −X− A −Y− B 1 2 DIM A B C D J K S D 2 PL 0.08 (0.003) M T X Y MILLIMETERS MIN NOM MAX 1.10 1.20 1.30 0.70 0.80 0.90 0.50 0.60 0.70 0.25 0.30 0.35 0.07 0.14 0.20 0.15 0.20 0.25 1.50 1.60 1.70 MIN 0.043 0.028 0.020 0.010 0.0028 0.006 0.059 INCHES NOM MAX 0.047 0.051 0.032 0.035 0.024 0.028 0.012 0.014 0.0055 0.0079 0.008 0.010 0.063 0.067 C K J S −T− SEATING PLANE SOLDERING FOOTPRINT* 1.40 0.0547 0.40 0.0157 0.40 0.0157 SCALE 10:1 mm Ǔ ǒinches Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2019 4/4 www.leiditech.com
ESD5Z5L 价格&库存
很抱歉,暂时无法提供与“ESD5Z5L”相匹配的价格&库存,您可以联系我们找货
