ACCESSORIES
Tie Wraps:TY-8
Ground Clamp
Electrical Tape
8 inch plastic Tie Wraps.
ZINC with SS bolts
Durable and Strong
Sold in bags of 100.
Brass Option Available
65′ L× 3/4" W
Clear color only.
SPADE BITS
(Special Order Item)
Available:White or Black
Call for Min. Order Qty - Leadtime - Pricing
Sold in sleeves of 10
JAMBSTICK
Plu
Pre-Wire Plugs
The JambStick is used to ensure
proper drill angles for alarm wiring.
Assorted sizes
Telephone Block
and 18" Cord
UL
STB-10 Plug= 3/8" Plug
SD-70 Plug= 3/4" Plug
reusable in Brown and White
PPD-11
(Push Pull Disconnect)
EZ DUCT-IT
Low Voltage Wire Raceway
Sold in 5 packs. Each pack contains five
strips 3/8"×5/8"×5'. Total of 125'.
Type
Part Number
RJ31
TJ-8
(8 wire block w/1 male jack)
TJ-8 DUAL
This 2 wire connector features 2 holes used
(8 wire block w/2 male jacks)
to either mount the PPD-11 or to take the
RJ31-DUAL
EZ DUCT-IT connectors sold separately
in 25 piece combo-packs.
pressure off the wires.
Available: White, Brown, Gray & Clear
61
ACCESSORIES
METAL
HOUSING
PLASTIC
COVER
.67"(17)
.224"
(5.7)
B-Connector
(DRY FILLED w/WHITE SLEEVE)
(SILICONE FILLED w/BLUE SLEEVE)
1.02"(26)
MATERIALS:
Outer Shell: Plastic Heat Shrink Tubing
Contact Resistance: 10 Milli Ohoms Initial
Metal Housing: Brass
Dielectric: 1000 V
Inner Sleeve: Beryllium Copper plated with Bright Nickel
Strength of Joint: 9 lbs
TANE WS-1
(Water Sensor with Leads)
The WS-1 is a low cost reliable water sensor that works on 12VDC alarm
panels, on a 24 hr zone, open loop circuit.
The wiring works similar to a two wire smoke detector. You have a red +
and black - wire inside the cable jacket. The sensor draws a very small
current from the alarm panel’s 24 hr open loop circuit. When the terminals
Color: White
get wet the internal transistor flip flops and locks down to close the circuit,
Size: 2 1/2" L × 1/2" W × 1/2" H
causing the alarm panel to send an alarm.
P/N TANE WS-1 WH Packed 5
Note: If the Panel uses an EOL resistor, then 6VDC is the minimum
Early water damage warning w/6' foot jacketed leads
requirement.
Longer Leads available, 12V Operating @10 ma
Note: Not compatible with wireless transmitters.
Output 9V DC minimum
Always test system for compatibility.
TANE BOX WSPR66A · 20 Watt Stainless Steel Box with Dual Tampers and Dual Tone Siren
Specifications:
·Housing Material:
Stainless Steel with Dual Reed Tampers
·Speaker Type:
Voice coil impedance-8 ohm
Steady-1200HZ
Warble-800HZ to 1200HZ
1 second ramp cycle
·Rated Input Voltage: 12 VDC
·Operating Temp: -20°C to 60°C
·Range Voltage: 6-15VDC
·Dimensions:
·Sound Level: 115db/m
·Current Draw:
AVAILABLE SPECIAL
ORDER ONLY
·Tone Frequency:
280mA @ 12VDC 8 ohm load
5.67"H×5.63"W×4"D
(144mm×143mm×100mm)
·Color: Stainless Steel
The TANE BOX WSPR66A Stainless-Steel Siren, can be fitted with a TANE LED STROBE
(sold separately), to provide visual as well as acoustic warnings and alerts.
62
很抱歉,暂时无法提供与“TANE WS-1”相匹配的价格&库存,您可以联系我们找货
