TSH190
Bipolar High Voltage Hall Effect Latch
TO-92S
Pin Definition:
1. VCC
2. GND
3. Output
SOT-23
Pin Definition:
1. VCC
2. Output
3. GND
Description
TS190, Hall-Effect sensor, designed for electronic commutation of brush-less DC motor applications. The device
includes an on-chip Hall voltage generator for magnetic sensing, a comparator that amplifies the Hall Voltage,
and a Schmitt trigger to provide switching hysteresis for noise rejection, open collector output. An internal band
gap regulator is used to provide temperature compensated supply voltage for internal circuits and allows a wide
operating supply range. The device is identical except for magnetic switch points. A south pole of sufficient
strength will turn the output on. The North Pole is necessary to turn the output off. An on-board regulator permits
operation with supply voltages of 4V to 30 V.
Features
Ordering Information
Optimized for BLDC motor applications
High Peak Voltage of 65V
o
100% tested at 125 C
Temperature compensation function
Part No.
TSH190CT B0G
TSH190CX RFG
Package
Packing
TO-92S
SOT-23
1Kpcs / Bulk Bag
3Kpcs / 7” Reel
Note: “G” denote for Halogen Free Product
Application
High temperature Fan motor
3 phase BLDC motor application
Fan motor application
Speed sensing
Revolution counting
E-Bike
Absolute Maximum Rating (Ta = 25oC unless otherwise noted)
Characteristics
Supply voltage
Output Voltage
Reverse voltage
Magnetic flux density
Output current
Operating Temperature Range
Storage temperature range
Maximum Junction Temp
Thermal Resistance - Junction to Ambient
Thermal Resistance - Junction to Case
Package Power Dissipation
Note: Do not apply reverse voltage to VCC and VOUT
Limit
Value
Unit
VCC
VOUT
VCC/OUT
65
65
-32
Unlimited
25
V
V
V
Gauss
mA
o
C
IOUT
TOPR
-40 to +125
o
-55 to +150
TSTG
C
o
150
TJ
C
206
TO-92S
o
θJA
C/W
543
SOT-23
148
TO-92S
o
θJC
C/W
410
SOT-23
606
TO-92S
PD
mW
230
SOT-23
Pin, It may be caused for Miss function or damaged device.
1/8
Version: B13
TSH190
Block Diagram
Typical Application Circuit
C1:1000pF
C2:15pF
R1:10KΩ
Electrical Specifications (DC Operating Parameters:TA=+25oC,VCC=12V)
Parameters
Supply Voltage
Supply Current
Output Saturation Voltage
Output Leakage Current
Output Rise Time
Output Fall Time
Test Conditions
Operating
BBOP
IOFF BBOP
South pole
TO-92S
BBOP
South pole
SOT-23
B
很抱歉,暂时无法提供与“TSH190CX RFG”相匹配的价格&库存,您可以联系我们找货
