SMT POWER INDUCTORS
Shielded Drum Core - PL89XX Series
Ruggedized
Inductance Range: 0.8µH to 54.4µH
Current Rating: up to 11A
Height: 7.1mm Max
Footprint: 10.5mm x 10.5mm Max
Moisture Sensitivity Level: 1
Electrical Specifications @ 25 °C — Operating Temperature - 40 °C to +130 °C
Saturation 3
Part
Inductance @0ADC
Irated 2
Inductance @Irated
DCR (mΩ)
Heating 4 Current
Current
(A)
Numbers
TYP
MAX
(µH TYP)
(µH)
(A) @25°C
(A)
0.80
11
3.5
4.0
1.0*
14
11
PL8901
1.20
10
4.3
6.0
1.5*
13
10
PL8902
2.1
9.0
5.1
7.3
2.7*
11
9
PL8903
2.9
8.0
6.9
8.5
3.7*
9.2
8
PL8904
3.7
7.3
7.9
9.5
4.7*
8.2
7.3
PL8905
4.8
6.0
10.9
16.5
6.0*
6.9
6.0
PL8906
6
5.5
14.8
18.5
7.6*
6.2
5.5
PL8907
8
5.0
16.7
21.8
10
5.5
5.0
PL8908
9.6
4.5
18.1
29.0
12
5.1
4.5
PL8909
12
4.1
21.2
35.4
15
4.4
4.1
PL8910
14.4
4.0
27.9
37.0
18
4.3
4.0
PL8911
17.6
3.8
29.8
42.0
22
3.8
3.8
PL8912
21.6
3.4
40.9
45.9
27
3.4
3.4
PL8913
26.4
3.0
43.1
64.8
33
3.0
3.1
PL8914
31.2
2.7
60.8
81.5
39
2.8
2.7
PL8915
37.6
2.6
67.1
89.0
47
2.6
2.6
PL8916
54.4
2.1
103.6
135.0
68
2.1
2.1
PL8917
*Inductance at 0ADC tolerance on indicated part numbers is ±30%; tolerance is ±20% on all other parts.
NOTES FROM TABLE: (See back page)
Optional Tape & Reel packaging can be ordered by adding a "T" suffix to the part number (i.e. PL8901 becomes PL8901T).
Mechanical
1
www.inrcore.com
Electrical Schematic
M117.C (07/20)
SMT POWER INDUCTORS
Ruggedized
Notes for tables:
Percentage of the intitial inductance�
4. The heating current is the DC current, which causes the temperature of
the part to increase
1. Temperature of the component (ambient plus temperature rise) must be
by approximately 40°C. This current is determined by extending the
within specified operating temperature range.
terminals of the component with 30mm length 28 gauge buss wires and
2. The rated current as listed is either the saturation current or the heating
applying the current to the device for 30 minutes. The temperature is
current depending on which value is lower.
measured by placing the thermo-couple between the winding and the
3. The saturation current is the current which causes the inductance to drop
shield.
to 75% of its initial inductance at zero bias. This current is determined
5. In high volt*time applications, additional heating in the component can
by placing the component at room ambient (25°C), and applying a
occur due to core losses in the inductor which may necessitate derating
short duration pulse current (to eliminate self-heating effects) to the
the current in order to limit the temperature rise of the compo-nent. In
component.
order to determine the approximate total loss (or temperature rise) for a
given application, both copper losses and core losses should be taken into
account.
Inductance vs. Current Characteristics
120%
100%
80%
60%
40%
20%
0%
0.0
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
Normalized Isat
2
www.inrcore.com
M117.C (07/20)
SMT POWER INDUCTORS
Ruggedized
For More Information
Global Sales Representatives and Lo cations:
http://www.inrcore.com
iNRCORE,LLC
311 Sinclair Road Bristol,
PA 19007-6812 U.S.A
Tel: + 1.215.781.6400
Fax: +1.215.7816430
Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names
mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2020. iNRCORE, LLC. All rights reserved.
3
www.inrcore.com
M117.C (07/20)
很抱歉,暂时无法提供与“PL8916T”相匹配的价格&库存,您可以联系我们找货
