BZT52C2V4S - BZT52C75S
Taiwan Semiconductor
200mW, 5% Tolerance SMD Zener Diodes
FEATURES
KEY PARAMETERS
Wide zener voltage range selection: 2.4V to 75V
VZ tolerance selection of ± 5%
Moisture sensitivity level: level 1, per J-STD-020
Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VZ
2.4-75
V
PD
200
mW
VF at IF=10mA
1
V
TJ Max.
150
°C
Package
SOD-323F
Configuration
Single die
APPLICATIONS
● Low voltage stabilizers or voltage references
● Adapters
● On-board DC/DC converter
MECHANICAL DATA
Case: SOD-323F
Molding compound meets UL 94 V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Polarity: Indicated by cathode band
Weight: 4.02 ± 0.5mg (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage @ IF=10mA
SYMBOL
VALUE
UNIT
VF
1
V
Power dissipation
PD
200
mW
Junction temperature range
TJ
-65 to +150
°C
Storage temperature range
TSTG
-65 to +150
°C
SYMBOL
TYP
UNIT
RӨJA
625
°C/W
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
1
Version: I1804
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
ZENER VOLTAGE
TEST
REGULAR IMPEDANCE
CURRENT
PART
MARKING
NUMBER
CODE
VZ @ IZT
V
TEST
LEAKAGE
CURRENT
CURRENT
IR @ V R
IZT
ZZT @ IZT
ZZK @ IZK
IZK
mA
Ω
Ω
mA
µA
V
Min.
Nom.
Max.
Max.
Max.
BZT52C2V4S
Z0
2.28
2.40
2.52
5
100
564
1
45
1
BZT52C2V7S
Z1
2.57
2.70
2.84
5
100
564
1
18
1
BZT52C3V0S
Z2
2.85
3.00
3.15
5
100
564
1
9
1
BZT52C3V3S
Z3
3.14
3.30
3.47
5
95
564
1
4.5
1
BZT52C3V6S
Z4
3.42
3.60
3.78
5
90
564
1
4.5
1
BZT52C3V9S
Z5
3.71
3.90
4.10
5
90
564
1
2.7
1
BZT52C4V3S
Z6
4.09
4.30
4.52
5
90
564
1
2.7
1
BZT52C4V7S
Z7
4.47
4.70
4.94
5
80
470
1
2.7
2.0
BZT52C5V1S
Z8
4.85
5.10
5.36
5
60
451
1
1.8
2.0
BZT52C5V6S
Z9
5.32
5.60
5.88
5
40
376
1
0.9
2.0
BZT52C6V2S
ZA
5.89
6.20
6.51
5
10
141
1
2.7
4.0
BZT52C6V8S
ZB
6.46
6.80
7.14
5
15
75
1
1.8
4.0
BZT52C7V5S
ZC
7.11
7.50
7.86
5
15
75
1
0.9
5.0
BZT52C8V2S
ZD
7.79
8.20
8.61
5
15
75
1
0.63
5.0
BZT52C9V1S
ZE
8.65
9.10
9.56
5
15
94
1
0.45
6.0
BZT52C10S
ZF
9.50
10
10.50
5
1
0.18
7.0
BZT52C11S
ZG
10.45
11
11.55
5
1
0.09
8.0
BZT52C12S
ZH
11.40
12
12.60
5
25
141
1
0.09
8.0
BZT52C13S
ZJ
12.35
13
13.65
5
30
160
1
0.09
8.0
BZT52C15S
ZK
14.25
15
15.75
5
30
188
1
0.045
10.5
BZT52C16S
ZL
15.20
16
16.80
5
40
188
1
0.045
11.2
BZT52C18S
ZM
17.10
18
18.90
5
45
212
1
0.045
12.6
BZT52C20S
ZN
19.00
5
55
212
1
0.045
14.0
BZT52C22S
ZP
20.90
22
23.10
5
55
235
1
0.045
15.4
BZT52C24S
ZR
22.80
24
25.20
5
70
235
1
0.045
16.8
BZT52C27S
ZS
25.65
27
28.35
2
80
282
0.5
0.045
18.9
BZT52C30S
ZT
28.50
30
31.50
2
80
282
0.5
0.045
21.0
BZT52C33S
ZU
31.35
33
34.65
2
80
306
0.5
0.045
23.0
BZT52C36S
ZV
34.20
36
37.80
2
90
329
0.5
0.045
25.2
BZT52C39S
ZW
37.05
39
40.95
2
130
329
0.5
0.045
27.3
BZT52C43S
ZX
40.85
43
45.15
2
150
353
0.5
0.045
30.1
BZT52C47S
ZY
44.65
47
49.35
2
170
353
0.5
0.045
33.0
BZT52C51S
Z-
48.45
51
53.55
2
180
376
0.5
0.045
35.7
BZT52C56S
Z=
53.20
56
58.80
2
200
400
0.5
0.045
39.2
BZT52C62S
Z≡
58.90
62
65.10
2
215
423
0.5
0.045
43.4
BZT52C68S
Z>
64.60
68
71.40
2
240
447
0.5
0.045
47.6
BZT52C75S
Z<
71.25
75
78.75
2
255
470
0.5
0.045
52.5
2
Max.
Version: I1804
Notes:
1. The zener voltage (VZ) is tested under pulse condition of 30ms.
2. The device numbers listed have a standard tolerance on the normal zener voltage of ±5%.
3. For detailed information on price, availability and delivery of normal zener voltages between the voltages
shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative.
4. The Zener impedance is derived from the 60-cycle ac voltage, which results when an ac current
having an RMS value equal to 10% of the DC zener current(IZT or IZK) is superimposed to IZT or IZK.
ORDERING INFORMATION
PART NO.
(Note 1)
PACKAGE
PACKING
BZT52CxxxS RRG
SOD-323F
3K / 7" Reel
BZT52CxxxS RR
SOD-323F
3K / 7" Reel
BZT52CxxxS R9G
SOD-323F
10K / 13" Reel
BZT52CxxxS R9
SOD-323F
10K / 13" Reel
Note:
1. "xxx" defines voltage from 2.4V (BZT52C2V4S) to 75V (BZT52C75S)
3
Version: I1804
CHARACTERISTICS CURVES
Fig.1 Typical Forward Characteristics
Fig. 2 Zener Breakdown Characteristics
100
TA=25oC
100
10
TA=25oC
10
Zener Current (mA)
Forward Current (mA)
1000
1
0.1
0.01
1
0.4
0.5
0.6
0.7
0.8
0.9
1.0
1.1
1
2
3
5
6
7
8
9
10 11 12
Zener Voltage (V)
Forward Voltage (V)
Fig. 3 Zener Breakdown Characteristics
Fig.4 Power Dissipation Curve
300
Power Dissipation (mW)
100
Zener Current (mA)
4
10
1
0.1
0.01
200
100
25
35
45
55
65
75
50
100
150
200
o
Ambient Temperature ( C)
Zener Voltage (V)
4
Version: I1804
Fig.5 Typical Capacitance
Fig.6 Effect of Zener Voltage on Impedence
1000
1000
Dynamic Impedence(Ohm)
Capacitance (pF)
IZ=1mA
1V Bias
100
Bias at 50% of
VZ (Nom)
10
IZ=5mA
100
IZ=20mA
10
1
1
1
10
Zener Voltage (V)
1
100
10
100
Zener Voltage (V)
5
Version: I1804
PACKAGE OUTLINE DIMENSION
SOD-323F
Unit (mm)
DIM.
Unit (inch)
Min
Max
Min
Max
A
1.15
1.35
0.045
0.053
B
2.30
2.80
0.091
0.110
C
0.25
0.40
0.010
0.016
D
1.60
1.80
0.063
0.071
E
0.80
1.10
0.031
0.043
F
0.05
0.25
0.002
0.010
SUGGEST PAD LAYOUT
Unit (mm)
Unit (inch)
Typ.
Typ.
A
0.63
0.025
B
0.83
0.033
C
1.60
0.063
D
2.86
0.113
DIM.
6
Version: I1804
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: I1804
很抱歉,暂时无法提供与“BZT52C2V4S”相匹配的价格&库存,您可以联系我们找货
