CW1
Counterweight for use on cable suspended float switches.
Adjustable cable pivot point
Cable lock feature
Inert and non-hazardous in water
This counterweight is used to set or adjust the pivot point for a cable suspended float switch. The position on the cable relative to the switch
can be used to adjust the liquid level differential between open and closed switch output.
Most of the cable suspended float switches from Cynergy3 are supplied with these counterweights but the LITTLE-EX series of ATEX approved
switches are not.
Installation of counterweight on cable
Remove the locking cone from the top of the counterweight moulding, but DO NOT REMOVE THE LID OF THE COUNTERWEIGHT.
Fit the locking cone onto the cable
Feed the cable through the counterweight body until the locking cone reaches the counterweight.
Push the locking cone into the base of the counterweight to lock the counterweight on the cable at the required position.
Cable
Remove Cone
Cynergy3 Components Ltd.
7 Cobham Road
Ferndown Industrial Estate
Wimborne, Dorset BH21 7PE
Telephone +44 (0) 1202 897969
Push up into body
Fit to cable
Email:sales@cynergy3.com
ISO9001 C E R T I F I E D
www.cynergy3.com
© 2012 Cynergy3 Components, All Rights Reserved. Specifications are subject to change without prior notice. Cynergy3 Components and the Cynergy3 Components logo are trademarks of Cynergy3 Components Limited.
很抱歉,暂时无法提供与“CW1”相匹配的价格&库存,您可以联系我们找货
