CR0402FC20RS01
CR0402FC20RS01
    NEXTGEN
    贴片电阻 0402 ±1% 1/16W ±100ppm/℃
CR0402FC20RS01 数据手册
PART CODE: CR0402FC20RS01 SPECIFICATION SHEET SPECIFICATION SHEET NO. N0621- CR0402FC20RS01 DATE June 21, 2021 REVISION A0 DESCRIPITION Thick Film Chip Resistors, 0402 (1005 Metric) Series, L1.00*W0.50*H0.35mm, Tolerance:+/-1%, Resistance 20 ohm, Dissipation 1/16W Max. Operating Temp. Range -55°C ~+155°C Package in Tape/Reel, 10,000pcs/Reel RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER Aillen CR02FC20R PART CODE CR0402FC20RS01 VENDOR APPROVE Issued/Checked/Approved DATE: June 21, 2021 CUSTOMER APPROVE DATE: 1 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CR0402FC20RS01 THICK FILM CHIP RESISTORS 0402 SERIES MAIN FEATURE • High Reliability And Stability • Reduced Size Of Final Equipment • Lower Assembly Costs • Higher Component And Equipment Reliability • RoHS III Compliant And Halogen Free Products APPLICATION • Consumer Electrical Equipment • EDP, Computer Application • Telecom Application RFQ PART CODE GUIDE Request For Quotation CR 0402 F C 20R S 01 1 2 3 4 5 6 7 1) CR: Product code for Thick Film Chip Resistors 2) 0402: Series Code, 0402 (1005 Metric) Series, Dimensions L1.00*W0.50*H0.35mm 3) F: Resistance Range Tolerance Code, P: Jumper; B: +/-0.1%; D: +/-0.5%; F: +/-1%; J: +/-5% 4) C: Package Code, A: 4Kpcs/Reel; B: 5kpcs/Reel; C: 10kpcs/Reel; M: 15kpcs/Reel; D: 10kpcs/10” Reel; E: 20kpcs/10” Reel 5) 20R: Resistance value code. 0R: 0ohm; 1R2: 1.2ohm; 20R: 20 ohm; 10K: 10Kohm; 15K: 15 Kohm;10K5: 10.5Kohm; 100K: 100Kohm; 1M2: 1.2Mohm 6) S: SMD type code 7) 01: Internal control code, 1~3 digits or letter; Blank: N/A 2 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CR0402FC20RS01 THICK FILM CHIP RESISTORS 0402 SERIES DIMENSION (Unit: mm) Marking: Blank Image for reference 0402 Item Dimension L 1.00±0.05 W 0.50±0.05 T 0.35±0.05 Tb 0.25±0.10 Tt 0.20±0.10 Item Dimension W 0.50~0.60 L 1.40~1.60 D 0.40~0.60 Resistors Construction For Reference Recommended Solder Pad 3 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CR0402FC20RS01 THICK FILM CHIP RESISTORS 0402 SERIES GENERAL ELECTRONICAL CHARACTERISTICS Item Unit Symbol Characteristic Product Name CR Thick Film Chip Resistors Size 0402 0402 (1005 Metric) Series, Dimensions L1.00*W0.50*H0.35mm Resistance Range Ω Resistance Tolerance TCR 10MΩ≥R>10Ω Condition 20 F +/-1% ppm/°C ≤±100 R≤10Ω -200~+400 Max. Dissipation W 1/16 @ Tamb=70°C Operating Temperature ℃ -55 ~+155 Max. Operation Voltage V 50 @DC or RMS Max. Overload Voltage V 100 @DC or RMS Characteristic Condition TEST CONDITION FOR JUMPER (0 Ω) Item Unit Symbol Power Rating At 70℃ W 1/16 Max. Resistance mΩ 50 Rated Current A 1.0 Peak Current A 2.0 Operating Temperature ℃ -55 ~+155 Note 1) This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication 60115-8” 2) Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by RCWV = 𝑅𝑎𝑡𝑒𝑑 𝑃𝑜𝑤𝑒𝑟 × 𝑅𝑒𝑠𝑖𝑠𝑡𝑎𝑛𝑐𝑒 𝑉𝑎𝑙𝑢𝑒 or Max. RCWV listed above, whichever is lower. 4 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CR0402FC15KS01 THICK FILM CHIP RESISTORS 0402 SERIES GENERAL CHARACTERIZATION Standard values of nominal resistance are taken from the E24 & E96 series for resistors with a tolerance Of +/-0.1%, +/-0.50, +/-1%, +/-5%, The values of the E24/E96 series are in accordance with “IEC publication 60063” Derating: The power that the resistor can dissipate depends on the operating temperature; see Fig.1 Fig 1 Maximum dissipation in percentage of rated power as a function of the ambient temperature for CR0402 STORAGE AND HANDLING CONDITIONS 1) Products are recommended to be used up within two years since operation date as ensured shelf life. Check solderability in case shelf life extension isneeded. 2) To store products with following condition: Temperature : 5 to 40℃ Humidity: 20 to 70% relative humidity 3) Don't store products in a corrosive environment such as sulfide, chloride gas, or acid. It may cause oxidization of electrode, which easily be resulted in poor soldering b.To store products on the shelf and avoid exposure to moisture. Don't expose products to excessive shock, vibration, direct sunlight and so on. 5 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CR0402FC15KS01 THICK FILM CHIP RESISTORS 0402 SERIES REFLOW SOLDERING CONDITION The robust construction of chip resistors allows them to be completely immersed in a solder bath of 260 ℃ for 10 seconds. Therefore, it is possible to mount Surface Mount Resistors on one side of a PCB and other discrete components on the reverse (mixed PCBs). Surface Mount Resistors are tested for solderability at 235 ℃ during 2 seconds. The test condition for no leaching is 260℃ for 30 seconds. Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2. Fig 2. Infrared soldering profile for Chip Resistors TEST AND REQUIREMENTS Essentially all tests are carried out according to the schedule of IEC publication 115-8, category LCT/UCT/56(rated temperature range: Lower Category Temperature, Upper Category Temperature; damp heat, long term, 56 days). The testing also meets the requirements specified by EIA, EIAJ and JIS. The tests are carried out in accordance with IEC publication 68, "Recommended basic climatic and mechanical robustness testing procedure for electronic components" and under standard atmospheric conditions according to IEC 60068-1, subclause 5.3. Unless otherwise specified, the following value supplied Temperature: 15°C to 35°C. Relative humidity: 45% to 75%. Air pressure: 86kPa to 106 kPa (860 mbar to 1060 mbar). All soldering tests are performed with midly activated flux. 6 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CR0402FC15KS01 THICK FILM CHIP RESISTORS 0402 SERIES TEST METHOD AND REQUIREMENT REQUIREMENT TEST PROCEDURE / TEST METHOD Resistor Electrical Characteristics JISC5201-1: 1998 Clause 4.8 0Ω - DC resistance values measurement - Temperature Coefficient of Resistance (T.C.R) Within the specified Natural resistance change per change in degree tolerance. centigrade. Refer to “QUICK REFERENCE DATA”
CR0402FC20RS01 价格&库存
很抱歉,暂时无法提供与“CR0402FC20RS01”相匹配的价格&库存,您可以联系我们找货
