PZ-30
PRESSURE INDICATORS
ϚʔΩϯά
&.$ࢦྩద߹
marking
Compatible with
EMC directive
11 kinds of display multiplier
Full 3-digit red LED
※ Except for
Current output type
Small 30 mm square face
Compatible with our analog sensors
■ FEATURES
● Pressure indicators separated from sensor
- Can be used with variety of sensors
● Wide range of applications such as pneumatic
equipment or semiconductor equipment
● Any range of pressure sensors is available
● Low power consumption by non display mode
● Set data protection by panel lock function
■ MODEL NUMBER DESIGNATION
P Z - 3 0 - N V S T I
Series name
Switch output interface
Analog output
N:NPN open collector
P:PNP open collector
Blank:Voltage output
I:Current output
Input signal type
Sensor connection type
V:1 ~ 5 V
I:4 ~ 20 mA
ST:One-touch type terminal
CN:Connector type terminal
■ LIST OF MODEL NUMBERS
Analog output
Switch output type
NPN
Analog output
PNP
NPN
Analog Current output
PNP
Input signal type
1~5V
4 ~ 20 mA
1~5V
4 ~ 20 mA
1~5V
4 ~ 20 mA
1~5V
4 ~ 20 mA
※ Verify the above model numbers when placing orders.
One-touch type
terminal
PZ-30-NVST
PZ-30-NIST
PZ-30-PVST
PZ-30-PIST
PZ-30-NVSTI
PZ-30-NISTI
PZ-30-PVSTI
PZ-30-PISTI
Marked
PZ-30-NVCN
PZ-30-NICN
PZ-30-PVCN
PZ-30-PICN
is manufactured upon receipt of order basis.
PZ-30
PRESSURE INDICATORS
■ STANDARD SPECIFICATIONS
● Unless otherwise specified, the specs are defined at an ambient temperature of 25±5 °C and excitation voltage of 24 V DC.
Imput
General specifications
Item
PZ-30
Model number
Operating temp. range
Operating humidity
− 10 ~ 50
°C
35 ~ 85
%RH
IP40
Protection grade
Storage temp.
Net weight
°C
− 20 ~ 70
g
Approx. 80 (Including 2 m cable)
100 MΩ minimum
Insulation resistance
500 V DC 1 minute
Dielectric strength
10.8 ~ 30 V DC(Including ripple percentage)※
Supply voltage
Consumption current
50 mA maximum
1 ~ 5 V (V) / 4 ~ 20 mA (I)
Input signal
Input impedance
10 kΩ (V) / 250 Ω (I)
kΩ
3
No. of digit
LED
Display
Display element
Approx. 4 times/s
Display cycle
“–” LED is ON
Negative pressure display
± 1 %F.S. (Without sensor's error)
Display accuracy
± 0.5 % (0 ~ 50 °C, Reference temp. 25 °C)
Thermal error
1 count
Resolution
NPN/PNP
Output status
2-point output (Transistor, Open collector output)
Switching capacity
30 V DC 100 mA maximum
1.2 V maximum (NPN), 2.2 V maximum (PNP)
Switch
Residual voltage
0 ~ 300 counts Adjustable
Hysteresis setting
± 0.2 %F.S. ± 1 count
Repeatability
With pretection function
Short circuit protection
Approx. 5 ms (“F – 0”) (Selectable 5 ms ~ 2.5 s)
Response
± 0.5 %F.S. (0 ~ 50 °C, Refernce temp. 25°C)
Analog output
Thermal error
State indication
Output 1 (Green LED), Output 2 (Red LED) Lighted when output is ON.
Voltage output
1~5V
Current output
4 ~ 20 mA(500 Ω)
※ When analog current output type of PZ30 is chosen or when a sensor of current output type is connected, supply voltage is 24 V DC ± 10%
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions
Vibration
10 ~ 500 Hz, 98.1 m/s or 1.5 mm P-P, 3 directions for 2 hours each
Shock
Moisture resistance
EMC
Permissible change
2
490 m/s2, 3 directions for 3 times each
40 °C, 90 ~ 95 %RH, 240 hrs.
EMI : EN55011: 2007, A2 : 2007 Group 1, class B
EMS : EN61326-1: 2006 Table 2
Pressure indication, switch operating points
and analog output variation :
± 1 %F.S. maximum each after test
Pressure indication, switch operating pressure and
analog output: ± 5 %F.S. maximum during test
PZ-30
PRESSURE INDICATORS
■ INTERNAL ELECTRICAL SCHEMATICS
● Voltage analog output
・Current input NPN output
1
・Current input PNP output
LED Indicator
2
LED Indicator
Power
1
V+
Load Load
Is
2
Sensor
Main circuit
3
Com
1
Is
Sensor
Common
A.Output
Com
1
2
Sensor
Pressure indication
・Voltage input PNP output
LED Indicator
LED Indicator
1
Com
Main circuit
3
2
Power
Load Load
Vs 2
Common
A.Output
Pressure indication
1
S.Output1
S.Output2
Load Load
3
LED
Power
V+
Main circuit
2
LED
・Voltage input NPN output
Power
1
V+
S.Output1
S.Output2
2
V+
S.Output1
S.Output2
Sensor
Common
A.Output
Com
1
S.Output1
Vs 2
Main circuit
S.Output2
Load Load
3
Common
A.Output
LED
LED
Pressure indication
Pressure indication
※ When connecting the 2-wire type of current output sensors, please do not connect the 3 (Com.) terminal.
● Current analog output
・ Current input NPN output
LED Indicator
LED Indicator
1
1
2
Power
V+
Sensor
Com
A.Output
1
Is
2
Main circuit
2
Power
V+
Load Load
S.Output1
S.Output2
Sensor
3
Common
Com
1
S.Output1
Is
2
Main circuit
Common
Pressure indication
LED Indicator
LED Indicator
1
2
Power
Sensor
Com
1
Vs 2
A.Output
Main circuit
3
Load Load
LED
LED
V+
S.Output2
A.Output
3
Pressure indication
1
2
Power
V+
Load Load
S.Output1
S.Output2
Common
Sensor
Com
1
S.Output1
Vs 2
Main circuit
S.Output2
A.Output
3
Load
Load
Common
LED
LED
Pressure indication
Pressure indication
(Note)Refer to the PIN allocation for the rear terminal number of the PZ-30 and the connector pin terminal number.
(Please from the table on dimension drawing)
PZ-30
PRESSURE INDICATORS
■ ANALOG OUTPUT MODE
Analog output
Code
● Analog output setting : The second figure in triple digits LED
indicates output mode in the initial
setting.
Output mode is fixed by rated pressure.
−Pr
Pr
Output mode
“1”
R mode (Compound) 1 V
(Vzero)
(4 mA)
5V
(20 mA)
“2”
G mode (Positive)
1 V
(4 mA)
5V
(20 mA)
“3”
V mode (Negative)
5 V
(20 mA)
1V
(4 mA)
■ SWITCH OUTPUT MODE
● Switch output can be set when blinking red LED indicates (SW2) in the intial setting.
● The mode is set at “Separate (H/H), 1” prior to shipment. The mode is initialized at “Separate (L/L), 4” when rated pressure is set at “-12P” or
“-12F” (negative pressure).
Output
Mode
Operation
SW1
Separate
HI
LO
Window comparator
A
B
Separate
HI
LO
( HI operation )
Window comparator
A
B
S- 1
S- 2
S- 3
S- 4
C- 5
C- 6
C- 7
C- 8
Pressure setting
(Operating point)
Window comparator mode
Separate mode
SW2
( A operation )
ON
OFF
ON
ON
OFF
P1: SW1
P2: SW2
H
H
-Pr
P1
Pr
P2
-Pr
Pr
H
( LO operation)
( B operation)
ON
ON
P1: SW1
-Pr
P2: SW2
H
H
OFF
Pr
OFF
(Lower limit) : Setting 1
(Upper limit) : Setting 2
Setting 2
H : Switch hysteresis
P1= Setting 1
P1
P2
-Pr
P1≦P2 or P1≧P2
Setting 1
H
OFF
Pr
H
H
P1≦P2–2H
P2= Setting 2
Note 1. In the Separate Mode, setting 1 corresponds to SW1, and Setting 2
corresponds to SW2.
Note 2. In the Window Comparator Mode, the minimum value for SW1 and
SW2 corresponds to Setting 1 and the maximum value corresponds
to Setting 2.
PZ-30
PRESSURE INDICATORS
■ SELECTION OF DISPLAY MULTIPLIER/RATED PRESSURE
● Selection of display multiplier
● Selection of rated pressure
pressure in the initial setting.
● Display multiplier is set at “1” (kPa) prior to shipment.
● Rated pressure is set at “12P” (0 ~ 100 kPa) prior to
● Please set any code when blinking red LED indicates negative
Mode (1/3)
Display multiplier
Code
Multiplier
“1”
× 1 (kPa)
“2”
× 0.0102
“3”
× 10.2
“4”
× 7.501
“5”
× 102
“6”
× 0.01
“7”
× 10
“8”
× 0.145
“9”
× 0.000145
pressure, SW1, SW2 in the initial setting.
shipment.
Pressure reference
Pressure unit
Rated pressure range
0 ~ 10
0 ~ 35
0 ~ 50
Setting code
“11P”
“41P”
“51P”
“-12P”
“12P”
“42P”
“52P”
“62P”
“72P”
“13P”
“23P”
0.00
9.99
0.00
0.10
0.0
99.9
0.0
75.0
0.00
0.10
0.0
99.9
0.00
1.45
0.0
35.0
0.00
0.35
0.0
50.0
0.00
0.51
0.0
-99.9
0.00
-1.02
0.0
99.9
0.00
1.02
0.00
3.57
0.00
5.10
0.00
6.12
0.00
7.14
0.00
9.99
0.0
20.4
0.00
0.35
0.00
5.07
0.00
0.50
0.00
7.25
0.00
-1.02
0.0
-14.5
0.00
1.02
0.0
14.5
0.00
3.50
0.00
5.00
0.00
6.00
0.00
7.00
0.00
9.99
0.0
20.0
0.0
50.7
0.0
72.5
0.0
87.0
0.00
1.00
0.00
0.29
0.00
2.00
Rated pressure display
(PL ~ PH)
Gauge/Absolute
kPa
MPa
0 ~ -100 0 ~ 100 0 ~ 350 0 ~ 500 0 ~ 600 0 ~ 700 0 ~ 1000 0 ~ 2.00
“A” × 0.001 (MPa)
“b”
Mode (2/3)
Display multiplier
Code
Multiplier
“1”
× 1 (kPa)
“2”
× 0.0102
“3”
× 10.2
“4”
× 7.501
“5”
× 102
“6”
× 0.01
“7”
× 10
“8”
× 0.145
“9”
× 0.000145
“A” × 0.001 (MPa)
“b”
0.00
2.95
× 0.2953
× 0.2953
Pressure reference
Pressure unit
Setting code
(PL ~ PH)
0.0
10.3
0.0
14.7
Gauge/Absolute
MPa
Compound
kPa
0 ~ 3.50 0 ~ 5.00 0 ~ 10.0 0 ~ 20.0 0 ~ 35.0 -10 ~ 10 -100 ~ 100 -100 ~ 200 -100 ~ 300 -100 ~ 500 -100 ~ 600 -100 ~ 1000
“43P”
“53P”
“14P”
“24P”
“44P”
0.0
35.7
0.0
51.0
0.0
35.0
0.0
50.0
0.0
99.9
0.00
0.50
0.00
3.50
0.00
0.72
0.00
5.00
0.00
1.45
0.00
9.99
0.00
2.90
0.00
20.0
0.00
5.07
0.00
35.0
“11r”
“12r”
“22r”
“32r”
“52r”
“62r”
“13r”
-9.99
9.99
-0.10
0.10
-99.9
99.9
-75.0
75.0
-999
999
-0.10
0.10
-99.9
99.9
-1.45
1.45
-99.9
99.9
-1.02
1.02
-999
999
-750
750
-100
200
-1.02
2.04
-100
300
-1.02
3.06
-100
500
-1.02
5.10
-100
600
-1.02
6.12
-100
999
-1.02
9.99
-1.00
1.00
-999
999
-14.5
14.5
-1.00
2.00
-1.00
3.00
-1.00
5.00
-1.00
6.00
-1.00
9.99
-14.5
29.0
-14.5
43.5
-14.5
72.5
-14.5
87.0
-0.10
0.10
-29.5
29.5
-0.10
0.20
-29.5
59.0
-0.10
0.30
-29.5
88.5
-0.10
0.50
-29
147
-0.10
0.60
-29
177
-14
145
-0.01
0.14
-0.10
1.00
-29
295
-2.95
2.95
PZ-30
PRESSURE INDICATORS
Pressure reference
Pressure unit
Mode (3/3)
Display multiplier
Code
Multiplier
“1”
× 1 (kPa)
“2”
× 0.0102
“3”
× 10.2
“4”
× 7.501
“5”
× 102
“6”
× 0.01
“7”
× 10
“8”
× 0.145
“9”
× 0.000145
Setting code
(PL ~ PH)
Gauge/Absolute
(× 1 / 0.0102) kPa
0 ~ 0.10 0 ~ 0.35 0 ~ 0.50 0 ~ -1.00 0 ~ 1.00 0 ~ 3.50 0 ~ 5.00 0 ~ 7.00 0 ~ 10.0
“11F”
“41F”
“51F”
“-12F”
“12F”
“42F”
“52F”
“72F”
“13F”
0.00
9.80
0.00
0.10
0.0
99.9
0.0
73.5
0.00
0.09
0.0
98.0
0.00
1.42
0.0
34.3
0.00
0.35
0.0
49.0
0.00
0.50
0.0
-98.0
0.00
-1.00
0.0
98.0
0.00
1.00
0.00
3.50
0.00
5.00
0.00
7.00
0.00
9.99
0.00
0.34
0.00
4.97
0.00
0.49
0.00
7.10
0.00
-0.98
0.0
-14.2
0.00
0.98
0.0
14.2
0.00
3.43
0.00
4.90
0.00
6.86
0.00
9.80
0.0
49.7
0.0
71.0
0.0
99.5
0.00
0.98
“A” × 0.001 (MPa)
“b”
0.00
2.89
× 0.2953
0.0
10.1
0.0
14.4
0.0
-28.9
0.0
28.9
■ OUTLINE DIMENSION
Unless otherwise specified, tolerance: ± 0.5 (Unit: mm)
● One-touch type terminal
□31.4
35
□30
Window
SW1
5 core cable
L = 2000 ± 100
36.4
SW2
kPa
10
PZ-30
2 – M3
Depth 6
1
3
AWG26 UL No.2844
Push button
Wire input
Terminal : OCN-051 manufactured by Osada
Wire : AWG16 26
Wire strip length : 9 10 mm
8.5
● Connector type terminal
□31.4
□30
35
7.5
2-M3 Depth 6
123
Rear Terminal No.
kPa
10
7.8
PZ-30
26.5
21
5 core cable
L = 2000 ± 100
AWG26 UL No.2844
3 2 1 Connector Pin No.
Connector : 0-171826-3 (Pitch 2.5) manufactured by AMP
(Housing : 0-171822-3)
8.5
Wire color
Brown
Gray
Black
White
Blue
Connection
Power ⊕
Analog output
Switch output 1
Switch output 2
Common
Connector pin No. Rear terminal No.
Connection of pressure sensor
3
1
V+:Power supply voltage output (Input voltage)
2
2
Sensor signal: Voltage output Vs (1 ~ 5V) /Current output Is (4 ~ 20mA)
1
3
COMMON(※)
PZ-30
PRESSURE INDICATORS
■ HOW TO MOUNT OPTIONAL ACCESSORIES
● Rear panel mounting bracket set
● Panel mounting bracket set
(51)
35
7
35
35
7
φ4.2
12
(51)
35
φ4.2
12
35
Material : SUS304 (t = 1.5)
25
35
25
φ4.2x5.2 Slot
2-M3x4
φ4.2x5.2 Slot
Associated screw
2-M3x4
Associated screw
2-M3x4
Associated screw
φ4.2
15.5
(5.7)
4.5
31.2
36 +0.5
+0.5
43 maximum
43 maximum
□40
□40
kPa
Recommended : 50 minimum
36 +0.5
6 maximum
24.7
kPa
PZ-30
Panel cut dimension
(Recommended board thickness : 5 maximum)
Panel cut dimension
Name
Series Name
Contents
(PG-30/PG-35)
ACPG-003
Panel holder cover
Panel holder
Panel stopper (2 pcs.)
Holder cover set
ACPG-004
Panel holder cover
Panel holder
Holder stopper set
ACPG-007
Panel holder
Rear panel bracket set (Z)
ACPG-011
Rear panel bracket set (Z) and M3 × 4, male screw (2 pcs.)
Panel bracket set (Z)
ACPG-012
Panel panel bracket set (Z) and M3 × 4, male screw (2 pcs.)
Panel holder set
(46)
(46)
6 maximum
PZ-30
(30)
φ4.2x5.2 Slot
24.7
(5.7)
□42.6
(30)
(20.5)
4.5
(14)
6
φ4.2x5.2 Slot
30
30
□42.6
(20.5)
9
(46)
(46)
6
24
9
24
φ4.2
15.5
● Panel holder set
2-M3x4
Associated screw
很抱歉,暂时无法提供与“PZ-30-NISTI”相匹配的价格&库存,您可以联系我们找货
