AH43328B-R17KHF
AH43328B-R17KHF
    ITG
    SMD
    固定电感器 SMD-2 170nH ±10% 70A 0.2mΩ
AH43328B-R17KHF 数据手册
AH43328B Series 1. Features of AH43328B Series : · Ferrite based SMD Inductor with lower core loss. · Inductance range: 105.0 nH to 300.0 nH , custom values are welcomed. · High current output chokes, up to 107.0 Amp with approx. 20% roll off. · Low Profile 7.90 mm typical Height . · 11.10 x 8.10 mm Foot Print. · Ideal for Buck Converter, VRM & High Density Board Design. · Operating frequency up to 2 MHz application. · Operating Temperature Range -55°C to + 130°C. RoHs & HF compliant . · T & R Qtys: 450 pcs , 13'' Reel. 2. Electrical Characteristic of AH43328B Series: OCL 1 L@Isat1 2 DCR 3 Isat1 4 Isat2 4 Isat3 4 Irms 5 Dim. C (nH) (nH) (mΩ) (A) (A) (A) (A) (mm) ± 10% MIN. ± 5.0% @25℃ @75℃ @100℃ @25℃ ± 0.20 AH43328B-R105KHF 105.00 75.60 0.195 107.00 103.00 100.00 70.00 8.10 AH43328B-R12KHF 120.00 86.40 0.195 103.00 99.00 94.00 70.00 8.00 AH43328B-R15KHF 150.00 108.00 0.195 86.00 83.00 80.00 70.00 7.90 AH43328B-R17KHF 170.00 122.40 0.195 76.00 73.00 70.00 70.00 7.90 AH43328B-R18KHF 180.00 129.60 0.195 71.00 68.00 65.00 70.00 7.90 AH43328B-R22KHF 220.00 158.40 0.195 56.00 53.00 51.00 70.00 7.90 AH43328B-R30KHF 300.00 216.00 0.195 36.00 33.00 32.00 70.00 7.90 Part Number 43328B RxxxHF ITGYYWW 3. Mechanical Dimension(Unit:mm): A B C D E F G ± 0.20 ± 0.20 (Max.) ± 0.20 (Nom.) ± 0.25 ± 0.35 7.90 10.60 See table above D B A 11.60 2x2.75 C 10.90 5.70 2.20 3.30 2.50 a G E b Suggested Pad Layout F Part Marking: 43328B: 43328 is part size, B is special code. Rxxx: Rxx is inductance value in uH(R:decimal point), x = tolerance,HF=halogen free. ITGYYWW: ITG logo and YYWW is date code. Note: 1> Open Circuit Inductance (OCL) test condition:500KHz,0.25Vrms, 0Adc at 25℃. 2> L @ Isat and L @ Irms Test condition:500KHz,0.25Vrms (Ta=25Ԩ). 3> The nominal DCR is measured from point "a" to point"b", as shown above on the mechanical drawing (Ta=25℃). 4> Isat1, Isat2 & Isat3 : DC current that will cause inductance to drop approximately by 20%. 5> Irms: DC current for an approximate temperature rise of 40℃ without core loss. Derating is necessary for AC currents. PCB pad layout,trace thickness and width,air-flow and proximity of other heat generating components will affect the temperature rise. It is recommended the part temperature not exceed 130°C under worst case operating conditions as verified in the end application. ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 ● Tokyo 81 3 5829 8676 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@inter-technical.com ● www.inter-technical.com Revision D: March 15, 2015 AH43328B Series Inductance vs. Current 4. Inductance Characteristics (Inductance vs. Current): AH43328B-R105KHF 120.0 105.0 25Ԩ L (nH) 90.0 75.0 75Ԩ 60.0 45.0 100Ԩ 30.0 15.0 0.0 0.0 20.0 40.0 60.0 80.0 100.0 102.0 104.0 106.0 108.0 110.0 112.0 114.0 116.0 118.0 120.0 Direct Current (A) AH43328B-R12KHF 140.0 120.0 25Ԩ L (nH) 100.0 80.0 75Ԩ 60.0 40.0 100Ԩ 20.0 0.0 0.0 20.0 40.0 60.0 70.0 80.0 90.0 92.0 94.0 96.0 98.0 100.0 102.0 104.0 106.0 108.0 110.0 112.0 Direct Current (A) AH43328B-R15KHF 180.0 150.0 25Ԩ L (nH) 120.0 75Ԩ 90.0 60.0 100Ԩ 30.0 0.0 0.0 20.0 40.0 60.0 70.0 74.0 78.0 80.0 82.0 84.0 86.0 88.0 90.0 Direct Current (A) ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 ● Tokyo 81 3 5829 8676 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@inter-technical.com ● www.inter-technical.com Revision D: March 15, 2015 AH43328B Series Inductance vs. Current AH43328B-R17KHF 204.0 L (nH) 170.0 25Ԩ 136.0 75Ԩ 102.0 68.0 100Ԩ 34.0 0.0 0.0 20.0 40.0 50.0 60.0 68.0 70.0 72.0 74.0 76.0 79.0 80.0 82.0 84.0 86.0 Direct Current (A) AH43328B-R18KHF 210.0 180.0 25Ԩ L (nH) 150.0 120.0 75Ԩ 90.0 60.0 100Ԩ 30.0 0.0 0.0 10.0 20.0 30.0 40.0 50.0 60.0 62.0 64.0 66.0 68.0 70.0 72.0 74.0 76.0 Direct Current (A) AH43328B-R22KHF 255.5 219.0 25Ԩ L (nH) 182.5 146.0 75Ԩ 109.5 73.0 100Ԩ 36.5 0.0 0.0 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 52.0 54.0 56.0 58.0 60.0 62.0 64.0 66.0 Direct Current (A) ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 ● Tokyo 81 3 5829 8676 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@inter-technical.com ● www.inter-technical.com Revision D: March 15, 2015 AH43328B Series Inductance vs. Current AH43328B-R30KHF 340.0 297.5 255.0 25Ԩ L (nH) 212.5 75Ԩ 170.0 127.5 100Ԩ 85.0 42.5 0.0 0.0 5.0 10.0 15.0 20.0 25.0 28.0 30.0 31.0 32.0 33.0 34.0 35.0 36.0 37.0 38.0 39.0 40.0 Direct Current (A) 5. Core Loss: AH43328B-XXX Core Loss 0 500 1000 1500 2000 2500 3000 3500 4000 1800.0 1700.0 1600.0 1500.0 1400.0 1300.0 Core Loss (mW) 1200.0 Where 1MHz 800KHz 1100.0 1000.0 600KHz 900.0 500KHz 800.0 400KHz 700.0 300KHz 600.0 200KHz 500.0 400.0 300.0 200.0 100.0 0.0 △B(Guass) Where △B=0.307*L(nH)*△I ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 ● Tokyo 81 3 5829 8676 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@inter-technical.com ● www.inter-technical.com Revision D: March 15, 2015
AH43328B-R17KHF 价格&库存
很抱歉,暂时无法提供与“AH43328B-R17KHF”相匹配的价格&库存,您可以联系我们找货
