BZT52C8V2S
BZT52C8V2S
    TAIWANSEMICONDUCTOR(台半)
    SOD323F
    台半 SOD-323F Zzk: 75Ω Pd: 200mW Izk: 1mA
BZT52C8V2S 数据手册
BZT52C2V4S - BZT52C75S Taiwan Semiconductor 200mW, 5% Tolerance SMD Zener Diodes FEATURES KEY PARAMETERS ● ● ● ● Wide zener voltage range selection: 2.4V to 75V VZ tolerance selection of ± 5% Moisture sensitivity level: level 1, per J-STD-020 Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT VZ 2.4-75 V PD 200 mW VF at IF=10mA 1 V TJ Max. 150 °C Package SOD-323F Configuration Single die APPLICATIONS ● Low voltage stabilizers or voltage references ● Adapters ● On-board DC/DC converter MECHANICAL DATA ● ● ● ● ● Case: SOD-323F Molding compound meets UL 94 V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Polarity: Indicated by cathode band Weight: 4.02 ± 0.5mg (approximately) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage @ IF=10mA SYMBOL VALUE UNIT VF 1 V Power dissipation PD 200 mW Junction temperature range TJ -65 to +150 °C Storage temperature range TSTG -65 to +150 °C SYMBOL TYP UNIT RӨJA 625 °C/W THERMAL PERFORMANCE PARAMETER Junction-to-ambient thermal resistance 1 Version: I1804 BZT52C2V4S - BZT52C75S Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) ZENER VOLTAGE TEST REGULAR IMPEDANCE CURRENT PART MARKING NUMBER CODE VZ @ IZT V TEST LEAKAGE CURRENT CURRENT IR @ V R IZT ZZT @ IZT ZZK @ IZK IZK mA Ω Ω mA µA V Min. Nom. Max. Max. Max. BZT52C2V4S Z0 2.28 2.40 2.52 5 100 564 1 45 1 BZT52C2V7S Z1 2.57 2.70 2.84 5 100 564 1 18 1 BZT52C3V0S Z2 2.85 3.00 3.15 5 100 564 1 9 1 BZT52C3V3S Z3 3.14 3.30 3.47 5 95 564 1 4.5 1 BZT52C3V6S Z4 3.42 3.60 3.78 5 90 564 1 4.5 1 BZT52C3V9S Z5 3.71 3.90 4.10 5 90 564 1 2.7 1 BZT52C4V3S Z6 4.09 4.30 4.52 5 90 564 1 2.7 1 BZT52C4V7S Z7 4.47 4.70 4.94 5 80 470 1 2.7 2.0 BZT52C5V1S Z8 4.85 5.10 5.36 5 60 451 1 1.8 2.0 BZT52C5V6S Z9 5.32 5.60 5.88 5 40 376 1 0.9 2.0 BZT52C6V2S ZA 5.89 6.20 6.51 5 10 141 1 2.7 4.0 BZT52C6V8S ZB 6.46 6.80 7.14 5 15 75 1 1.8 4.0 BZT52C7V5S ZC 7.11 7.50 7.86 5 15 75 1 0.9 5.0 BZT52C8V2S ZD 7.79 8.20 8.61 5 15 75 1 0.63 5.0 BZT52C9V1S ZE 8.65 9.10 9.56 5 15 94 1 0.45 6.0 BZT52C10S ZF 9.50 10 10.50 5 20 141 1 0.18 7.0 BZT52C11S ZG 10.45 11 11.55 5 20 141 1 0.09 8.0 BZT52C12S ZH 11.40 12 12.60 5 25 141 1 0.09 8.0 BZT52C13S ZJ 12.35 13 13.65 5 30 160 1 0.09 8.0 BZT52C15S ZK 14.25 15 15.75 5 30 188 1 0.045 10.5 BZT52C16S ZL 15.20 16 16.80 5 40 188 1 0.045 11.2 BZT52C18S ZM 17.10 18 18.90 5 45 212 1 0.045 12.6 BZT52C20S ZN 19.00 20 21.00 5 55 212 1 0.045 14.0 BZT52C22S ZP 20.90 22 23.10 5 55 235 1 0.045 15.4 BZT52C24S ZR 22.80 24 25.20 5 70 235 1 0.045 16.8 BZT52C27S ZS 25.65 27 28.35 2 80 282 0.5 0.045 18.9 BZT52C30S ZT 28.50 30 31.50 2 80 282 0.5 0.045 21.0 BZT52C33S ZU 31.35 33 34.65 2 80 306 0.5 0.045 23.0 BZT52C36S ZV 34.20 36 37.80 2 90 329 0.5 0.045 25.2 BZT52C39S ZW 37.05 39 40.95 2 130 329 0.5 0.045 27.3 BZT52C43S ZX 40.85 43 45.15 2 150 353 0.5 0.045 30.1 BZT52C47S ZY 44.65 47 49.35 2 170 353 0.5 0.045 33.0 BZT52C51S Z- 48.45 51 53.55 2 180 376 0.5 0.045 35.7 BZT52C56S Z= 53.20 56 58.80 2 200 400 0.5 0.045 39.2 BZT52C62S Z≡ 58.90 62 65.10 2 215 423 0.5 0.045 43.4 BZT52C68S Z> 64.60 68 71.40 2 240 447 0.5 0.045 47.6 BZT52C75S Z< 71.25 75 78.75 2 255 470 0.5 0.045 52.5 2 Max. Version: I1804 BZT52C2V4S - BZT52C75S Taiwan Semiconductor Notes: 1. The zener voltage (VZ) is tested under pulse condition of 30ms. 2. The device numbers listed have a standard tolerance on the normal zener voltage of ±5%. 3. For detailed information on price, availability and delivery of normal zener voltages between the voltages shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative. 4. The Zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an RMS value equal to 10% of the DC zener current(IZT or IZK) is superimposed to IZT or IZK. ORDERING INFORMATION PART NO. (Note 1) PACKAGE PACKING BZT52CxxxS RRG SOD-323F 3K / 7" Reel BZT52CxxxS RR SOD-323F 3K / 7" Reel BZT52CxxxS R9G SOD-323F 10K / 13" Reel BZT52CxxxS R9 SOD-323F 10K / 13" Reel Note: 1. "xxx" defines voltage from 2.4V (BZT52C2V4S) to 75V (BZT52C75S) 3 Version: I1804 BZT52C2V4S - BZT52C75S Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Typical Forward Characteristics Fig. 2 Zener Breakdown Characteristics 100 TA=25oC 100 10 TA=25oC 10 Zener Current (mA) Forward Current (mA) 1000 1 0.1 0.01 1 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 0 1.2 1 2 3 5 6 7 8 9 10 11 12 Zener Voltage (V) Forward Voltage (V) Fig. 3 Zener Breakdown Characteristics Fig.4 Power Dissipation Curve 300 Power Dissipation (mW) 100 Zener Current (mA) 4 10 1 0.1 0.01 200 100 0 15 25 35 45 55 65 75 0 85 50 100 150 200 o Ambient Temperature ( C) Zener Voltage (V) 4 Version: I1804 BZT52C2V4S - BZT52C75S Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Typical Capacitance Fig.6 Effect of Zener Voltage on Impedence 1000 1000 Dynamic Impedence(Ohm) Capacitance (pF) IZ=1mA 1V Bias 100 Bias at 50% of VZ (Nom) 10 IZ=5mA 100 IZ=20mA 10 1 1 1 10 Zener Voltage (V) 1 100 10 100 Zener Voltage (V) 5 Version: I1804 BZT52C2V4S - BZT52C75S Taiwan Semiconductor PACKAGE OUTLINE DIMENSION SOD-323F Unit (mm) DIM. Unit (inch) Min Max Min Max A 1.15 1.35 0.045 0.053 B 2.30 2.80 0.091 0.110 C 0.25 0.40 0.010 0.016 D 1.60 1.80 0.063 0.071 E 0.80 1.10 0.031 0.043 F 0.05 0.25 0.002 0.010 SUGGEST PAD LAYOUT Unit (mm) Unit (inch) Typ. Typ. A 0.63 0.025 B 0.83 0.033 C 1.60 0.063 D 2.86 0.113 DIM. 6 Version: I1804 BZT52C2V4S - BZT52C75S Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version: I1804
BZT52C8V2S 价格&库存
很抱歉,暂时无法提供与“BZT52C8V2S”相匹配的价格&库存,您可以联系我们找货
