2SA1837 PNP
PNP Epitaxial Silicon Transistor
APPLICATIONS
Power Amplifier Applications
FEATURES
High collector voltage
VCEO=-230V (min)
Complementary to 2SC4793
High transition frequency :fT=70MHz(Typ.)
RoHS product
VCEO=-230V (min)
2SC4793
fT=70MHz(Typ.)
RoHS
r
to
Package
nd
uc
TO-220F
Order codes
Marking
Halogen Free
2SA1837
NO
mi
2SA1837-O
co
不ORDER MESSAGE不
不
Package
Packaging
TO-220F
Tube
Se
ABSOLUTE RATINGS (Tc=25℃ unless otherwise noted)
Parameter
Value
Unit
VCBO
-230
V
VCEO
-230
V
Emitter-Base Voltage
VEBO
-5
V
Collector Current DC
IC
-1
A
Base Current
IB
-0.1
A
2.0
W
W
Collector- Emitter Voltage
RO
Symbol
JS
MI
C
IB=0
Collector Dissipation(Ta=25
Collector Dissipation(Tc=25
PC
Junction Temperature
Tj
Storage Temperature
Tstg
150
-55~+150
THERMAL CHARACTERISTIC
Symbo
Parameter
min
max
Unit
Thermal Resistance Junction Ambient TO-220F
Rth(j-a)
62.5
/W
Thermal Resistance Junction Case
Rth(j-c)
6.25
/W
TO-220F
1/3
2SA1837 PNP
ELECTRICAL CHARACTERISTIC
Tests conditions
Parameter
Value(min)
VCE=-230V,IE=0
-1.0
μA
IEBO
VEB=-5V,IC=0
-1.0
μA
V(BR)CEO
Ic=-10mA,IB=0
-230
V
hFE
VCE=-5V,IC=0.1A
100
160
270
VCE(sat)
IC=-0.5A,IB=-0.05A
-1.5
V
VBE
VCE=-5V,IC=-0.5A
-1.0
V
fT
VCE=-10V, Ic=-0.1A,
70
MHz
Cob
VCB=-10V,IE=0,f=1MHz
30
uc
VCE(sat)- IC
nd
VCE(sat) V
Common emitter
co
COLLECTOR-BMITTER SATURATION
Tc=125
IC/IB = 10
Single pulse test
Tc=125
Vce=-5V
COLLECTOR CURRENT
VOLTAGE
Se
mi
Tc=25
RO
DC CURRENT GAIN hFE
hFE – IC
Tc=25
COLLECTOR CURRENT
IC A
PC-TC
Tc=25
PC (percent)
MI
C
JS
IC A
IC- VBE
Tc=125
pF
to
ON
r
ICBO
ELECTRICAL CHARACTERISTICS (curves)
COLLECTOR CURRENT
Unit
Value(typ) Value(max)
Common emitter
Vce=--5V
BASE-EMITTER VOLTAGE
VBE V
Infinite heat sink
CASE TEMPERATURE
TC
2/3
IC A
2SA1837 PNP
r
Tc = 25°C
to
Single nonrepetitive pulse
Curves must be derated linear
with increase in temperature.
COLLECTOR-EMITTER VOLTAGE
VCE
V
co
PACKAGE MECHANICAL DATA
MI
C
RO
Se
mi
TO-220F
JS
nd
uc
COLLECTOR CURRENT
IC A
SAFE OPERATION AREA
Unit
mm
mm
A
4.50-4.90
B
很抱歉,暂时无法提供与“2SA1837”相匹配的价格&库存,您可以联系我们找货
