IWR-1
IWR-1
    SENSATA(森萨塔)
    WIRELESS RCVR 1 CH FOR WIFI PRES
IWR-1 数据手册
IWR-1 Single Channel Wireless Receiver Pairs with the IWPT wireless pressure transducer User-selectable 1-5V or 4-20mA receiver output Clean contact output for process, low battery or loss of signal alarm function Simple DIL switch pairing with the IWPT pressure transducer Up to 750m range, line-of-sight 12 to 32 Vdc powered End-to-end accuracy of ±0.25% FS BFSL LED indication of wireless link DIN rail or wall mounting kits available Five channel receiver available - see data sheet IWR-5 Description The IWR-1 is a single channel receiver designed to pair with the IWPT series of wireless pressure transducers to form a cost effective replacement of the traditional wired pressure transducer. This offers a low cost solution to inaccessible or expensive installation environment The receiver has a user selectable voltage or mA output corresponding to the calibrated pressure range of the remote Wireless Pressure Transducer and 5A rated changeover contacts for alarm functionality. User configuration is possible, however the single channel transmitter/receiver combination is designed to work ‘out of the box’ offering a simple plug and play solution to pressure measurement applications. With the standard 0dBI antenna, a line-of-sight range of up to 500m can be achieved and, using the optional 3dBI antenna, up to 750m (LOS) is achievable. Electrical Protection Receiver Input Outputs User selectable 1-5V or 4-20mA Receiver Frequency* 2.4GHz Alarm Output 5 Amp rated changeover contacts System Channel Standard setting, however Receiver Update Rate* 10 seconds as standard. user adjustable in multiple Alternative user setable rates : instrument systems. - 1,5, 10 and 30 seconds Antenna Enclosure mounted 0dBi *Consult IWPT Installation manual and data sheet for set-up of alternative transmission rates. *Compliant with EN 300 328, V1.8.1 Enclosure Specifications System Performance (@ +20°C) Dimensions 120 mm x 80 mm x 57 mm Accuracy
IWR-1 价格&库存
很抱歉,暂时无法提供与“IWR-1”相匹配的价格&库存,您可以联系我们找货
IWR-1
