BZT55C2V4 - BZT55C75
Taiwan Semiconductor
500mW, 5% Tolerance Zener Diodes
FEATURES
KEY PARAMETERS
● Wide zener voltage range selection: 2.4V to 75V
● VZ tolerance selection of ± 5%
● Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
PARAMETER
VALUE
UNIT
VZ
2.4-75
V
PD
500
mW
VF at IF=10mA
1
V
TJ Max.
Package
APPLICATIONS
Configuration
Low voltage stabilizers or voltage references
Adapters
Lighting application
On-board DC/DC converter
175
°C
Quadro MiniMELF (LS34)
Single die
MECHANICAL DATA
Case: Quadro Mini-MELF (LS34)
Terminal: Matte tin plated leads, solderable per J-STD-002
Polarity: Indicated by cathode band
Weight: 29 ± 2.5mg
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage @ IF=10mA
SYMBOL
VALUE
UNIT
VF
1
V
Power dissipation
PD
500
mW
Junction temperature range
TJ
-65 to +175
°C
Storage temperature range
TSTG
-65 to +175
°C
SYMBOL
TYP
UNIT
RӨJA
500
°C/W
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
1
Version: H1809
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
ZENER VOLTAGE
PART NUMBER
TEST
REGULAR
TEST
CURRENT
IMPEDANCE
CURRENT
VZ @ IZT
IZT
ZZT @ IZT
ZZK @ IZK
IZK
V
mA
Ω
Ω
mA
LEAKAGE CURRENT
IR @ V R
µA
V
Nom.
Min.
Max.
Max.
Max.
BZT55C2V4
2.4
2.28
2.56
5
85
600
1
50
1
BZT55C2V7
2.7
2.51
2.89
5
85
600
1
10
1
BZT55C3V0
3.0
2.8
3.2
5
85
600
1
4
1
BZT55C3V3
3.3
3.1
3.5
5
85
600
1
2
1
BZT55C3V6
3.6
3.4
3.8
5
85
600
1
2
1
BZT55C3V9
3.9
3.7
4.1
5
85
600
1
2
1
BZT55C4V3
4.3
4.0
4.6
5
75
600
1
1
1
BZT55C4V7
4.7
4.4
5.0
5
60
600
1
0.5
1
BZT55C5V1
5.1
4.8
5.4
5
35
550
1
0.1
1
BZT55C5V6
5.6
5.2
6.0
5
25
450
1
0.1
1
BZT55C6V2
6.2
5.8
6.6
5
10
200
1
0.1
2
BZT55C6V8
6.8
6.4
7.2
5
8
150
1
0.1
3
BZT55C7V5
7.5
7.0
7.9
5
7
50
1
0.1
5
BZT55C8V2
8.2
7.7
8.7
5
7
50
1
0.1
6.2
BZT55C9V1
9.1
8.5
9.6
5
10
50
1
0.1
6.8
BZT55C10
10
9.4
10.6
5
15
70
1
0.1
7.5
BZT55C11
11
10.4
11.6
5
1
0.1
8.2
BZT55C12
12
11.4
12.7
5
1
0.1
9.1
BZT55C13
13
12.4
14.1
5
26
110
1
0.1
10
BZT55C15
15
13.8
15.6
5
30
110
1
0.1
11
BZT55C16
16
15.3
17.1
5
40
170
1
0.1
12
BZT55C18
18
16.8
19.1
5
50
170
1
0.1
13
BZT55C20
21.1
5
55
220
1
0.1
15
BZT55C22
22
20.8
23.3
5
55
220
1
0.1
16
BZT55C24
24
22.8
25.6
5
80
220
1
0.1
18
BZT55C27
27
25.1
28.9
5
80
220
1
0.1
BZT55C30
30
28
32
5
80
220
1
0.1
22
BZT55C33
33
31
35
5
80
220
1
0.1
24
BZT55C36
36
34
38
5
80
220
1
0.1
27
BZT55C39
39
37
41
2.5
90
500
0.5
0.1
28
BZT55C43
43
40
46
2.5
90
600
0.5
0.1
32
BZT55C47
47
44
50
2.5
110
700
0.5
0.1
35
BZT55C51
51
48
54
2.5
125
700
0.5
0.1
38
BZT55C56
56
52
60
2.5
135
1,000
0.5
0.1
42
BZT55C62
62
58
66
2.5
150
1,000
0.5
0.1
47
BZT55C68
68
64
72
2.5
160
1,000
0.5
0.1
51
BZT55C75
75
70
79
2.5
170
1,000
0.5
0.1
56
2
Max.
Version: H1809
Notes:
1. The zener voltage (VZ) is tested under pulse condition of 30ms
2. The device numbers listed have a standard tolerance on the nomial zener voltage of ±5%
3. For detailed information on price, availability and delivery of nominal zener voltages between the voltages
shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative
4. The zener impedance is derived from the 60-cycle ac voltage, which results when an ac current
having an rms value equal to 10% of the DC zener current(IZT or IZK) is superimposed to IZT or IZK
ORDERING INFORMATION
ORDERING CODE
(Note)
PACKAGE
PACKING
BZT55Cxxx L0
Quadro Mini-MELF
10K / 13" Reel
BZT55Cxxx L0G
Quadro Mini-MELF
10K / 13" Reel
BZT55Cxxx L1
Quadro Mini-MELF
2.5K / 7" Reel
BZT55Cxxx L1G
Quadro Mini-MELF
2.5K / 7" Reel
Note:
"xxx" defines voltage from 2.4V (BZT55C2V4) to 75V (BZT55C75)
“G” means green compound (halogen free)
3
Version: H1809
CHARACTERISTICS CURVES
Fig. 1 Typical Forward Characteristics
Fig. 2 Admissible Power Dissipation Curve
600
500
TA=25oC
Power Dissipation (mW)
Forward Current (mA)
1000
100
10
400
300
200
100
0.4
0.5
0.6
0.7
0.8
0.9
1.0
1.1
50
100
150
200
Ambient Temperature (oC)
Forward Voltage (V)
Fig. 3 Typical Capacitance
1000
Capacitance (pF)
100
1V Bias
10
Bias at 50% of VZ (Nom)
1
1
10
100
Zener Voltage (V)
4
Version: H1809
PACKAGE OUTLINE DIMENSION
Quadro Mini-MELF
Unit (mm)
DIM.
Unit (inch)
Min
Max
Min
Max
A
3.30
3.70
0.130
0.146
B
1.40
1.60
0.055
0.063
C
0.20
0.45
0.008
0.018
D
1.8 TYP.
0.071 TYP.
SUGGEST PAD LAYOUT
Unit (mm)
Unit (inch)
Typ.
Typ.
A
1.25
0.049
B
2.00
0.079
C
2.50
0.098
D
5.00
0.197
DIM.
5
Version: H1809
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: H1809
很抱歉,暂时无法提供与“BZT55C2V4 L0”相匹配的价格&库存,您可以联系我们找货
