Wuxi I-CORE Electronics Co., Ltd.
Tab: 835-12
rev:B3
Number:AiP74HC/HCT244-AX-LJ-A020EN
or
e
AiP74HC/HCT244
Octal Buffer/Line Driver; 3-state
Specification
i-c
Product
Specification Revision History:
Version
Date
2019-06-A1
2019-06
Description
New
Address:Building B4,NO.777,Jianzhu Road,Binhu Distrct,Wuxi City,Jiangsu Province
http://www.i-core. cn
P.C.:214072
1/ 16
VER:2019-06-A1
Tab: 835-12
rev:B3
1、General Description
The AiP74HC/HCT244 is an 8-bit buffer/line driver with 3-state outputs. The device can be used as two
4-bit buffers or one 8-bit buffer. The device features two output enables (1OE and 2OE), each controlling
four of the 3-state outputs. A HIGH on nOE causes the outputs to assume a high-impedance OFF-state.
Inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages
in excess of VCC.
i-c
or
e
Features:
Input levels:
For AiP74HC244: CMOS level
For AiP74HCT244: TTL level
Octal bus interface
Non-inverting 3-state outputs
Multiple package options
Specified from -40℃ to +85℃
Packaging information: DIP20/SOP20/TSSOP20
P.C.:214072
2/ 16
VER:2019-06-A1
Tab: 835-12
rev:B3
Ordering Information:
Tube packing specifications:
Packaging
form
Type number
Marking
code
Tube
quantity
Boxed
tube
quantity
Boxed
quantity
Packing
box
number
Packing
quantity
DIP20
74HC244
18
PCS/tube
40
tube/box
720
PCS/box
10
box/pack
7200
PCS/pack
AiP74HCT244DA.TB
DIP20
74HCT244
18
PCS/tube
40
tube/box
720
PCS/box
10
box/pack
7200
PCS/pack
AiP74HC244SA.TB
SOP20
74HC244
80
tube/box
2800
PCS/box
10
box/pack
28000
PCS/pack
or
35
PCS/tube
SOP20
74HCT244
35
PCS/tube
80
tube/box
2800
PCS/box
10
box/pack
28000
PCS/pack
AiP74HC244TA.TB
TSSOP20
74HC244
70
PCS/tube
200
tube/box
14000
PCS/box
10
box/pack
140000
PCS/pack
70
PCS/tube
200
tube/box
14000
PCS/box
10
box/pack
140000
PCS/pack
i-c
AiP74HCT244SA.TB
AiP74HCT244TA.TB
TSSOP20
74HCT244
Reel packing specifications:
Packaging Marking
Type number
form
code
Dimensions of
plastic enclosure:
26.3mm×6.4mm
Pin spacing:
2.54mm
Dimensions of
plastic enclosure:
26.3mm×6.4mm
Pin spacing:
2.54mm
Dimensions of
plastic enclosure:
12.8mm×7.5mm
Pin spacing:
1.27mm
Dimensions of
plastic enclosure:
12.8mm×7.5mm
Pin spacing:
1.27mm
Dimensions of
plastic enclosure:
6.5mm×4.4mm
Pin spacing:
0.65mm
Dimensions of
plastic enclosure:
6.5mm×4.4mm
Pin spacing:
0.65mm
e
AiP74HC244DA.TB
Notes
Reel
quantity
AiP74HC244SA.TR
SOP20
74HC244
1000PCS/reel
AiP74HCT244SA.TR
SOP20
74HCT244
1000PCS/reel
AiP74HC244TA.TR
TSSOP20
74HC244
2500PCS/reel
AiP74HCT244TA.TR
TSSOP20
74HCT244
2500PCS/reel
Note: If the physical information is inconsistent with
product.
Boxed reel
quantity
Packing
quantity
1000PCS/box
8000PCS/pack
Notes
Dimensions of plastic
enclosure: 12.8mm×7.5mm
Pin spacing:1.27mm
1000PCS/box 8000PCS/pack enclosure: 12.8mm×7.5mm
Pin spacing:1.27mm
5000PCS/box 40000PCS/pack enclosure: 6.5mm×4.4mm
Pin spacing:0.65mm
Pin spacing:0.65mm
the ordering information, please refer to the actual
P.C.:214072
3/ 16
VER:2019-06-A1
Tab: 835-12
rev:B3
2、Block Diagram And Pin Description
2.1、Block Diagram
i-c
or
e
Figure 1. Logic symbol
Figure 2. IEC logic symbol
Figure 3. Functional diagram
P.C.:214072
4/ 16
VER:2019-06-A1
Tab: 835-12
rev:B3
2.2、Pin Configurations
2.3、Pin Description
Pin No.
Pin Name
Description
1OE
output enable input (active LOW)
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
1A0
2Y0
1A1
2Y1
1A2
2Y2
1A3
2Y3
GND
2A3
1Y3
2A2
1Y2
2A1
1Y1
2A0
1Y0
19
2OE
VCC
supply voltage
e
1
i-c
or
data input
bus output
data input
bus output
data input
bus output
data input
bus output
ground (0V)
data input
bus output
data input
bus output
data input
bus output
data input
bus output
2.4、Function Table
Input
nOE
nAn
Output
nYn
L
L
L
L
H
H
H
X
Z
Note: H=HIGH voltage level; L=LOW voltage level; X=don’t care; Z=high-impedance OFF-state.
P.C.:214072
5/ 16
VER:2019-06-A1
Tab: 835-12
rev:B3
3、Electrical Parameter
3.1、Absolute Maximum Ratings
(Voltages are referenced to GND(ground=0V), unless otherwise specified.)
Unit
V
mA
mA
mA
mA
mA
or
e
Parameter
Symbol
Conditions
Min.
Max.
supply voltage
VCC
-0.5
+7.0
input clamping
IIK
VI < -0.5V or VI > VCC+0.5V
±20
current
output clamping
IOK
VO < -0.5V or VO > VCC+0.5V
±20
current
output current
IO
-0.5V < VO < VCC+0.5V
±35
supply current
ICC
70
ground current
IGND
-70
storage
Tstg
-65
+150
temperature
total power
500
Ptot
dissipation
DIP
245
Soldering
10s
TL
temperature
SOP
250
Note:
[1] For DIP20 packages: above 70℃ the value of Ptot derates linearly with 12mW/K.
[2] For SOP20 packages: above 70℃ the value of Ptot derates linearly with 8mW/K.
[3] For (T)SSOP20 packages: above 60℃ the value of Ptot derates linearly with 5.5mW/K.
mW
3.2、Recommended Operating Conditions
Symbol
supply voltage
input voltage
output voltage
VCC
VI
VO
input transition
rise and fall rate
Δt/ΔV
ambient
temperature
Tamb
Conditions
AiP74HC244
VCC=2.0V
VCC=4.5V
VCC=6.0V
i-c
Parameter
supply voltage
input voltage
output voltage
input transition
rise and fall rate
ambient
temperature
VCC
VI
VO
AiP74HCT244
Min.
Typ.
Max.
Unit
2.0
1.67
6.0
VCC
VCC
625
139
83
V
V
V
ns/V
ns/V
ns/V
-40
+85
4.5
5.5
VCC
VCC
V
V
V
Δt/ΔV
VCC=4.5V
1.67
139
ns/V
Tamb
-40
+85
P.C.:214072
6/ 16
VER:2019-06-A1
Tab: 835-12
rev:B3
Max.
Unit
0.5
1.35
1.8
0.1
0.1
0.1
0.26
0.26
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
±0.1
uA
±0.5
uA
8.0
uA
pF
V
0.8
V
0.1
0.26
V
V
V
V
±0.1
uA
±0.5
uA
8.0
uA
252
uA
pF
i-c
or
e
3.3、Electrical Characteristics
3.3.1、DC Characteristics 1
(Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.)
Parameter
Symbol
Conditions
Min. Typ.
AiP74HC244
VCC=2.0V
1.5
1.2
HIGH-level
VCC=4.5V
3.15
2.4
VIH
input voltage
VCC=6.0V
4.2
3.2
VCC=2.0V
0.8
LOW-level
VIL
VCC=4.5V
2.1
input voltage
VCC=6.0V
2.8
IO=-20uA; VCC=2.0V
1.9
2.0
IO=-20uA; VCC=4.5V
4.4
4.5
HIGH-level
VI = VIH or VIL
IO=-20uA; VCC=6.0V
5.9
6.0
VOH
output voltage
IO=-6.0mA; VCC=4.5V
3.98
4.32
IO=-7.8mA; VCC=6.0V
5.48
5.81
IO=20uA; VCC=2.0V
IO=20uA; VCC=4.5V
LOW-level
VI = VIH or VIL
IO=20uA; VCC=6.0V
VOL
output voltage
IO=6.0mA; VCC=4.5V
0.15
IO=7.8mA; VCC=6.0V
0.16
input leakage
VI=VCC or GND;
II
current
VCC=6.0V
OFF-state
VI=VIH or VIL; VCC=6.0V;
IOZ
output current
VO=VCC or GND
supply current
ICC
VI=VCC or GND; IO=0A; VCC=6.0V
input
CI
3.5
capacitance
AiP74HCT244
HIGH-level
VIH
VCC=4.5V to 5.5V
2.0
1.6
input voltage
LOW-level
VIL
VCC=4.5V to 5.5V
1.2
input voltage
IO=-20uA
4.4
4.5
HIGH-level
VI = VIH or VIL;
VOH
output voltage
VCC=4.5V
IO=-6.0mA
3.98
4.32
I
=20uA
LOW-level
VI = VIH or VIL;
O
VOL
output voltage
VCC=4.5V
IO=6.0mA
0.16
input leakage
VI=VCC or GND;
II
current
VCC=5.5V
OFF-state
VI=VIH or VIL; VCC=5.5V;
IOZ
output current
VO=VCC or GND
supply current
ICC
VI=VCC or GND; IO=0A; VCC=5.5V
per input pin; VI=VCC-2.1V;
additional
other inputs at VCC or GND;
70
ΔICC
supply current
VCC=4.5V to 5.5V; IO=0A
input
CI
3.5
capacitance
P.C.:214072
7/ 16
VER:2019-06-A1
Tab: 835-12
rev:B3
3.3.2、DC Characteristics 2
(Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.)
Symbol
Min.
Typ.
Max.
Unit
1.5
3.15
4.2
1.9
4.4
5.9
3.84
5.34
0.5
1.35
1.8
0.1
0.1
0.1
0.33
0.33
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
V
±1.0
uA
±5.0
uA
ICC
Conditions
AiP74HC244
VCC=2.0V
VCC=4.5V
VCC=6.0V
VCC=2.0V
VCC=4.5V
VCC=6.0V
IO=-20uA; VCC=2.0V
IO=-20uA; VCC=4.5V
VI = VIH or VIL
IO=-20uA; VCC=6.0V
IO=-6.0mA; VCC=4.5V
IO=-7.8mA; VCC=6.0V
IO=20uA; VCC=2.0V
IO=20uA; VCC=4.5V
VI = VIH or VIL
IO=20uA; VCC=6.0V
IO=6.0mA; VCC=4.5V
IO=7.8mA; VCC=6.0V
VI=VCC or GND;
VCC=6.0V
VO=VCC or GND
80
uA
CI
pF
VIH
LOW-level
input voltage
VIL
HIGH-level
output voltage
VOH
LOW-level
output voltage
VOL
or
HIGH-level
input voltage
e
Parameter
II
IOZ
AiP74HCT244
i-c
input leakage
current
OFF-state
output current
supply current
input
capacitance
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output voltage
LOW-level
output voltage
input leakage
current
OFF-state
output current
supply current
VIH
VCC=4.5V to 5.5V
2.0
V
VIL
VCC=4.5V to 5.5V
0.8
V
4.4
3.84
0.1
0.33
V
V
V
V
±1.0
uA
±5.0
uA
80
uA
315
uA
pF
VOH
VOL
II
IOZ
ICC
additional
supply current
ΔICC
input
capacitance
CI
IO=-20uA
IO=-6.0mA
IO=20uA
VI = VIH or VIL;
VCC=4.5V
IO=6.0mA
VI=VCC or GND;
VCC=5.5V
VO=VCC or GND
VI = VIH or VIL;
VCC=4.5V
P.C.:214072
8/ 16
VER:2019-06-A1
Tab: 835-12
rev:B3
3.3.3、AC Characteristics 1
Parameter
nAn to nYn
propagation
delay
Symbol
tpd
see Figure 5
ten
see Figure 6
nOE to nYn
disable time
tdis
see Figure 6
transition time
tt
see Figure 5
power
dissipation
capacitance
CPD
nAn to nYn
propagation
delay
tpd
nOE to nYn
enable time
ten
nOE to nYn
enable time
Typ.
Max.
Unit
30
11
9
9
36
13
10
39
14
11
14
5
4
110
22
19
150
30
26
150
30
26
60
12
10
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
35
pF
VCC=4.5V
13
22
ns
VCC=5.0V; CL=15pF
11
ns
15
30
ns
15
25
ns
5
12
ns
35
pF
per buffer; VI=GND to VCC
or
Min.
e
Conditions
AiP74HC244
VCC=2.0V
VCC=4.5V
VCC=5.0V; CL=15pF
VCC=6.0V
VCC=2.0V
VCC=4.5V
VCC=6.0V
VCC=2.0V
VCC=4.5V
VCC=6.0V
VCC=2.0V
VCC=4.5V
VCC=6.0V
AiP74HCT244
see Figure 5
VCC=4.5V; see Figure 6
i-c
nOE to nYn
tdis
disable time
transition time
tt
VCC=4.5V; see Figure 5
power
dissipation
CPD
per buffer; VI=GND to VCC-1.5V
capacitance
Note:
[1] tpd is the same as tPLH and tPHL.
[2] ten is the same as tPZL and tPZH.
[3] tdis is the same as tPLZ and tPHZ.
[4] tt is the same as tTHL and tTLH.
[5] CPD is used to determine the dynamic power dissipation (PD in uW).
PD=CPD×VCC2×fi×N+∑(CL×VCC2×fo) where:
fi=input frequency in MHz;
fo=output frequency in MHz;
CL=output load capacitance in pF;
VCC=supply voltage in V;
N=number of inputs switching;
∑(CL×VCC2×fo)=sum of outputs.
P.C.:214072
9/ 16
VER:2019-06-A1
Tab: 835-12
rev:B3
3.3.4、AC Characteristics 2
Parameter
nAn to nYn
propagation
delay
Symbol
tpd
see Figure 5
ten
see Figure 6
nOE to nYn
disable time
tdis
see Figure 6
transition time
tt
see Figure 5
power
dissipation
capacitance
CPD
nAn to nYn
propagation
delay
tpd
nOE to nYn
enable time
ten
nOE to nYn
enable time
Typ.
Max.
Unit
145
28
24
190
38
33
190
38
33
75
15
13
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
ns
pF
VCC=4.5V
22
ns
VCC=5.0V; CL=15pF
ns
30
ns
25
ns
12
ns
pF
or
Min.
e
Conditions
AiP74HC244
VCC=2.0V
VCC=4.5V
VCC=5.0V; CL=15pF
VCC=6.0V
VCC=2.0V
VCC=4.5V
VCC=6.0V
VCC=2.0V
VCC=4.5V
VCC=6.0V
VCC=2.0V
VCC=4.5V
VCC=6.0V
AiP74HCT244
see Figure 5
i-c
nOE to nYn
tdis
disable time
transition time
tt
power
dissipation
CPD
capacitance
Note:
P.C.:214072
10/ 16
VER:2019-06-A1
Tab: 835-12
rev:B3
4、Testing Circuit
or
e
4.1、AC Testing Circuit
Figure 4. Test circuit for measuring switching times
i-c
Definitions for test circuit:
RL=Load resistance.
CL=Load capacitance including jig and probe capacitance.
RT=Termination resistance should be equal to the output impedance Zo of the pulse generator.
S1=Test selection switch.
4.2、AC Testing Waveforms
Figure 5. Input (nAn) to output (nYn) propagation delays and output transition times
P.C.:214072
11/ 16
VER:2019-06-A1
rev:B3
e
Tab: 835-12
Figure 6. 3-state enable and disable times
or
4.3、Measurement Points
Input
Type
Output
VM
0.5×VCC
1.3V
AiP74HC244
AiP74HCT244
VM
0.5×VCC
1.3V
VX
0.1×VCC
0.1×VCC
VY
0.9×VCC
0.9×VCC
4.4、Test Data
Input
i-c
Type
Load
AiP74HC244
AiP74HCT244
VI
tr , tf
CL
RL
VCC
3V
6ns
6ns
15pF, 50pF
15pF, 50pF
1kΩ
1kΩ
P.C.:214072
S1 position
tPHL,
tPZH,
tPZL,
tPLH
tPHZ
tPLZ
open
open
GND
GND
VCC
VCC
12/ 16
VER:2019-06-A1
Tab: 835-12
rev:B3
5、Package Information
i-c
or
e
5.1、DIP20
P.C.:214072
13/ 16
VER:2019-06-A1
Tab: 835-12
rev:B3
i-c
or
e
5.2、SOP20
P.C.:214072
14/ 16
VER:2019-06-A1
Tab: 835-12
rev:B3
i-c
or
e
5.3、TSSOP20
P.C.:214072
15/ 16
VER:2019-06-A1
Tab: 835-12
rev:B3
6、Statements And Notes
6.1、The name and content of Hazardous substances or Elements in the product
Part name
Lead
and
lead
compou
nds
Mercur
y and
mercur
y
compo
unds
Cadm
ium
and
cadmi
um
comp
ounds
Hexaval
ent
chromiu
m
compoun
ds
Polybro
minated
biphenyl
s
Polybro
minate
d
biphen
yl
ethers
Dibutyl
phthala
te
Butylbe
nzyl
phthala
te
Di-2-et
hylhex
yl
phthala
te
Diisobu
tyl
phthala
te
Plastic resin
Chip
The lead
Plastic sheet
installed
e
Lead frame
○:Indicates that the content of hazardous substances or elements in the detection limit
of the following the SJ/T11363-2006 standard。
×:Indicates that the content of hazardous substances or elements exceeding the SJ/T11363-2006
Standard limit requirements。
or
explanation
6.2、Notion
Recommended carefully reading this information before the use of this product;
The information in this document are subject to change without notice;
This information is using to the reference only, the company is not responsible for any loss;
i-c
The company is not responsible for the any infringement of the third party patents or other rights of
the responsibility.
P.C.:214072
16/ 16
VER:2019-06-A1
