PL9509
PL9509
    INRCORE
    非标准
    固定电感器 Nonstandard 15µH ±20% 1.1A 82mΩ
PL9509 数据手册
SMT POWER INDUCTORS Shielded Drum Core - PL95XX Series Ruggedized Height: 0.122 inches (3.1mm) Max Footprint: 0.256 inches x 0.256 inches (6.5mm x 6.5mm) Max Inductance Range: 2.15µH to 85.39µH Current Rating: up to 2.60A Moisture Sensitivity Level: 1 Electrical Specifications @ 25 °C — Operating Temperature - 5 5 °C to +130 °C DCR (mΩ ) Irated 2 Saturation 3 Inductance Inductance (µH TYP) (A) TYP 15.3 24.9 49.9 54 72 82 102 119 146 183 210 230 305 351 419 520 @0ADC (A) @25°C Heating 4 Current 3.45 3.31 2.84 2.70 2.37 2.19 2.01 1.76 1.65 1.44 1.33 1.26 1.08 0.97 0.96 0.86 0.81 0.75 0.66 *Inductance at 0ADC tolerance on indicated part numbers is ±30%; tolerance is ±20% on all other parts. Optional Tape & Reel packaging can be ordered by adding a "T" suffix to the part number (i.e. PL9501 becomes PL9501T). Notes from Tables 4. The heating current is the DC current, which causes the temperature of the part to increase by approximately 40°C. This current is 1. Temperature of the component (ambient plus temperature 5. etermined by extending the terminals of the component with 30mm rise) must be within specified operating temperature range. length 28 gauge buss wires and applying the current to the device for 2. The rated current as listed is either the saturation current or 30 minutes. The temperature is measured by placing the thermo-couple the heating current depending on which value is lower. between the winding and the shield. 3. The saturation current is the current which causes the 6. In high volt*time applications, additional heating in the component can inductance to drop to 75% of its initial inductance at zero occur due to core losses in the inductor which may necessitate derating bias. This current is determined by placing the component at the current in order to limit the temperature rise of the compo-nent. In room ambient (25°C), and applying a short duration pulse order to determine the approximate total loss (or temperature rise) for a current (to eliminate given application, both copper losses and core losses should be taken into self-heating effects) to the component. account. 1 www.inrcore.com M124.J (07/20) SMT POWER INDUCTORS Shielded Drum Core - PL95XX Series Ruggedized Electrical Schematic Mechanical Percentage of the intitial inductance� Schematic Inductance vs. Current Characteristics 120% 100% 80% 60% 40% 20% 0% 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 Normalized Isat 2 www.inrcore.com M124.J (07/20) SMT POWER INDUCTORS Shielded Drum Core - PL95XX Series Ruggedized For More Information Global Sales Representatives and Lo cations: http://www.inrcore.com iNRCORE,LLC 311 Sinclair Road Bristol, PA 19007-6812 U.S.A Tel: + 1.215.781.6400 Fax: +1.215.7816430 Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product names mentioned herein may be trademarks or registered trademarks of their respective owners. © Copyright, 2020. iNRCORE, LLC. All rights reserved. 3 www.inrcore.com M124.J (07/20)
PL9509 价格&库存
很抱歉,暂时无法提供与“PL9509”相匹配的价格&库存,您可以联系我们找货
