BZX84CXXX
Rev.H Jan.-2019
DATA SHEET
Descriptions
SOT-23 塑封封装 稳压二极管。
Zener Diode in a SOT-23 Plastic Package.
特征
/ Features
300mW 功耗,非常适合于自动化装配流程。
300mW power dissipation, Ideally Suited for Automated Assembly.
用途
Applications
适用于 2.4V-51V 的宽范围稳压电路。
2.4V to 51V wide zener voltage range applications.
内部等效电路
引脚排列
/ Equivalent Circuit
/ Pinning
3
1
2
PIN: See Equivalent Circuit.
放大及印章代码
/ hFE Classifications & Marking
见电性能参数。See Electrical Characteristics.
http://www.fsbrec.com
1/7
BZX84CXXX
Rev.H Jan.-2019
极限参数
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
Forward Voltage( IF=10mA)
符号
Symbol
VF
数值
Rating
0.9
单位
Unit
V
Power Dissipation(Note 1)
PD
300
mW
Power Dissipation(Note 4)
PD
350
mW
Thermal Resistance, Junction to Ambient(Note 1)
RθJA
417
℃/W
Thermal Resistance, Junction to Ambient(Note 4)
RθJA
357
℃/W
Junction and Storage Temperature Range
Tj,Tstg
-65~150
电性能参数
Type
Number
/ Electrical Characteristics(Ta=25℃)
Zener Voltage Range
(Note 2)
Marking
Code
Vz @IZT
IZT
ZZT @IZT
Maximum
Reverse
Current
(Note 2)
ZZK @IZK
IR
VR
Typical
Temperature
Coefficient
@IZT
mV/ºC
Maximum Zener
Impedance (Note 3)
Nom
(V)
Min
(V)
Max
(V)
mA
Ω
Ω
mA
uA
V
Min
Max
BZX84C2V4
HZB
2.4
2.2
2.6
5.0
100
600
1.0
50
1.0
-3.5
BZX84C2V7
HZC
2.7
2.5
2.9
5.0
100
600
1.0
-3.5
BZX84C3V0
HZD
3.0
2.8
3.2
5.0
95
600
1.0
10
1.0
-3.5
BZX84C3V3
HZE
3.3
3.1
3.5
5.0
95
600
1.0
5.0
1.0
-3.5
BZX84C3V6
HZF
3.6
3.4
3.8
5.0
90
600
1.0
5.0
1.0
-3.5
BZX84C3V9
HZG
3.9
3.7
4.1
5.0
90
600
1.0
3.0
1.0
-3.5
BZX84C4V3
ZHH
4.3
4.0
4.6
5.0
90
600
1.0
3.0
1.0
-3.5
BZX84C4V7
HZ1
4.7
4.4
5.0
5.0
80
500
1.0
3.0
2.0
-3.5
0.2
BZX84C5V1
HZ2
5.1
4.8
5.4
5.0
60
480
1.0
2.0
2.0
-2.7
1.2
BZX84C5V6
HZ3
5.6
5.2
6.0
5.0
40
400
1.0
1.0
2.0
-2.0
2.5
BZX84C6V2
HZ4
6.2
5.8
6.6
5.0
10
150
1.0
3.0
4.0
0.4
3.7
BZX84C6V8
HZ5
6.8
6.4
7.2
5.0
15
80
1.0
2.0
4.0
1.2
4.5
BZX84C7V5
HZ6
7.5
7.0
7.9
5.0
15
80
1.0
1.0
5.0
2.5
5.3
BZX84C8V2
HZ7
8.2
7.7
8.7
5.0
15
80
1.0
0.7
5.0
3.2
6.2
BZX84C9V1
HZ8
9.1
8.5
9.6
5.0
15
100
1.0
0.5
6.0
3.8
7.0
BZX84C10
HZ9
10
9.4
10.6
5.0
1.0
0.2
7.0
4.5
8.0
BZX84C11
HY1
11
10.4
11.6
5.0
1.0
0.1
8.0
5.4
9.0
BZX84C12
HY2
12
11.4
12.7
5.0
25
150
1.0
0.1
8.0
6.0
10.0
BZX84C13
HY3
13
12.4
14.1
5.0
30
170
1.0
0.1
8.0
7.0
11.0
BZX84C15
HY4
15
13.8
15.6
5.0
30
200
1.0
0.1
10.5
9.2
13.0
BZX84C16
HY5
16
15.3
17.1
5.0
40
200
1.0
0.1
11.2
10.4
14.0
2/7
BZX84CXXX
Rev.H Jan.-2019
电性能参数
Type Number
DATA SHEET
Zener Voltage Range
(Note 2)
Marking
Code
Vz @IZT
IZT
ZZT @IZT
Maximum
Reverse
Current
(Note 2)
ZZK @IZK
IR
VR
Typical
Temperature
Coefficient
@IZT
mV/ºC
Maximum Zener
Impedance (Note 3)
Nom
(V)
Min
(V)
Max
(V)
mA
Ω
Ω
mA
uA
V
Min
Max
BZX84C18
HY6
18
16.8
19.1
5.0
45
225
1.0
0.1
12.6
12.4
16.0
BZX84C20
HY7
21.2
5.0
55
225
1.0
0.1
14.0
14.4
18.0
BZX84C22
HY8
22
20.8
23.3
5.0
55
250
1.0
0.1
15.4
16.4
20.0
BZX84C24
HY9
24
22.8
25.6
5.0
70
250
1.0
0.1
16.8
18.4
22.0
BZX84C27
HYA
27
25.1
28.9
2.0
80
300
0.5
0.1
18.9
21.4
25.3
BZX84C30
HYB
30
28.0
32.0
2.0
80
300
0.5
0.1
21.0
24.4
29.4
BZX84C33
HYC
33
31.0
35.0
2.0
80
325
0.5
0.1
23.1
27.4
33.4
BZX84C36
HYD
36
34.0
38.0
2.0
90
350
0.5
0.1
25.2
30.4
37.4
BZX84C39
HYE
39
37.0
41.0
2.0
130
350
0.5
0.1
27.3
33.4
41.2
BZX84C43
HYF
43
40.0
46.0
2.0
150
375
0.5
0.1
30.1
10.0
12.0
BZX84C47
HYG
47
44.0
50.0
2.0
170
375
0.5
0.1
32.9
10.0
12.0
BZX84C51
HYH
51
48.0
54.0
2.0
180
400
0.5
0.1
35.7
10.0
12.0
Notes:
1.Device mounted on FR-4 PC board with recommended pad layout.
2.Short duration test pulse used to minimize self-heating effect.
3.f = 1KHz.
4.Valid provided the terminals are kept at ambient temperature.
3/7
BZX84CXXX
Rev.H Jan.-2019
电参数曲线图
DATA SHEET
/ Electrical Characteristic Curve
4/7
BZX84CXXX
Rev.H Jan.-2019
外形尺寸图
DATA SHEET
/ Package Dimensions
5/7
BZX84CXXX
Rev.H Jan.-2019
印章说明
DATA SHEET
Marking Instructions
HZB
说明:
H:
为公司代码
ZB:
为型号代码
Note:
H:
Company Code.
ZB:
Product Type.
6/7
BZX84CXXX
Rev.H Jan.-2019
DATA SHEET
回流焊温度曲线图(无铅)
Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 150~180℃,时间 60~90sec;
1.Preheating:150~180℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件
Resistance to Soldering Heat Test Conditions
温度:260±5℃
包装规格
Time:10±1 sec
/ REEL
Package Type
封装形式
使用说明
Temp.:260±5℃
/ Packaging SPEC.
卷盘包装
SOT-23
时间:10±1 sec.
Units 包装数量
Dimension
包装尺寸
3
(unit:mm )
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
3,000
10
30,000
6
180,000
7〞×8
180×120×180
390×385×205
/ Notices
7/7
很抱歉,暂时无法提供与“BZX84C43”相匹配的价格&库存,您可以联系我们找货
