74LVC1GX04
X-tal driver
Rev. 4 — 12 December 2016
Product data sheet
1. General description
The 74LVC1GX04 combines the functions of the 74LVC1GU04 and 74LVC1G04 to
provide a device optimized for use in crystal oscillator applications.
The integration of the two devices into the 74LVC1GX04 produces the benefits of a
compact footprint. It provides lower power dissipation and stable operation over a wide
frequency and temperature range.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of this
device in a mixed 3.3 V and 5 V environment.
This device is fully specified for partial power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant input and a 5 V overvoltage tolerant powered down output
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8B/JESD36 (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74LVC1GX04
Nexperia
X-tal driver
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC1GX04GW
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74LVC1GX04GV
40 C to +125 C
SC-74
plastic surface-mounted package (TSOP6); 6 leads SOT457
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74LVC1GX04GW
VX
74LVC1GX04GV
VX4
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
PQE
Fig 1.
Logic symbol
74LVC1GX04
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 18
74LVC1GX04
Nexperia
X-tal driver
6. Pinning information
6.1 Pinning
/9&*;
QF
*1'
9&&
DDJ
Fig 2.
Pin configuration SOT363 and SOT457
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
n.c.
1
not connected
GND
2
ground (0 V)
X1
3
data input
X2
4
data output
VCC
5
supply voltage
Y
6
data output
7. Functional description
Table 4.
Function table[1]
Input
Output
X1
X2
Y
H
L
H
L
H
L
[1]
H = HIGH voltage level;
L = LOW voltage level.
74LVC1GX04
Product data sheet
3 of 18
74LVC1GX04
Nexperia
X-tal driver
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
VI < 0 V
[1]
Max
Unit
0.5
+6.5
V
50
0.5
+6.5
V
mA
mA
50
Active mode
[1][2]
0.5
VCC + 0.5
V
Power-down mode
[1][2]
0.5
+6.5
V
50
mA
VO > VCC or VO < 0 V
output voltage
VO
Min
IO
output current
VO = 0 V to VCC
ICC
supply current
100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
250
mW
Tamb = 40 C to +125 C
[3]
[1]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
Above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
Conditions
[1]
output voltage
VO
Active mode
ambient temperature
t/V
input transition rise and fall rate
Unit
1.65
5.5
V
V
VCC
V
5.5
V
40
+125
C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
For use of a regular crystal oscillator, the recommended minimum VCC should be 2.0 V.
[2]
Only for output Y.
Product data sheet
Max
[1]
74LVC1GX04
Typ
Power-down mode; VCC = 0 V
Tamb
[2]
Min
4 of 18
74LVC1GX04
Nexperia
X-tal driver
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ[1]
Max
Unit
Tamb = 40 C to +85 C
VIH
HIGH-level input voltage
VCC = 1.65 V to 5.5 V
0.75 VCC
VIL
LOW-level input voltage
VOL
LOW-level output voltage VI = VIH or VIL
IO = 100 A; VCC = 1.65 V to 5.5 V
0.1
V
VOH
V
0.25 VCC V
IO = 4 mA; VCC = 1.65 V
0.45
V
IO = 8 mA; VCC = 2.3 V
0.3
V
IO = 12 mA; VCC = 2.7 V
0.4
V
IO = 24 mA; VCC = 3.0 V
0.55
V
IO = 32 mA; VCC = 4.5 V
0.55
V
VCC 0.1
V
1.2
V
HIGH-level output voltage VI = VIH or VIL
1.9
V
2.2
V
2.3
V
3.8
V
0.1
1
A
0.1
2
A
0.1
4
A
5.0
pF
II
input leakage current
IOFF
power-off leakage current VI or VO = 5.5 V; VCC = 0 V
ICC
supply current
CI
input capacitance
74LVC1GX04
Product data sheet
VCC = 0 V to 5.5 V; VI = 5.5 V or GND
[2]
VCC = 1.65 V to 5.5 V; IO = 0 A;
VI = 5.5 V or GND;
5 of 18
74LVC1GX04
Nexperia
X-tal driver
Table 7.
Static characteristics …continued
Symbol Parameter
Conditions
Min
Typ[1]
Max
Unit
VIH
0.8 VCC
V
VIL
0.2 VCC
V
VOL
0.1
V
0.7
V
0.45
V
0.6
V
0.8
V
0.8
V
VCC 0.1
V
0.95
V
1.7
V
1.9
V
2.0
V
3.4
V
1
A
2
A
4
A
VOH
II
VCC = 0 V to 5.5 V; VI = 5.5 V or GND;
IOFF
ICC
supply current
VI = 5.5 V or GND;
[1]
Typical values are measured at maximum VCC and Tamb = 25 C.
[2]
VO only for output Y.
74LVC1GX04
Product data sheet
[2]
6 of 18
74LVC1GX04
Nexperia
X-tal driver
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 5.
Symbol Parameter
propagation delay
tpd
40 C to +85 C
Conditions
40 C to +125 C Unit
Min
Typ[1]
Max
Min
Max
VCC = 1.65 V to 1.95 V
0.5
2.1
5.0
0.5
6.5
ns
VCC = 2.3 V to 2.7 V
0.3
1.7
4.0
0.3
5.0
ns
VCC = 2.7 V
0.3
2.5
4.5
0.3
5.6
ns
VCC = 3.0 V to 3.6 V
0.3
2.1
3.7
0.3
4.5
ns
VCC = 4.5 V to 5.5 V
0.3
1.6
3.0
0.3
3.8
ns
1.0
4.4
10.0
1.0
12.5
ns
[2]
X1 to X2; see Figure 3
X1 to Y; see Figure 4
0.5
2.9
6.0
0.5
7.5
ns
VCC = 2.7 V
0.5
3.0
6.0
0.5
7.5
ns
0.5
2.8
5.5
0.5
6.9
ns
0.5
2.3
4.5
0.5
5.6
ns
35
pF
power dissipation
capacitance
CPD
[1]
[3]
VCC = 3.3 V; VI = GND to VCC;
output enabled
Typical values are measured at nominal VCC and at Tamb = 25 C.
[2]
tpd is the same as tPLH and tPHL
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
12. Waveforms
9,
90
;LQSXW
*1'
W3/+
W3+/
92+
;RXWSXW
90
92/
PQE
Measurement points are given in Table 9.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 3.
Input X1 to output X2 propagation delay times
74LVC1GX04
Product data sheet
7 of 18
74LVC1GX04
Nexperia
X-tal driver
9,
90
;LQSXW
*1'
W3+/
W3/+
92+
很抱歉,暂时无法提供与“74LVC1GX04GW,125”相匹配的价格&库存,您可以联系我们找货
