SQ4126 Series
RoHS
COMPLIANT
HF
COMPLIANT
1. Features:
· Ferrite based SMD Inductor with lower core loss.
· Inductance Range:0.42uH to 10.00uH,Custom values are welcomed.
· High current output chokes, upto 45.0 Amp with approx. 20% roll off.
· Low Profile 6.65mm Max. height .
· Foot Print 8.10 x 10.30 mm Max.
· Ideal for VRM, POL, Notebook regulators,Graphics cards and battery power systems
· Operating frequency up to 1 MHz application.
· Operating Temperature Range -55°C to + 130°C , RoHs & HF compliance .
· T & R Qtys: 700 pcs , 13'' Reel ;
2. Electrical Characteristic of SQ4126 Series:
Inductance
DCR
DCR
Isat1
Isat2
Irms
(uH)
(mΩ)
(mΩ)
(A)
(A)
(A)
±20%
Typical
Max.
@25℃
@125℃
@25℃
0.42
0.56
0.68
1.00
1.50
2.20
3.30
4.70
5.60
6.80
10.00
1.200
1.200
1.200
2.200
3.900
6.350
7.500
8.600
8.600
8.600
8.600
1.390
1.390
1.390
2.800
4.399
6.731
7.950
9.169
9.169
9.169
9.169
45.00
36.00
29.00
26.00
22.00
18.00
14.50
12.00
9.40
7.80
5.30
36.00
28.00
23.00
21.00
17.00
14.00
11.00
8.90
7.50
6.10
4.20
26.00
26.00
26.00
16.00
13.00
11.00
10.00
9.40
9.40
9.40
9.40
Part Number
SQ4126-R42MHF
SQ4126-R56MHF
SQ4126-R68MHF
SQ4126-1R0MHF
SQ4126-1R5MHF
SQ4126-2R2MHF
SQ4126-3R3MHF
SQ4126-4R7MHF
SQ4126-5R6MHF
SQ4126-6R8MHF
SQ4126-100MHF
D
G
3. Mechanical Dimension(Unit:mm):
A
B
C
D
E
F
G
H
I
J
A
F
b
J
E
Max. Max. Max. Nom. Nom. Ref. Nom. Nom. Nom. Max.
8.10
10.30
6.65
6.00
4.20
1.80
2.30
1.30
2.40
8.20
Marking
I
a
H
8.6
2x3.0
C
B
Note:
3.6
3.6
2.9
2.0
Suggested Pad Layout
1>.Open Circuit Inductance (OCL) test condition:100KHz,0.1Vrms,0Adc ,at 25 ℃.
2>.Full Load Inductance (FLL) Test condition:100KHz,0.1Vrms ,Isat ;(Ta=25 ℃).
3>.Isat1,Isat2: DC current that will cause inductance to drops approximately by 20% ;
4>. Irms: DC current for an approximate temperature rise of 40℃ without core loss,.Derating is necessary for AC currents. PCB
pad layout,trace thickness and width,air-flow and proximity of other heat generating components will affect the temperature rise.
It is recommended the part temperature not exceed 130°C under worst case operating conditions verified in the end application.
5>.The nominal DCR is measured from point "a" to point"b",as shown above on the mechanical drawing.
4. Inductance Characteristics (Inductance vs. Current):
US 1 914 347 2474 ●Taiwan 886 972 022 388 ●Shenzhen 86 755 8418 6263 ●Shanghai 86 21 5424 5141 ●HK 852 9688 9767
Sales@inter-technical.com www.inter-technical.com , Rev.B, Jun.06, 2013
SQ4126 Series
RoHS
COMPLIANT
HF
COMPLIANT
SQ4126-R42MHF
0.510
0.425
25Ԩ
L (uH)
0.340
0.255
0.170
0.085
125Ԩ
0.000
0.0
5.0
10.0
15.0
20.0
25.0
27.0
30.0
33.0
36.0
39.0
42.0
45.0
46.0
48.0
51.0
Direct Current (A)
SQ4126-R56MHF
0.700
0.560
25Ԩ
L (uH)
0.420
0.280
125Ԩ
0.140
0.000
0.0
5.0
10.0
15.0
18.0
21.0
24.0
27.0
28.0
Direct Current (A)
30.0
33.0
36.0
39.0
42.0
SQ4126-R68MHF
0.765
0.680
0.595
0.510
0.425
0.340
0.255
0.170
0.085
0.000
L (uH)
25Ԩ
125Ԩ
0.0
2.0
4.0
6.0
8.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 23.0 24.0 26.0 28.0 30.0 32.0 34.0
Direct Current (A)
SQ4126-1R0MHF
1.200
1.050
0.900
0.750
0.600
0.450
0.300
0.150
0.000
L (uH)
25Ԩ
125Ԩ
0.0
3.0
6.0
9.0
12.0
15.0
18.0
21.0
23.0
24.0
25.0
26.0
27.0
29.0
30.0
Direct Current (A)
SQ4126-1R5MHF
1.750
1.500
1.250
25Ԩ
L (uH)
1.000
0.750
0.500
125Ԩ
0.250
0.000
0.0
4.0
8.0
10.0
12.0
14.0
16.0
18.0
Direct Current (A)
20.0
22.0
24.0
26.0
28.0
SQ4126 Series
RoHS
COMPLIANT
HF
COMPLIANT
SQ4126-2R2MHF
2.700
2.250
1.800
L (uH)
25Ԩ
1.350
0.900
125Ԩ
0.450
0.000
0.0
2.0
4.0
6.0
8.0
10.0
12.0
14.0
Direct Current (A)
16.0
18.0
19.0
20.0
22.0
SQ4126-3R3MHF
3.960
3.300
2.640
L (uH)
25Ԩ
1.980
1.320
125Ԩ
0.660
0.000
0.0
2.0
4.0
5.0
6.0
7.0
8.0
9.0 10.0 11.0
Direct Current (A)
12.0
13.5
14.5
15.0
16.5
18.0
SQ4126-4R7MHF
5.200
4.680
4.160
3.640
25Ԩ
L (uH)
3.120
2.600
2.080
125Ԩ
1.560
1.040
0.520
0.000
0.0
2.0
4.0
5.0
6.0
7.0
8.0
9.0
Direct Current (A)
9.4
10.0
11.0
12.0
13.0
SQ4126-6R8MHF
7.650
6.800
5.950
5.100
4.250
3.400
2.550
1.700
0.850
0.000
L (uH)
25Ԩ
125Ԩ
0.0
1.0
2.0
3.0
4.0
5.0
Direct Current (A)
6.0
7.0
8.0
9.0
SQ4126 Series
RoHS
COMPLIANT
HF
COMPLIANT
11.550
SQ4126-100MHF
9.900
L (uH)
8.250
25Ԩ
6.600
4.950
125Ԩ
3.300
1.650
0.000
0.0 1.0 1.5 2.0 2.5 2.8 3.0 3.3 3.6 3.9 4.3 4.5 4.8 5.1 5.4 5.8 6.0 6.3 6.6 6.9 7.3
Direct Current (A)
5. Core Loss:
Condition
Temp.
mT
KW/m3
很抱歉,暂时无法提供与“SQ4126-100MHF”相匹配的价格&库存,您可以联系我们找货
