SDLC18C-4
Low Capacitance TVS Diode for Quad Extended Common-Mode
Features
Ultra low leakage: nA level
Operating voltage: 18V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) 8A (8/20μs)
RoHS Compliant
Dimensions SOP-08
Pin Configuration
Applications
Multi-Mode Transceiver Protection
WAN Equipment:
CSU/DSU
Multiplexers
Protection for any of the RS232 interfaces
Protection for any of the RS485 interfaces
Mechanical Characteristics
Package: SOP-08
Lead Finish: Lead Free
UL Flammability Classification Rating 94V-0
Quantity Per Reel:2500pcs
Reel Size:13 inch
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Value
Ppp
320
Unit
W
±30
VESD
Kv
±30
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev : 01.06.2014
1/4
www.leiditech.com
SDLC18C-4
Electrical Characteristics(TA=25°C unless otherwise specified)
Vc
Part Number
SDLC18C-4
Device
Marking
VRWM
(V)
VBR
(V)
IT
(mA)
VC
@1A
SDLC18C-4
18
30
(Max)
40
(@A)
8
IR
μA
(Max)
C
(Pf)
(Typ.)
1
5
Characteristic Curves
8x20μs Pulse Waveform
Power Derating Curve
SDLC36C-4
SDLC24C-4
SDLC18C-4
SDLC15C-4
SDLC12C-4
SDLC08C-4
SDLC05C-4
SDLC03C-4
Clamping Voltage vs. Peak Pulse Current (tp=8/20us)
Rev : 01.06.2014
2/4
www.leiditech.com
SDLC18C-4
APPLICATION INFORMATION
Four I/Os Flow-Thru Layout
Rev : 01.06.2014
3/4
www.leiditech.com
SDLC18C-4
SOP-08 Mechanical Data
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2014
4/4
www.leiditech.com
很抱歉,暂时无法提供与“SDLC18C-4”相匹配的价格&库存,您可以联系我们找货
