BZT52B2V4S - BZT52B75S
Taiwan Semiconductor
200mW, 2% Tolerance SMD Zener Diodes
FEATURES
KEY PARAMETERS
Wide zener voltage range selection: 2.4V to 75V
VZ tolerance selection of ± 2%
Moisture sensitivity level: level 1, per J-STD-020
Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VZ
2.4-75
V
PD
200
mW
VF at IF=10mA
1
V
TJ Max.
150
°C
APPLICATIONS
● Low voltage stabilizers or voltage references
● Adapters
● On-board DC/DC converter
Package
SOD-323F
Configuration
Single die
MECHANICAL DATA
Case: SOD-323F
Molding compound meets UL 94 V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Polarity: Indicated by cathode band
Weight: 4.02 ± 0.5mg (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage @ IF=10mA
SYMBOL
VALUE
UNIT
VF
1
V
PD
200
mW
Junction temperature range
TJ
-65 to +150
°C
Storage temperature range
TSTG
-65 to +150
°C
SYMBOL
TYP
UNIT
RӨJA
625
°C/W
Power dissipation
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
1
Version: G1804
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
ZENER VOLTAGE
PART
MARKING
NUMBER
CODE
TEST
REGULAR
TEST
LEAKAGE
CURRENT
IMPEDANCE
CURRENT
CURRENT
IR @ V R
VZ @ IZT
IZT
ZZT @ IZT
ZZK @ IZK
IZK
V
mA
Ω
Ω
mA
µA
V
Min.
Nom.
Max.
Max.
Max.
BZT52B2V4S
0Z
2.35
2.40
2.45
5
100
564
1
45
1
BZT52B2V7S
1Z
2.65
2.70
2.75
5
100
564
1
18
1
BZT52B3V0S
2Z
2.94
3.00
3.06
5
100
564
1
9
1
BZT52B3V3S
3Z
3.23
3.30
3.37
5
95
564
1
4.5
1
BZT52B3V6S
4Z
3.53
3.60
3.67
5
90
564
1
4.5
1
BZT52B3V9S
5Z
3.82
3.90
3.98
5
90
564
1
2.7
1
BZT52B4V3S
6Z
4.21
4.30
4.39
5
90
564
1
2.7
1
BZT52B4V7S
7Z
4.61
4.70
4.79
5
80
470
1
2.7
2.0
BZT52B5V1S
8Z
5.00
5.10
5.20
5
60
451
1
1.8
2.0
BZT52B5V6S
9Z
5.49
5.60
5.71
5
40
376
1
0.9
2.0
BZT52B6V2S
AZ
6.08
6.20
6.32
5
10
141
1
2.7
4.0
BZT52B6V8S
BZ
6.66
6.80
6.94
5
15
75
1
1.8
4.0
BZT52B7V5S
CZ
7.35
7.50
7.65
5
15
75
1
0.9
5.0
BZT52B8V2S
DZ
8.04
8.20
8.36
5
15
75
1
0.63
5.0
BZT52B9V1S
EZ
8.92
9.10
9.28
5
15
94
1
0.45
6.0
BZT52B10S
FZ
9.80
10.00
10.20
5
1
0.18
7.0
BZT52B11S
GZ
10.78
11.00
11.22
5
1
0.09
8.0
BZT52B12S
HZ
11.76
12.00
12.24
5
25
141
1
0.09
8.0
BZT52B13S
JZ
12.74
13.00
13.26
5
30
160
1
0.09
8.0
BZT52B15S
KZ
14.70
15.00
15.30
5
30
188
1
0.045
10.5
BZT52B16S
LZ
15.68
16.00
16.32
5
40
188
1
0.045
11.2
BZT52B18S
MZ
17.64
18.00
18.36
5
45
212
1
0.045
12.6
BZT52B20S
NZ
19.60
20.00
20.40
5
55
212
1
0.045
14.0
BZT52B22S
PZ
21.56
22.00
22.44
5
55
235
1
0.045
15.4
BZT52B24S
RZ
23.52
24.00
24.48
5
70
235
1
0.045
16.8
BZT52B27S
SZ
26.46
27.00
27.54
2
80
282
0.5
0.045
18.9
BZT52B30S
TZ
29.40
30.00
30.60
2
80
282
0.5
0.045
21.0
BZT52B33S
UZ
32.34
33.00
33.66
2
80
306
0.5
0.045
23.0
BZT52B36S
VZ
35.28
36.00
36.72
2
90
329
0.5
0.045
25.2
BZT52B39S
WZ
38.22
39.00
39.78
2
130
329
0.5
0.045
27.3
BZT52B43S
XZ
42.14
43.00
43.86
2
150
353
0.5
0.045
30.1
BZT52B47S
YZ
46.06
47.00
47.94
2
170
353
0.5
0.045
33.0
BZT52B51S
-Z
49.98
51.00
52.02
2
180
376
0.5
0.045
35.7
BZT52B56S
=Z
54.88
56.00
57.12
2
200
400
0.5
0.045
39.2
BZT52B62S
≡Z
60.76
62.00
63.24
2
215
423
0.5
0.045
43.4
BZT52B68S
>Z
66.64
68.00
69.36
2
240
447
0.5
0.045
47.6
BZT52B75S
<Z
73.50
75.00
76.50
2
255
470
0.5
0.045
52.5
2
Max.
Version: G1804
Notes:
1. The zener voltage (VZ) is tested under pulse condition of 30ms.
2. The device numbers listed have a standard tolerance on the normal zener voltage of ±2%.
3. For detailed information on price, availability and delivery of normal zener voltages between the voltages
shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative.
4. The Zener impedance is derived from the 60-cycle ac voltage, which results when an ac current
having an RMS value equal to 10% of the DC zener current(IZT or IZK) is superimposed to IZT or IZK.
ORDERING INFORMATION
PART NO.
(Note 1)
PACKAGE
PACKING
BZT52BxxxS RRG
SOD-323F
3K / 7" Reel
BZT52BxxxS RR
SOD-323F
3K / 7" Reel
BZT52BxxxS R9G
SOD-323F
10K / 13" Reel
BZT52BxxxS R9
SOD-323F
10K / 13" Reel
Note:
1. "xxx" defines voltage from 2.4V (BZT52B2V4S) to 75V (BZT52B75S)
3
Version: G1804
CHARACTERISTICS CURVES
Fig.1 Typical Forward Characteristics
Fig. 2 Zener Breakdown Characteristics
100
TA=25oC
100
10
TA=25oC
10
Zener Current (mA)
Forward Current (mA)
1000
1
0.1
0.01
1
0.4
0.5
0.6
0.7
0.8
0.9
1.0
1.1
1
2
3
5
6
7
8
9
10 11 12
Zener Voltage (V)
Forward Voltage (V)
Fig. 3 Zener Breakdown Characteristics
Fig.4 Power Dissipation Curve
300
Power Dissipation (mW)
100
Zener Current (mA)
4
10
1
0.1
0.01
200
100
25
35
45
55
65
75
50
100
150
200
o
Ambient Temperature ( C)
Zener Voltage (V)
4
Version: G1804
Fig.5 Typical Capacitance
Fig.6 Effect of Zener Voltage on Impedence
1000
1000
Dynamic Impedence(Ohm)
Capacitance (pF)
IZ=1mA
1V Bias
100
Bias at 50% of
VZ (Nom)
10
IZ=5mA
100
IZ=20mA
10
1
1
1
10
Zener Voltage (V)
1
100
10
100
Zener Voltage (V)
5
Version: G1804
PACKAGE OUTLINE DIMENSION
SOD-323F
Unit (mm)
DIM.
Unit (inch)
Min
Max
Min
Max
A
1.15
1.35
0.045
0.053
B
2.30
2.80
0.091
0.110
C
0.25
0.40
0.010
0.016
D
1.60
1.80
0.063
0.071
E
0.80
1.10
0.031
0.043
F
0.05
0.25
0.002
0.010
SUGGEST PAD LAYOUT
Unit (mm)
Unit (inch)
Typ.
Typ.
A
0.63
0.025
B
0.83
0.033
C
1.60
0.063
D
2.86
0.113
DIM.
6
Version: G1804
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: G1804
很抱歉,暂时无法提供与“BZT52B15S”相匹配的价格&库存,您可以联系我们找货
