SMPJ5.0 THRU SMPJ100CA
Stand-off Voltage - 5.0 to 100 Volts
Peak Pulse Power: 5000 Watts
TRANSIENT VTAGE SUPPRESSOR
Features
SMP
ƹ Excellent clamping capability
◆ Low dynamic impedance
◆ Solder dip 260 °C max. 10 s, per JESD 22-B106
Mechanical Data
Case : JEDEC SMP Molded plastic body
Terminals : Tin plated leads, solderable per J-STD- 002 and
JESD22-B102
Mounting Position : Any
0D[LPXP5DWLQJV (OHFWULFDO&KDUDFWHULVWLFV
Ratings at TA = 25°C unless otherwise specified
PARAMETER
Peak power dissipation, with a 10/1000us waveform(1)(2 )
Power dissipation, on infinite heat sink at TL=75℃(2)
Peak forward surge current, 8.3 ms single half sine-wave unidirectional only
(3)
Operating junction and storage temperature range
Maximum instantaneous forward voltage at 100A for unidirectional only(4)
Junction to ambient
Junction to lead
Notes:
(1)
(2)
(3)
(4)
(5)
Dimensions in inches and (millimeters)
SYMBOL
UNIT
Max
PPPM
W
5000
PD
W
8.0
IFSM
A
400
TJ,TST G
-55 to +150
VFM
V
3.5
RθJ-A
℃/W
75
RθJ-L
℃/W
15
Non-repetitive current pulse, per Fig. 3 and derated above TA= 25℃per Fig.2.
Mounted on 0.31 x 0.31" (8.0 x 8.0 mm) copper pads to each terminal
Measured on 8.3ms single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum.
VF=3.5V Max for devices of VBR≤220v,and VF=5.0v Max for devices of VBR>220v.
Mounted on minimum recommended pad layout.
DN:T20519A0
http://www.microdiode.com
Rev:2020A0
Page :1
ELECTRICAL CHARACTERISTICS(TA=25°C unless otherwise noted)
Part No.
Peak Power
Dissipation
10/1000μ
sec(W)
Reverse
Stand-Off
Voltage
VRWM(V)
Breakdown
Voltage
VBR (V)
Min @ IT
Breakdown
Voltage
VBR (V)
Max @ IT
Test
Current
IT (mA)
Max
Clamping
Voltage
VC (V)@ IPP
Peak
Pulse
Current
IPP (A)
Reverse
Leakage
IR (μA)
@ VRWM
SMPJ5.0A
SMPJ5.0CA
5000
5.0
6.40
7.00
10
9.20
543.48
1000
SMPJ6.0A
SMPJ6.0CA
5000
6.0
6.67
7.37
10
10.30
485.44
1000
SMPJ6.5A
SMPJ6.5CA
5000
6.5
7.22
7.98
10
11.20
446.43
500
SMPJ7.0A
SMPJ7.0CA
5000
7.0
7.78
8.60
10
12.00
416.67
200
SMPJ7.5A
SMPJ7.5CA
5000
7.5
8.33
9.21
1
12.90
387.60
100
SMPJ8.0A
SMPJ8.0CA
5000
8.0
8.89
9.83
1
13.60
367.65
50
SMPJ8.5A
SMPJ8.5CA
5000
8.5
9.44
10.40
1
14.40
347.22
25
SMPJ9.0A
SMPJ9.0CA
5000
9.0
10.00
11.10
1
15.40
324.68
10
SMPJ10A
SMPJ10CA
5000
10.0
11.10
12.30
1
17.00
294.12
5
SMPJ11A
SMPJ11CA
5000
11.0
12.20
13.50
1
18.20
274.73
5
SMPJ12A
SMPJ12CA
5000
12.0
13.30
14.70
1
19.90
251.26
5
SMPJ13A
SMPJ13CA
5000
13.0
14.40
15.90
1
21.50
232.56
5
SMPJ14A
SMPJ14CA
5000
14.0
15.60
17.20
1
23.20
215.52
5
SMPJ15A
SMPJ15CA
5000
15.0
16.70
18.50
1
24.40
204.92
5
SMPJ16A
SMPJ16CA
5000
16.0
17.80
19.70
1
26.00
192.31
5
SMPJ17A
SMPJ17CA
5000
17.0
18.90
20.90
1
27.60
181.16
5
SMPJ18A
SMPJ18CA
5000
18.0
20.00
22.10
1
29.20
171.23
5
SMPJ19A
SMPJ19CA
5000
19.0
21.10
23.30
1
30.80
162.44
5
SMPJ20A
SMPJ20CA
5000
20.0
22.20
24.50
1
32.40
154.32
5
SMPJ22A
SMPJ22CA
5000
22.0
24.40
26.90
1
35.50
140.85
5
SMPJ24A
SMPJ24CA
5000
24.0
26.70
29.50
1
38.90
128.53
5
SMPJ26A
SMPJ26CA
5000
26.0
28.90
31.90
1
42.10
118.76
5
SMPJ28A
SMPJ28CA
5000
28.0
31.10
34.40
1
45.40
110.13
5
SMPJ30A
SMPJ30CA
5000
30.0
33.30
36.80
1
48.40
103.31
5
SMPJ33A
SMPJ33CA
5000
33.0
36.70
40.60
1
53.30
93.81
5
SMPJ36A
SMPJ36CA
5000
36.0
40.00
44.20
1
58.10
86.06
5
SMPJ40A
SMPJ40CA
5000
40.0
44.40
49.10
1
64.50
77.52
5
SMPJ43A
SMPJ43CA
5000
43.0
47.80
52.80
1
69.40
72.05
5
SMPJ45A
SMPJ45CA
5000
45.0
50.00
55.30
1
72.70
68.78
5
SMPJ48A
SMPJ48CA
5000
48.0
53.30
58.90
1
77.40
64.60
5
SMPJ51A
SMPJ51CA
5000
51.0
56.70
62.70
1
82.40
60.68
5
SMPJ54A
SMPJ54CA
5000
54.0
60.00
66.30
1
87.10
57.41
5
SMPJ58A
SMPJ58CA
5000
58.0
64.40
71.20
1
93.60
53.42
5
SMPJ60A
SMPJ60CA
5000
60.0
66.70
73.70
1
96.80
51.65
5
SMPJ64A
SMPJ64CA
5000
64.0
71.10
78.60
1
103.0
48.54
5
SMPJ70A
SMPJ70CA
5000
70.0
77.80
86.00
1
113.0
44.25
5
SMPJ75A
SMPJ75CA
5000
75.0
83.30
92.10
1
121.0
41.32
5
SMPJ78A
SMPJ78CA
5000
78.0
86.70
95.80
1
126.0
39.68
5
SMPJ80A
SMPJ80CA
5000
80.0
88.80
97.60
1
129.6
38.58
5
SMPJ85A
SMPJ85CA
5000
85.0
94.40
104.00
1
137.0
36.50
5
SMPJ90A
SMPJ90CA
5000
90.0
100.00
111.00
1
146.0
34.25
5
SMPJ100A
SMPJ100CA
5000
100.0
111.00
123.00
1
162.0
30.86
5
Rev:2020A0
Page :2
Typical Characteristics
100
100
Non-Repetitive Pulse
Waveform shown in Fige.3
TA=25℃
PPP or IPP(%)
75
PPPM(KW)
10
50
1.0
25
0.1
0.31×0.31"(8.0×8.0mm)
Copper Pad Areas
0.1μs
1μs
10μs
100μs
td(μs)
1.0ms
10ms
FIG1:Peak Pulse Power Rating Curve
150
75
50
100
125
TJ(℃)
150
175
200
FIG2: Pulse Power or Current vs. Initial
Junction Temperature
100
tr=10μs
TJ=25℃
Pulse Width(td) is defined as
the Point where the Peak
Current Decays to 50% of IPPM
Peak Value
IPPM
IPPM(%)
25
Rth(℃/W)
100
Half Value - IPP
2
IPPM
50
10
1
10/1000μs Waveform as
Defined by R.E.A.
td
2.0
3.0
4.0
T(ms)
0.1
0.001
0.01
0.1
1
tp(s)
10
100
1000
FIG4:Typical Transient Thermal Impedance
FIG3: Pulse Waveform
10.5
TJ=TJMax.
8.3ms Single Half Sine-Wave
9.0
400
8.0
PD(W)
IFSM(A)
7.5
6.0
4.5
3.0
1.5
Number of Cycles
FIG5: Maximum Non-Repetitive Surge Current
100
50
75
100
125
150
175
200
TL(℃)
FIG6:Steady State Power Dissipation
Rev:2020A0
Page :3
0RXQWLQJ3DG/D\RXW(unit:mm)
B
A
C
Dim
Millimeters
A
5.40
B
5.90
C
2.10
D
1.90
E
4.00
D
E
Note: based on the center of the small pad,Maximum Displacement 0.3mm。
Important Notice and Disclaimer
Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and
specifications at any time without notice. Customers should obtain and confirm the latest product information and
specifications before final design,purchase or use.
Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its
products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application
assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with
products which are purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode
Electronics (Jiangsu).
Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support
devices or systems without express written approval of Microdiode Electronics (Jiangsu).
Rev:2020A0
Page :4
很抱歉,暂时无法提供与“SMPJ11CA”相匹配的价格&库存,您可以联系我们找货
