12327
    ALLIEDVISION
    CABLE USB 3.0 3M INDUSTRIAL SUIT
12327 数据手册
DATA SHEET Product code 12327 Interface cable V1.0.0 2019-May-17 USB 3.0 Type-A to Micro-B with screw locks, 3.0 m NOTICE Malfunctions and short circuits by damaged cables and connectors Provide sufficient strain relief for all cable connections. Cable and connector dimensions Length (33.0) (30.0) (21.0) (33.0) 5.4 +0.20 - 0.00 (30.0) (22.0) (15.8) 11.75+0.20 - 0.00 Note: Unit in technical drawings is [mm]. Connector 1: USB 3.0 Type-A male Cable Connector 2: USB 3.0 Micro-B male (10.5) Connector 1 and adapter description 10 6 DĂƟŶŐĨĂĐĞǀŝĞǁ 5 1 A Red: Screw lock mounted to the connector. See right. 18.0 9 Screw mount adapter A) M2.5×3.0 screw replaces M2.65×2.5 B) M2 thumb screws (8.0) 1 Connector 2 description (10.5) (22.0) 5 (7.8) 4 M2 x 0.4 3.5 0.25 DĂƟŶŐĨĂĐĞǀŝĞǁ B Wiring diagram VBUS 1 2 3 4 5 D- White White D- D+ Green Green D+ GND StdA-SSRX- 6 StdA-SSRX+ GND-DRAIN 7 8 StdA-SSTXStdA-SSTX+ 9 SHELL VBUS Red 1 2 3 GND Black Blue Blue Yellow Yellow Violet Violet Orange Orange Braid Shield 6 MicB-SSTX+ 7 GND-DRAIN 8 MicB-SSRX- 9 MicB-SSRX+ 10 Braid Shield Page 1 of 3 5 MicB-SSTX- SHELL USB 3.0 Type-A to Micro-B with screw locks, 3.0 m Specifications Feature Length Diameter Classifications Static bending radius Dynamic bending radius Operating temperature range Regulations Specification 3.0 m ± 50 mm 6.2 mm Industrial grade for static applications ≥ 62 mm For static applications only -10°C to +60°C 2011/65/EU, incl. amendment 2015/863/EU (RoHS), China RoHS, REACH, cable material: UL2725 Allied Vision Technologies GmbH, Taschenweg 2a, D-07646 Stadtroda, Germany info@alliedvision.com, https://www.alliedvision.com © Allied Vision 2019 Page 2 of 3 USB 3.0 Type-A to Micro-B with screw locks, 3.0 m Page 3 of 3
12327 价格&库存
很抱歉,暂时无法提供与“12327”相匹配的价格&库存,您可以联系我们找货
