FRC-Series
Thick Film Chip Resistor Product Specifications
FRC 系列厚膜片式电阻器规格说明书
常规厚膜片式电阻器(Thick Film Chip Resistor )
■应用(Application)
- Entertainment:Stereo,TV tuners,Tape recorder
- 娱乐:立体声、电视调谐器、录音机
- Appliance: Air conditioner, Refrigerator
- 电器:空调、冰箱
- Computer & relative products : Main board, PDA
- 电脑及相关产品:主板、PDA
- Communication equipment: Cell phone, Fax machine
- 通讯设备:手机、传真机
- Power equipment: Power supply , II Lumination equipment
- 电源设备:电源、二级照明设备
- Measuring instrument: Electric meter,Navigation equipment
- 测量仪器:电表、导航设备
■特点(Features)
small size and light weight
- 体积小、重量轻
- Reliability, high quality
- 可靠性,高质量
■产品料号(Parts Number Explanation)
示例(Example):
FRC1206F1001TSD
F
R
C
1206
F
1001
T
S
D
公司名
产品别
功能别
尺寸
公差
字码
包装别
端电极
特殊码
FOJAN
R:Resistor
C:Normal
0201
B:±0.1%
±5%:E24
T: 7 inch reel
S:Sn
N:
C:Capacitor
P:Hi-Power
0402
C:±0.25%
3-digits+blank
Q:10 inch reel
C:Cu
Normal
L:Inductor
L:Lowohmic
0603
D:±0.5%
102=1KΩ
R:13 inch reel
A:Au
D:Diode
A:Array
0805
F:±1%
1R0=1Ω
B:Bulk
A:Audion
S:Surge
1206
J:±5%
±1%&Below:
H:Hi-Precision
1210
P:Jumper
E24+E96:
V:Hi-Voltage
1218
4-digits
Q:Auto-motive
1812
1001=1KΩ
R:Anti-sulfur
2010
1R00=1Ω
M:Metal
2512
D:LED
D: LED
Company
Type code
code
FJ-JS-3001-V1.0 / 2021.1.25
Functional
Size
Tolerance
Resistance
Packaging
Termination
Special
code
code
code
code
code
code
Case
1
www.fojan.cn
FRC-Series
FRC 系列厚膜片式电阻器规格说明书
■本体标识(Marking on the Resistor's Body)
0201 及 0402 因本体太小,本体上无字码标示
For 0201 and 0402 size, no marking on the body due to the
small size of the resistor
472=47×102=4.7KΩ
公差±5%的产品,以三字码标示,前两位表示阻值
的有效数字,最后一位表示 10 的乘幂
±5% tolerance product: the marking is 3 digits, the first
2 digits are significant figures of resistance value and
the 3rd one denotes the power number of 10, (10X)
10Ω以下标示:5R6=5.6Ω
Below 10Ω: 5R6=5.6Ω
±0.5%, ±1%, ±2%的产品,以四字码标示,前三位
表示阻值的有效数字,最后一位表示 10 的乘幂
±0.5%, ±1%,±2% tolerance product: the marking is 4
digits, the first 3 digits are significant figures of
resistance value and the 4th one denotes the power
number of 10, (10X)
4992=499×102=49.9KΩ
0603 ±1% E96 系列的标准阻值,因电阻本体太小,
采用三位代码标示。
Standard E96 series values of 0603 ±1%: due to the
small size of the resistor’s body, use 3digits code to
indicate the resistance value.
100Ω以下标示:
6R81=6.81Ω
Below 100Ω: 6R81=6.81
Ω
■0603±1% E96 系列电阻值代码 Standard E96 Series Resistance Value Code for 0603
代码 阻值
Code Value
01
100
02
102
03
105
04
107
05
110
06
113
07
115
08
118
09
121
10
124
11
127
12
130
13
133
14
137
15
140
16
143
代码
Code
17
18
19
22
23
24
25
26
27
28
29
30
31
32
阻值
Value
147
150
154
158
162
165
169
174
178
182
187
191
196
200
205
210
代码
Code
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
阻值
Value
215
221
226
232
237
243
249
255
261
267
274
280
287
294
301
309
代码
Code
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
2
阻值
Value
316
324
332
340
348
357
365
374
383
392
402
412
422
432
442
453
代码
Code
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
阻值
Value
464
475
487
499
511
523
536
549
562
576
590
604
619
634
649
665
±1% Marking
代码
Code
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
阻值
Value
681
698
715
732
750
768
787
806
825
845
866
887
909
931
953
976
www.fojan.cn
FRC-Series
FRC 系列厚膜片式电阻器规格说明书
■0603±1%标记的倍增码 Multiplier Code for 0603
代码 Code
指数 Multiplier
±1% Marking
Y
X
A
B
C
D
E
F
10-2
10-1
100
101
102
103
104
105
阻值标示如下(So the resistance value are marked as the following examples)
10D=124×103=124KΩ
38Y=243×10-2=2.43Ω
0603 ±1%的产品,在标准 E24 系列中,但不属于 E96 系列,标示与 5%的字码相同,但是在中间字码
下加一条线(Standard E24 and not belong to E96 series values of 0603 ±1%, the marking is the
same as 5% tolerance but marking as underline)
331=33×101=330Ω
560=56×100=56Ω
尺寸(Dimension):
尺寸
dimension
单位(unit): mm
型别(Type)
L
W
H
T1
T2
0201
0.60±0.03
0.30±0.03
0.23±0.03
0.10±0.05
0.15±0.05
0402
1.00±0.05
0.50±0.05
0.35±0.05
0.20±0.10
0.25±0.10
0603
1.60±0.10
0.80±0.10
0.45±0.10
0.25±0.15
0.25±0.15
0805
2.00±0.10
1.25±0.10
0.50±0.10
0.35±0.20
0.35±0.20
1206
3.10±0.10
1.60±0.10
0.55±0.10
0.45±0.20
0.40±0.20
1210
3.10±0.10
2.60±0.15
0.55±0.10
0.45±0.15
0.50±0.20
1218
3.10±0.10
4.60±0.10
0.55±0.10
0.45±0.20
0.40±0.20
1812
4.50±0.20
3.10±0.20
0.55±0.10
0.55±0.20
0.70±0.20
2010
5.00±0.10
2.50±0.15
0.55±0.10
0.45±0.15
0.50±0.20
2512
6.35±0.10
3.10±0.15
0.55±0.10
0.60±0.20
0.50±0.20
3
www.fojan.cn
FRC-Series
FRC 系列厚膜片式电阻器规格说明书
■ 功率衰减曲线( Derating Curve)
■ 电阻结构(Construction)
NO.
1
2
3
4
5
6
7
8
9
4
结构
construction
主要材料
Major material
陶瓷基板
Ceramic substrate
银电极
Conductive layer
侧电极
Side conductive layer
阻体层
Resistive layer
内保护层
Inner protective layer
外保护层
Outer Protective layer
文字
Marking
镍电极
Ni plating layer
锡电极
Sn plating layer
三氧化二铝
Al2O3
银
Ag
镍铬合金
NiCr
氧化钌+玻璃
RuO2+ glass
玻璃
Glass
环氧树脂
Epoxy
环氧树脂
Epoxy
镍
Ni
锡
Matte Tin
www.fojan.cn
FRC-Series
FRC 系列厚膜片式电阻器规格说明书
■ 电气特性(Electrical characteristics)
型别 Type
0201
0402
0603
0805
1206
1210
1218
1812
2010
2512
1/20W
1/16W
1/10W
1/8W
1/4W
1/2W
1W
1/2W
3/4W
1W
最大工作电压
Max Working Voltage
25V
50V
75V
150V
200V
200V
200V
200V
200V
200V
最大过负荷电压
Max Overload Voltage
50V
100V
150V
300V
400V
400V
500V
400V
400V
400V
绝缘耐压
Dielectric Withstanding
Voltage
100V
100V
300V
500V
500V
500V
500V
500V
500V
零欧姆阻值 ±1%
Resistance Value
of Jumper ±1%
很抱歉,暂时无法提供与“FRC1812F1004TS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09600
- 200+0.09000
- 600+0.08400
- 2000+0.07800
- 5000+0.07200
- 10000+0.06780
