5KP5.0 THRU 5KP110A
Breakdown Voltage:5.0-110 Volts
Peak Pulse Power:5000 Watts
GLASS PASSIVATED JUNCTION TRANSIENT VOLTAGE SUPPRESSOR
Features
R-6
5000w peak pulse power capability
Excellent clamping capability
Low incremental surge resistance
1.0 (25.4)
MIN.
Fast response time:typically less than 1.0ps from 0v to VBR for
0.360 (9.1)
0.340(8.6)
unidirectional and 5.0ns ror bidirectional types.
DIA.
High temperature soldering guaranteed:
265°C/10S/9.5mm lead length at 5 lbs tension
0.360(9.1)
0.340(8.6)
1.0 (25.4)
MIN.
Mechanical Data
0.052 (1.3)
0.048 (1.2)
Case : JEDEC R-6 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.072 ounce, 2.05 grams
DIA.
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS
VALUE
UNITS
Peak power dissipation
sipation
PPPM
Minimum 5000
Watts
Peak pulse reverse curr
current
IPPM
See Table 1
Amps
Steady state power dissapation (Note 2)
PM(AV)
8.0
Watts
Peak forward sur
surge current
IFSM
400
Amps
VF
3.5
Volts
TSTG,TJ
-55 to + 175
C
Maximum instantaneous forward voltage at 100A
for unidirectional only
(Note 3)
Operating junction and storage temperature range
Note:
1.10/1000µs waveform non-repetitive current pulse,per Fig.3 and derated above Ta=25°C per Fig.2
2.TL=75°C,lead lengths 9.5mm,Mounted on copper pad atea of (20x20mm)Fig.5
3.Measured on 8.3ms single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum.
DN:T20526A0
http://www.microdiode.com
Rev:2020A0
Page :1
5KP5.0 THRU 5KP110A
ELECTRICAL CHARACTERISTICS (at TA=25 C unless otherwise noted)
Device Type
5KP5.0
5KP5.0A
5KP6.0
5KP6.0A
5KP6.5
5KP6.5A
5KP7.0
5KP7.0A
5KP7.5
5KP7.5A
5KP8.0
5KP8.0A
5KP8.5
5KP8.5A
5KP9.0
5KP9.0A
5KP10
5KP10A
5KP11
5KP11A
5KP12
5KP12A
5KP13
5KP13A
5KP14
5KP14A
5KP15
5KP15A
5KP16
5KP16A
5KP17
5KP17A
5KP18
5KP18A
5KP20
5KP20A
5KP22
5KP22A
5KP24
5KP24A
5KP26
5KP26A
5KP28
5KP28A
5KP30
5KP30A
5KP33
5KP33A
Maximum
Breakdown Voltage
Maximum
Reverse
V(BR)
Test Stand-off
Peak Pulse
Leakage
(Volts)(NOTES 1)
Current Voltage
Reverse Current
VWM
atVWM
IT(mA)
IPPM(NOTE2)
(Volts) ID(NOTE3)(µA)
MIN
MAX
(Amps)
6.40
6.40
6.67
6.67
7.22
7.22
7.78
7.78
8.33
8.33
8.89
8.89
9.44
9.44
10.00
10.00
11.10
11.10
12.20
12.20
13.30
13.30
14.40
14.40
15.60
15.60
16.70
16.70
17.80
17.80
18.90
18.90
20.00
20.00
22.20
22.20
24.40
24.40
26.70
26.70
28.90
28.90
31.10
31.10
33.30
33.30
36.70
36.70
7.30
7.00
8.15
7.37
8.82
7.98
9.51
8.60
10.20
9.21
10.90
9.83
11.50
10.40
12.20
11.10
13.60
12.30
14.90
13.50
16.30
14.70
17.60
15.90
19.10
17.20
20.40
18.50
21.80
19.70
23.10
20.90
24.40
22.10
27.10
24.50
29.80
26.90
32.60
29.50
35.30
31.90
38.00
34.40
40.70
36.80
44.90
40.60
50
50
50
50
50
50
50
50
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5.0
5.0
6.0
6.0
6.5
6.5
7.0
7.0
7.5
7.5
8.0
8.0
8.5
8.5
9.0
9.0
10.00
10.00
11.00
11.00
12.00
12.00
13.00
13.00
14.00
14.00
15.00
15.00
16.00
16.00
17.00
17.00
18.00
18.00
20.00
20.00
22.00
22.00
24.00
24.00
26.00
26.00
28.00
28.00
30.00
30.00
33.00
33.00
5000
5000
5000
5000
2000
2000
1000
1000
250
250
150
150
50
50
15
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
Maximum
Clamping
Voltage at
IPPM
Vc(Volts)
Maximum
Temperature
Coefficient
of V(BR)
(%/ C)
9.6
9.2
11.4
10.3
12.3
11.2
13.3
12.0
14.3
12.9
15.0
13.6
15.9
14.4
16.9
15.4
18.8
17.0
20.1
18.2
22.0
19.9
23.8
21.5
25.8
23.2
26.9
24.4
28.8
26.0
30.5
27.6
32.2
29.2
35.8
32.4
39.4
35.5
43.0
38.9
46.6
42.1
50.1
45.4
53.5
48.4
59.0
53.3
0.057
0.057
0.061
0.061
0.065
0.065
0.068
0.068
0.073
0.073
0.075
0.075
0.078
0.078
0.081
0.081
0.084
0.084
0.086
0.086
0.088
0.088
0.090
0.090
0.092
0.092
0.094
0.094
0.096
0.096
0.097
0.097
0.098
0.098
0.099
0.099
0.100
0.100
0.101
0.101
0.101
0.101
0.102
0.102
0.103
0.103
0.104
0.104
522
544
439
486
407
447
377
417
350
388
334
368
315
348
296
325
266
295
249
275
228
252
210
233
194
216
186
205
174
193
164
181
155
172
140
154
127
141
116
129
107
119
100
110
93.6
103
84.8
93.9
Rev:2020A0
Page :2
5KP5.0 THRU 5KP110A
Device Type
Breakdown Voltage
V(BR)
(Volts)(NOTES 1)
Test
Current
IT(mA)
Stand-off
Voltage
VWM
(Volts)
Maximum
Reverse
Leakage
atVWM
ID(NOTE3)(µA)
Maximum
Peak Pulse
Reverse Current
IPPM(NOTE2)
(Amps)
Maximum
Clamping
Voltage at
IPPM
Vc(Volts)
Maximum
Temperature
Coefficient
of V(BR)
(%/ C)
MIN
MAX
5KP36
40.00
48.90
5.0
36.00
10
64.3
77.8
0.104
5KP36A
40.00
44.20
5.0
36.00
10
58.1
86.1
0.104
5KP40
44.40
54.30
5.0
40.00
10
71.4
70.1
0.105
5KP40A
44.40
49.10
5.0
40.00
10
64.5
77.6
0.105
5KP43
47.80
58.40
5.0
43.00
10
76.7
65.2
0.105
5KP43A
47.80
52.80
5.0
43.00
10
69.4
72.1
0.105
5KP45
50.00
61.10
5.0
45.00
10
80.3
62.3
0.106
5KP45A
50.00
55.30
5.0
45.00
10
72.7
68.8
0.106
5KP48
53.30
65.20
5.0
48.00
10
85.8
58.5
0.106
5KP48A
53.30
58.90
5.0
48.00
10
77.4
64.7
0.106
5KP51
56.70
69.30
5.0
51.00
10
91.1
54.9
0.107
5KP51A
56.70
62.70
5.0
51.00
10
82.4
60.7
0.107
5KP54
60.00
73.30
5.0
54.00
10
96.3
52.0
0.107
5KP54A
60.00
66.30
5.0
54.00
10
87.1
57.5
0.107
5KP58
64.40
78.70
5.0
58.00
10
103.0
48.6
0.107
5KP58A
64.40
71.20
5.0
58.00
10
93.6
53.5
0.107
5KP60
66.70
81.50
5.0
60.00
10
107.0
46.8
0.108
5KP60A
66.70
73.70
5.0
60.00
10
96.8
51.7
0.108
5KP64
71.10
86.90
5.0
64.00
10
114.0
43.9
0.108
5KP64A
71.10
78.60
5.0
64.00
10
103.0
48.6
0.108
5KP70
77.80
95.10
5.0
70.00
10
125.0
40.0
0.108
5KP70A
77.80
86.00
5.0
70.00
10
113.0
44.3
0.108
5KP75
83.30
102.00
5.0
75.00
10
134.0
37.4
0.108
5KP75A
83.30
92.10
5.0
75.00
10
121.0
41.4
0.108
5KP78
86.70
106.00
5.0
78.00
10
139.0
36.0
0.108
5KP78A
86.70
95.80
5.0
78.00
10
126.0
39.7
0.108
5KP85
94.40
115.00
5.0
85.00
10
151.0
33.2
0.108
5KP85A
94.40
104.00
5.0
85.00
10
137.0
36.5
0.108
5KP90
100.00
122.00
5.0
90.00
10
160.0
31.3
0.110
5KP90A
100.00
111.00
5.0
90.00
10
146.0
34.3
0.110
5KP100
111.00
136.00
5.0
100.00
10
179.0
28.0
0.110
5KP100A
111.00
123.00
5.0
100.00
10
162.0
30.9
0.110
5KP110
122.00
149.00
5.0
110.00
10
196.0
25.6
0.112
5KP110A
122.00
135.00
5.0
110.00
10
177.0
28.3
0.112
NOTES:
1. V(BR) measured after IT applied for 300µs IT=square wave pulse or equivalent
2. Surge current waveform per Fig.3 and derate per Fig.2
3. All items and symbols are consistent with ANSI/IEEE C62.35
Rev:2020A0
Page :2
5KP5.0 THRU 5KP110A
PppM,PEAK PULSE POWER,kw
10
NON-REPETITIVE
PULSE WAVEFORM
SHOWN in FIG.3
TA=25 C
1.0
0.1
0.1µs
1.0µs
10µs
100µs
1.0ms
FIG. 2-PULSE DERATING CURVE
PEAK PULSE POWER(PppM)or CURRENT(IppM)
DERATING IN PERCENTAGE,%
FIG. 1-PEAK PULSE POWER RATING CURVE
100
10ms
td,PULSE WIDTH,sec.
100
75
50
25
50
75
100
125
150
175
200
TA, AMBIENT TEMPERATURE,( C)
FIG. 4-TYPICAL JUNCTIONAL CAPACITANCE
FIG.3-PULSE WAVEFORM
100,000
f=1.0MHz
Vsig=50mVp-p
TJ=25 C
PULSE WIDTH (td) is DEFINED
as the POINT WHERE the PEAK
CURRENT DECAYS to 50% of IppM
tr=10µsec
CJ,JINCTION CAPACITANCE,pF
IppM,PEAK PULSE CURRENT,%
150
PEAK VALUE IppM
100
HALF VALUE IPPM
2
10/1000µsec WAVEFORM
as DFINED by R.E.A.
50
MEASURED at
ZERO BIAS
10,000
1,000
MEASURED at
ATAND-OFF
VOLTAGE,VWM
td
2.0
3.0
4.0
t,TIME,ms
100
1
10
100
200
V(BR),BREAKDOWN VOLTAGE,VOLTS
FIG.5-STEADY STATE POWER DERATING CURVE
60Hz RESISTIVE
OR INDUCTIVE LOAD
IFSM,PEAK FORWARD SURAGE
CURRENT AMPERES
PM(AV),STEADY STATE POWER
DISSIPATION,WATTS
8
6
L=0.375” (9.5mm)
lLEAD LENGTHS
4
2
1.6 1.6 0.040”(40 40 1mm)
COPPER HEAT SINKS
50
75
100
125
150
TL,LEAD TEMPERATURE, C
175
FIG.6-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
400
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
350
300
250
200
150
100
1.0
10
100
200
NUMBER OF CYCLES AT 60Hz
The curve above is for reference only.
Rev:2020A0
Page :2
很抱歉,暂时无法提供与“5KP110A”相匹配的价格&库存,您可以联系我们找货
