SDLC12C-4
SDLC12C-4
    LEIDITECH(雷卯电子)
    SOP8
    雷卯 SOP-08 374W 12V
SDLC12C-4 数据手册
SDLC12C-4 Low Capacitance TVS Diode for Quad Extended Common-Mode Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 12V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 11A (8/20μs) RoHS Compliant Dimensions SOP-08 Pin Configuration Applications ● Multi-Mode Transceiver Protection ● WAN Equipment: ● CSU/DSU ● Multiplexers ● Protection for any of the RS232 interfaces ● Protection for any of the RS485 interfaces Mechanical Characteristics ● Package: SOP-08 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:2500pcs ● Reel Size:13 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 374 Unit W ±30 VESD Kv ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2014 1/4 www.leiditech.com SDLC12C-4 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number SDLC12C-4 Device Marking VRWM (V) VBR (V) IT (mA) VC @1A SDLC12C-4 12 13.3 1 20 (Max) 34 (@A) 11 IR μA (Max) C (Pf) (Typ.) 1 5 Characteristic Curves 8x20μs Pulse Waveform Power Derating Curve SDLC36C-4 SDLC24C-4 SDLC18C-4 SDLC15C-4 SDLC12C-4 SDLC08C-4 SDLC05C-4 SDLC03C-4 Clamping Voltage vs. Peak Pulse Current (tp=8/20us) Rev : 01.06.2014 2/4 www.leiditech.com SDLC12C-4 APPLICATION INFORMATION Four I/Os Flow-Thru Layout Rev : 01.06.2014 3/4 www.leiditech.com SDLC12C-4 SOP-08 Mechanical Data Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 4/4 www.leiditech.com
SDLC12C-4 价格&库存
很抱歉,暂时无法提供与“SDLC12C-4”相匹配的价格&库存,您可以联系我们找货
