BCM847BV; BCM847BS;
BCM847DS
NPN/NPN matched double transistors
Rev. 06 — 28 August 2009
Product data sheet
1. Product profile
1.1 General description
NPN/NPN matched double transistors in small Surface-Mounted Device (SMD) plastic
packages. The transistors are fully isolated internally.
Table 1.
Product overview
Type number
Package
Nexperia
JEITA
PNP/PNP
complement
Matched version of
BCM847BV
SOT666
BCM857BV
BC847BV
BCM847BS
SOT363
SC-88
BCM857BS
BC847BS
BCM847DS
SOT457
SC-74
BCM857DS
1.2 Features
n Current gain matching
n Base-emitter voltage matching
n Drop-in replacement for standard double transistors
1.3 Applications
n Current mirror
n Differential amplifier
1.4 Quick reference data
Table 2.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
open base
45
V
100
mA
200
290
450
Per transistor
VCEO
collector-emitter voltage
IC
collector current
hFE
DC current gain
VCE = 5 V;
IC = 2 mA
BCM847BV/BS/DS
Nexperia
Table 2.
Quick reference data …continued
Symbol
Parameter
Conditions
hFE1/hFE2
hFE matching
VCE = 5 V;
IC = 2 mA
VBE1−VBE2
VBE matching
VCE = 5 V;
IC = 2 mA
Min
Typ
Max
[1]
0.9
1
[2]
2
Unit
Per device
[1]
The smaller of the two values is taken as the numerator.
[2]
The smaller of the two values is subtracted from the larger value.
mV
2. Pinning information
Table 3.
Pinning
Pin
Description
1
emitter TR1
2
base TR1
3
collector TR2
4
emitter TR2
5
base TR2
6
collector TR1
Simplified outline
6
5
Symbol
6
4
5
4
TR2
TR1
1
2
3
1
2
3
001aab555
sym020
3. Ordering information
Table 4.
Type number
Package
Name
Description
Version
BCM847BV
plastic surface-mounted package; 6 leads
SOT666
BCM847BS
SC-88
SOT363
BCM847DS
SC-74
plastic surface-mounted package (TSOP6); 6 leads
SOT457
4. Marking
Table 5.
Marking codes
Type number
Marking code[1]
BCM847BV
3A
BCM847BS
M1*
BCM847DS
R6
[1]
* = -: made in Hong Kong
* = p: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
BCM847BV_BS_DS_6
Product data sheet
NNexperia B.V. 2017. All rights reserved
2 of 15
BCM847BV/BS/DS
Nexperia
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
Per transistor
VCBO
collector-base voltage
open emitter
50
V
VCEO
open base
45
V
VEBO
emitter-base voltage
open collector
6
V
IC
collector current
100
mA
ICM
peak collector current
single pulse;
tp ≤ 1 ms
200
mA
Ptot
total power dissipation
Tamb ≤ 25 °C
SOT666
[1][2]
200
mW
SOT363
[1]
200
mW
SOT457
[1]
250
mW
SOT666
[1][2]
300
mW
SOT363
[1]
300
mW
SOT457
[1]
380
mW
Per device
Ptot
Tamb ≤ 25 °C
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
[2]
Reflow soldering is the only recommended soldering method.
6. Thermal characteristics
Table 7.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Per transistor
Rth(j-a)
thermal resistance from
junction to ambient
in free air
SOT666
[1][2]
625
K/W
SOT363
[1]
625
K/W
SOT457
[1]
500
K/W
BCM847BV_BS_DS_6
Product data sheet
3 of 15
BCM847BV/BS/DS
Nexperia
Table 7.
Thermal characteristics …continued
Symbol
Parameter
Conditions
junction to ambient
in free air
Min
Typ
Max
Unit
Per device
Rth(j-a)
SOT666
[1][2]
416
K/W
SOT363
[1]
416
K/W
SOT457
[1]
328
K/W
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[2]
7. Characteristics
Table 8.
Characteristics
Tamb = 25 °C unless otherwise specified
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCB = 30 V;
IE = 0 A
15
nA
VCB = 30 V;
IE = 0 A;
Tj = 150 °C
5
µA
nA
Per transistor
ICBO
collector-base cut-off
current
IEBO
emitter-base cut-off
current
VEB = 5 V;
IC = 0 A
100
hFE
DC current gain
VCE = 5 V;
IC = 10 µA
250
VCE = 5 V;
IC = 2 mA
200
290
450
IC = 10 mA;
IB = 0.5 mA
50
200
mV
IC = 100 mA;
IB = 5 mA
200
400
mV
VCEsat
VBEsat
VBE
collector-emitter
saturation voltage
base-emitter
saturation voltage
base-emitter voltage
IC = 10 mA;
IB = 0.5 mA
[1]
760
mV
IC = 100 mA;
IB = 5 mA
[1]
910
mV
VCE = 5 V;
IC = 2 mA
[2]
610
660
710
mV
VCE = 5 V;
IC = 10 mA
[2]
770
mV
Cc
collector capacitance
VCB = 10 V;
IE = ie = 0 A;
f = 1 MHz
1.5
pF
Ce
emitter capacitance
VEB = 0.5 V;
IC = ic = 0 A;
f = 1 MHz
11
pF
BCM847BV_BS_DS_6
Product data sheet
4 of 15
BCM847BV/BS/DS
Nexperia
Table 8.
Characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
fT
transition frequency
VCE = 5 V;
IC = 10 mA;
f = 100 MHz
100
250
MHz
NF
noise figure
VCE = 5 V;
IC = 0.2 mA;
RS = 2 kΩ;
f = 10 Hz to
15.7 kHz
2.8
dB
VCE = 5 V;
IC = 0.2 mA;
RS = 2 kΩ;
f = 1 kHz;
B = 200 Hz
3.3
dB
Per device
hFE matching
VCE = 5 V;
IC = 2 mA
[3]
0.9
1
VBE1−VBE2 VBE matching
VCE = 5 V;
IC = 2 mA
[4]
2
hFE1/hFE2
[1]
VBEsat decreases by about 1.7 mV/K with increasing temperature.
[2]
VBE decreases by about 2 mV/K with increasing temperature.
[3]
[4]
BCM847BV_BS_DS_6
Product data sheet
mV
5 of 15
BCM847BV/BS/DS
Nexperia
0.20
IC
(A)
0.16
006aaa532
IB (mA) = 4.50
4.05
3.60
3.15
006aaa533
600
hFE
2.70
2.25
1.80
1.35
0.12
400
(1)
0.90
(2)
0.08
0.45
200
(3)
0.04
10−2
4
6
8
10
VCE (V)
Tamb = 25 °C
10−1
1
102
103
IC (mA)
10
VCE = 5 V
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig 1.
Collector current as a function of
collector-emitter voltage; typical values
Fig 2.
006aaa534
1.3
VBEsat
(V)
1.1
DC current gain as a function of collector
current; typical values
006aaa535
10
VCEsat
(V)
0.9
1
(1)
(2)
0.7
(3)
10−1
0.5
(1)
(2)
(3)
0.3
0.1
10−1
1
10
102
103
10−2
10−1
1
10
102
IC (mA)
IC/IB = 20
IC/IB = 20
(1) Tamb = −55 °C
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
(3) Tamb = −55 °C
Fig 3.
Base-emitter saturation voltage as a function
of collector current; typical values
Fig 4.
Collector-emitter saturation voltage as a
function of collector current; typical values
BCM847BV_BS_DS_6
Product data sheet
103
IC (mA)
6 of 15
BCM847BV/BS/DS
Nexperia
006aaa536
1
VBE
(V)
006aaa537
103
fT
(MHz)
0.8
102
0.6
0.4
10−1
1
102
10
10
103
IC (mA)
VCE = 5 V; Tamb = 25 °C
Fig 5.
Base-emitter voltage as a function of collector
Fig 6.
006aaa538
5
Cc
(pF)
Transition frequency as a function of collector
006aaa539
15
4
Ce
(pF)
13
3
11
2
9
1
7
5
4
6
8
10
VCB (V)
6
f = 1 MHz; Tamb = 25 °C
Collector capacitance as a function of
collector-base voltage; typical values
Fig 8.
Emitter capacitance as a function of
emitter-base voltage; typical values
BCM847BV_BS_DS_6
Product data sheet
2
VEB (V)
Fig 7.
102
10
1
IC (mA)
7 of 15
BCM847BV/BS/DS
Nexperia
8. Application information
V+
VCC
OUT1
OUT2
IN1
R1
TR1
IN2
TR2
l out
TR1
TR2
V−
006aaa523
Fig 9.
006aaa525
Current mirror
Fig 10. Differential amplifier
9. Package outline
1.7
1.5
6
2.2
1.8
0.6
0.5
5
6
4
1.1
0.8
5
4
2
3
0.45
0.15
0.3
0.1
1.7
1.5
2.2 1.35
2.0 1.15
1.3
1.1
pin 1
index
pin 1 index
1
2
1
3
0.18
0.08
0.27
0.17
0.5
1.3
1
Dimensions in mm
0.25
0.10
0.3
0.2
0.65
04-11-08
Fig 11. Package outline SOT666
Dimensions in mm
06-03-16
Fig 12. Package outline SOT363 (SC-88)
3.1
2.7
6
3.0
2.5
1.7
1.3
1.1
0.9
5
4
2
3
0.6
0.2
pin 1 index
1
0.40
0.25
0.95
0.26
0.10
1.9
Dimensions in mm
04-11-08
Fig 13. Package outline SOT457 (SC-74)
BCM847BV_BS_DS_6
Product data sheet
8 of 15
BCM847BV/BS/DS
Nexperia
10. Packing information
Table 9.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number Package Description
Packing quantity
3000 4000 8000 10000
BCM847BV
BCM847BS
BCM847DS
SOT666
SOT363
SOT457
2 mm pitch, 8 mm tape and reel
-315
4 mm pitch, 8 mm tape and reel
-115
4 mm pitch, 8 mm tape and reel; T1
[2]
-115
-135
4 mm pitch, 8 mm tape and reel; T2
[3]
-125
-165
[2]
-115
-135
[3]
-125
-165
[1]
For further information and the availability of packing methods, see Section 14.
[2]
T1: normal taping
[3]
T2: reverse taping
BCM847BV_BS_DS_6
Product data sheet
9 of 15
BCM847BV/BS/DS
Nexperia
11. Soldering
2.75
2.45
2.1
1.6
solder lands
0.4
(6×) 0.25
(2×)
0.538
2
1.7 1.075
0.3
(2×)
placement area
0.55
(2×)
solder paste
occupied area
0.325 0.375
(4×) (4×)
Dimensions in mm
1.7
0.45
(4×)
0.6
(2×)
0.5
(4×)
0.65
(2×)
sot666_fr
Fig 14. Reflow soldering footprint SOT666
2.65
solder lands
2.35 1.5
0.4 (2×)
0.6 0.5
(4×) (4×)
solder resist
solder paste
0.5
(4×)
0.6
(2×)
0.6
(4×)
occupied area
Dimensions in mm
1.8
sot363_fr
Fig 15. Reflow soldering footprint SOT363 (SC-88)
BCM847BV_BS_DS_6
Product data sheet
10 of 15
BCM847BV/BS/DS
Nexperia
1.5
solder lands
0.3 2.5
4.5
solder resist
occupied area
1.5
Dimensions in mm
1.3
preferred transport
direction during soldering
1.3
2.45
5.3
sot363_fw
Fig 16. Wave soldering footprint SOT363 (SC-88)
3.45
1.95
solder lands
0.95
solder resist
0.45 0.55
3.30 2.825
occupied area
solder paste
1.60
1.70
3.10
3.20
msc422
Dimensions in mm
Fig 17. Reflow soldering footprint SOT457 (SC-74)
BCM847BV_BS_DS_6
Product data sheet
11 of 15
BCM847BV/BS/DS
Nexperia
5.30
solder lands
5.05
0.45 1.45 4.45
solder resist
occupied area
1.40
msc423
4.30
Dimensions in mm
Fig 18. Wave soldering footprint SOT457 (SC-74)
BCM847BV_BS_DS_6
Product data sheet
12 of 15
BCM847BV/BS/DS
Nexperia
12. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BCM847BV_BS_DS_6
20090828
Product data sheet
BCM847BV_BS_DS_5
Modifications:
This data sheet was changed to reflect the new company name NXP Semiconductors,
including new legal definitions and disclaimers. No changes were made to the technical
content.
Figure 12 “Package outline SOT363 (SC-88)”: updated
Figure 14 “Reflow soldering footprint SOT666”: updated
Figure 15 “Reflow soldering footprint SOT363 (SC-88)”: updated
Figure 16 “Wave soldering footprint SOT363 (SC-88)”: updated
Figure 18 “Wave soldering footprint SOT457 (SC-74)”: updated
BCM847BV_BS_DS_5
20060627
Product data sheet
BCM847BS_DS_4
BCM847BS_DS_4
20060216
Product data sheet
BCM847BS_DS_3
BCM847BS_DS_3
20060123
Product data sheet
BCM847BS_2
BCM847BS_2
20050406
Product data sheet
BCM847BS_1
BCM847BS_1
20040914
Product data sheet
BCM847BV_BS_DS_6
Product data sheet
13 of 15
BCM847BV/BS/DS
Nexperia
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
13.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or warranties,
expressed or implied, as to the accuracy or completeness of such information
Right to make changes — Nexperia reserves the right to make changes to
information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in medical, military, aircraft, space or life
support equipment, nor in applications where failure or malfunction of an
Nexperia product can reasonably be expected to result in personal injury,
death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of Nexperia
products in such equipment or applications and therefore such inclusion and/
or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold subject to the
general terms and conditions of commercial sale, as published at http://
www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of any
inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to:
salesaddresses@nexperia.com
BCM847BV_BS_DS_6
Product data sheet
14 of 15
Nexperia
BCM847BV/BS/DS
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description. . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data. . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Thermal characteristics. . . . . . . . . . . . . . . . . . . 3
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Application information. . . . . . . . . . . . . . . . . . . 8
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Packing information. . . . . . . . . . . . . . . . . . . . . . 9
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13
Legal information. . . . . . . . . . . . . . . . . . . . . . . 14
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Contact information. . . . . . . . . . . . . . . . . . . . . 14
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 28 August 2009
很抱歉,暂时无法提供与“BCM847BS,135”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.51341
- 10+1.33024
- 30+1.25172
- 100+1.15388
- 500+1.11024
- 1000+0.64811
- 国内价格 香港价格
- 1+2.809881+0.34005
- 10+1.9918010+0.24105
- 100+1.00440100+0.12156
- 500+0.89000500+0.10771
- 1000+0.692611000+0.08382
- 2000+0.619892000+0.07502
- 5000+0.609665000+0.07378
