DEQING HUAYING ELECTRONICS CO.,LTD.
APPROVAL SHEET
SAW BANDPASS FILTER
PART NO.: NDFG010-1580SA
Product Type:
Customer:
SAW Filter
Part NO.:
Customer Part NO.:
NDFG010-1580SA
Ver. Ctrl.:
Issued Date:
SFG010-1580SA -160315-v1.0
PREPARED BY
Part No.
Pages
Data
Revision
CHECKED BY
APPROVED BY
NDFG010-1580SA
10
2016-3-15
Add (Deqing): 188 Zhiyuan North Rd.Wukang Town Deqing County Zhejiang Province 313200,P.R.China
Phone
: +86-572-8281127
Fax
: +86-572-8281298
E-mail
: sales@dqhuaying.com
Website : http://www.dqhuaying.com
NDFG010-1580SA
Unbalanced
1580 MHz
Revision
Date
Description
2016-3-15
First draft
-2-
Remark
NDFG010-1580SA
Unbalanced
1580 MHz
Features
SAW filter for Beidou & GPS & GLONASS.
1 High stability and reliability with good performance and no adjustment.
2 Narrow and sharp pass band characteristics. RoHS compatible.
3 Low insertion loss and deep stop band attenuation for interference.
4 Low – loss SAW filter for GPS.
5 Package size 1.4 mm *1.1 mm
Package Dimensions
Ceramic Package: Unit:mm
Pin Configuration
1
Input
4
Output
2,3,5
Ground
Marking
Top View, Laser Marking
“10”:
Part number
” 1”::
Terminal1
Dot marking, indicates input 1
The first “*”: Month Code (The code shown below varies in a 4-year-cycle)
Month
2016/2020
2017/2021
2018/2022
2019/2023
1
n
A
N
a
2
p
B
P
b
3
q
C
Q
c
4
r
D
R
d
5
s
E
S
e
6
t
F
T
f
7
u
G
U
g
8
v
H
V
h
9
w
J
W
i
10
x
K
X
j
11
y
L
Y
k
4th
5th
6th
7th
8th
9th
10th
12
z
M
Z
m
The second “*”: Date Code
data
code
data
code
data
code
1st
2nd
3rd
A
B
C
D
E
F
G
H
J
K
11th
12th
13th
14th
15th
16th
17th
18th
19th
20th
L
M
N
P
Q
R
S
T
U
V
21st
22nd
23rd
24th
25th
26th
27th
28th
29th
30th
31st
W
X
Y
Z
a
b
d
e
f
g
h
-3-
NDFG010-1580SA
Unbalanced
1580 MHz
Electrical Characteristics:
Item
Minimum
Typical
Maximum
Unit
1559.09 …. 1563.09 MHz
1.8
2.1
dB
1574.42 …. 1576.42 MHz
1.3
1.6
dB
1597.55 …. 1605.89 MHz
1.8
2.1
dB
0.2
0.5
dB
0.2
0.4
dB
0.3
0.6
dB
1.6
1.9
1.2
1.6
1.3
1.8
2
7
ns
2
7
ns
2
8
ns
IL
Insertion Loss
Pr
Passband Ripple
Vswr
VSWR
Gdr
Group delay Ripple
α
Absolute Attenuation
DC …. 925.00 MHz
45
50
dB
925.00 …. 960.00 MHz
43
50
dB
1427.00 …. 1453.00 MHz
41
47
dB
1453.00 …. 1470.00 MHz
40
45
dB
1470.00 …. 1530.00 MHz
30
35
dB
1530.00 …. 1541.00MHz
7
13
dB
1626.00 …. 1635.00 MHz
10
17
dB
1635.00 …. 1700.00 MHz
33
37
dB
1710.00 …. 1785.00 MHz
45
50
dB
1850.00 …. 1910.00 MHz
43
48
dB
1920.00 …. 1980.00 MHz
42
48
dB
2110.00 …. 2170.00 MHz
40
45
dB
2300.00 …. 2400.00 MHz
40
44
dB
2400.00 …. 2500.00 MHz
39
43
dB
2500.00 …. 2570.00 MHz
38
42
dB
2570.00 …. 3000.00 MHz
33
39
dB
50
Ω
Input / Output Impedance (Nominal)
RoHS Compliant
Electrostatic Sensitive Device
-4-
NDFG010-1580SA
Unbalanced
1580 MHz
Maximum Ratings
Rating
Value
Unit
VDC
10
V
RF Power (in BW)
P
13
dBm
Operating Temperature Range
TA
-30~ +85
°C
Storage Temperature Range
Tstg
-40 ~ +85
°C
ESD Voltage (HB)
VESD
>150
V
Moisture Sensitivity Levels
MSL
DC Voltage (between any Terminals)
Typical Frequency Response
S21
-5-
2A
NDFG010-1580SA
Unbalanced
S11 Group Dealy
Far side
-6-
1580 MHz
NDFG010-1580SA
Unbalanced
1580 MHz
Stability Characteristics
Item No.
Test Item
Preconditioning
STD Reference
JESD22-A113
Test Conditions
per lot
1) Temperature Cycling, 5 cycles -40℃ to
85℃
2) Bake, 24 hrs @125±5℃;
Temperature
Cycling
JESD22-A104
3) Reflow, 3 reflow cycles using profiles per
IPC/JEDEC J-STD-020, SnPb or Pb-free
profile based on device end use process
4) Drying, Room ambient temperature
-40 ℃ / +85 ℃ ,40min dwell, 4 minutes,
4X in each orientation, 50g peak acceleration
23
10
Mechanical Shock
JESD22-B104
11
Solder Heat
Resistance
IEC 68-2-21 Ue3
Y1 plane only, 5 pulses, 0.5 ms duration, 1500
g peak acceleration
±250V,C=100pF,R=1.5kΩ,1times
12
Static marginal test
JESD22-A114F
customer )
13
Power
capacity
Margin Limits
Power margin tests beyond input power
specification:
CW signal,85℃,highest in-band frequency,2
1
23
23
23
23
23
demand
of
hours dwell time for each step, repeat the tests
until DUT abnormal
Requirements: The SAW filer shall remain within the electrical specifications after tests.
-7-
211
5
6
23
11
11
12
NDFG010-1580SA
Unbalanced
Packing Information
Carrier Tape
Reel Dimensions
-8-
1580 MHz
NDFG010-1580SA
Unbalanced
1580 MHz
Outer Packing
Type
Quantity
Dimension
Description
Carton Box Ⅰ
10000
200×200×100
Carton Box Ⅱ
20000
200×200×200
anti-static plastic bag & carton box
1 reel / bag
5 bags / box (20000 pcs)
10 bags / box (40000 pcs)
Unit: mm
Weight
0.85
1.80
Unit: kg
Remarks
SAW devices should not be used in any type of fluid such as water, oil, organic solvent, etc.
Be certain not to apply voltage exceeding the rated voltage of components.
Do not operate outside the recommended operating temperature range of components.
Sudden change of temperature shall be avoided, deterioration of the characteristics can occur.
Be careful of soldering temperature and duration of components when soldering.
Do not place soldering iron on the body of components.
Be careful not to subject the terminals or leads of components to excessive force.
SAW devices are electrostatic sensitive. Please avoid static voltage during operation and storage.
Ultrasonic cleaning shall be avoided. Ultrasonic vibration may cause destruction of components.
Test Circuit
50Ω
PCB Footprint
-9-
NDFG010-1580SA
Unbalanced
1580 MHz
Recommended Soldering Profile
C DQHUAYING 2016. All Rights Reserved.
A
1.
2.
3.
4.
The specifications of this device are subject to change or obsolescence without notice.
Typically, equipment utilizing this device requires emissions testing and government approval, which is the responsibility
of the equipment manufacturer.
Our liability is only assumed for the Surface Acoustic Wave (SAW) component(s) per se, not for applications, processes
and circuits implemented within components or assemblies.
For questions on technology, prices and delivery, please contact our sales offices or e-mail sales@dqhuaying.com.
- 10 -
很抱歉,暂时无法提供与“NDFG010-1580SA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.87406
- 30+0.84284
- 100+0.81162
- 500+0.74919
- 1000+0.71797
- 2000+0.69924
