BZX84C2V4-BZX84C51
350mW Surface Mount Zener Diode
FEATURES
Planar Die Construction.
z
350mw Power Dissipation.
z
Zener Voltages From 2.4V -51V
z
Ideally Suited For Automated Assembly Prcesses.
to
r
z
APPLICATIONS
350Mw Surface mount zener diode
uc
z
Package Code
See Table on page2
mi
BZX84C2V4-BZX84C51
Marking
co
Type No.
nd
ORDERING INFORMATION
SOT-23
MAXIMUM RATING @ Ta=25℃ unless otherwise specified
Symbol
Value
Unit
VF
0.9
V
Power Dissipation
Pd
350
mW
Thermal Resistance, Junction to Ambient Air
RθjA
357
℃/W
Operating and Storage Temperature Range
Tj,Tstg
-65 to+150
JS
MI
CR
O
Forward Valtage@IF=10mA
Se
Characteristic
Notes: 1. Valid provided that device terminals are kept at ambient temperature.
2. Tested with pulses, 300μs pulse width, period = 5ms.
3. f = 1KHz.
www.jsmsemi.com
第1页,共5页
BZX84C2V4-BZX84C51
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Maximum Zener
Marking
Number
Code
Impedance
IZT
ZZT@IZT
ZZK@IZK
IR
VR
(μA)
(V)
Nom(V)
Min(V)
Max(V)
(mA)
(Ω)
(Ω)
(mA)
600
1.0
50
nd
VZ@IZT
Current
uc
Type
Reverse
Typical
Temperature
Coefficient @IZT
mV/℃
to
r
Zerner Voltage Range
Maximum
Min
Max
1.0
-3.5
Z11
2.4
2.2
2.6
5.0
100
BZX84C2V7
Z12
2.7
2.5
2.9
5.0
100
600
1.0
-3.5
BZX84C3V0
Z13
3.0
2.8
3.2
5.0
95
600
1.0
10
1.0
-3.5
BZX84C3V3
Z14
3.3
3.1
3.5
5.0
95
600
1.0
5.0
1.0
-3.5
BZX84C3V6
Z15
3.6
3.4
3.8
5.0
90
600
1.0
5.0
1.0
-3.5
BZX84C3V9
Z16
3.9
3.7
4.1
5.0
90
600
1.0
3.0
1.0
-3.5
BZX84C4V3
Z17
4.3
4.0
4.6
5.0
90
600
1.0
3.0
1.0
-3.5
BZX84C4V7
Z1
4.7
4.4
5.0
5.0
80
500
1.0
3.0
2.0
-3.5
0.2
BZX84C5V1
Z2
BZX84C5V6
Z3
BZX84C6V2
Z4
BZX84C6V8
CR
O
Se
mi
co
BZX84C2V4
4.8
5.4
5.0
60
480
1.0
2.0
2.0
-2.7
1.2
5.6
5.2
6.0
5.0
40
400
1.0
1.0
2.0
-2.0
2.5
6.2
5.8
6.6
5.0
10
150
1.0
3.0
4.0
0.4
3.7
Z5
6.8
6.4
7.2
5.0
15
80
1.0
2.0
4.0
1.2
4.5
BZX84C7V5
Z6
7.5
7.0
7.9
5.0
15
80
1.0
1.0
5.0
2.5
5.3
BZX84C8V2
Z7
8.2
7.7
8.7
5.0
15
80
1.0
0.7
5.0
3.2
6.2
BZX84C9V1
Z8
9.1
8.5
9.6
5.0
15
100
1.0
0.5
6.0
3.8
7.0
BZX84C10
Z9
10
9.4
10.6
5.0
1.0
0.2
7.0
4.5
8.0
BZX84C11
Y1
11
10.4
11.6
5.0
1.0
0.1
8.0
5.4
9.0
JS
MI
5.1
www.jsmsemi.com
第2页,共5页
BZX84C2V4-BZX84C51
Maximum Zener
Type
Marking
Number
Code
Impedance
VZ@IZT
IZT
ZZT@IZT
Reverse
Current
ZZK@IZK
Nom(V)
Min(V)
Max(V)
(mA)
(Ω)
(Ω)
(mA)
IR
Typical
Temperature
Coefficient @IZT
mV/℃
VR
to
r
Maximum
Min
Max
(μA)
(V)
0.1
8.0
6.0
10.0
0.1
8.0
7.0
11.0
Y2
12
11.4
12.7
5.0
25
150
1.0
BZX84C13
Y3
13
12.4
14.1
5.0
30
170
1.0
BZX84C15
Y4
15
13.8
15.6
5.0
30
200
1.0
0.1
10.5
9.2
13.0
BZX84C16
Y5
16
15.3
17.1
5.0
40
200
1.0
0.1
11.2
10.4
14.0
BZX84C18
Y6
18
16.8
19.1
5.0
45
225
1.0
0.1
12.6
12.4
16.0
BZX84C20
Y7
21.2
5.0
55
225
1.0
0.1
14.0
14.4
18.0
BZX84C22
Y8
22
20.8
23.3
5.0
55
250
1.0
0.1
15.4
16.4
20.0
BZX84C24
Y9
24
22.8
25.6
5.0
70
250
1.0
0.1
16.8
18.4
22.0
BZX84C27
Y10
27
25.1
28.9
2.0
80
300
0.5
0.1
18.9
21.4
25.3
BZX84C30
Y11
BZX84C33
Y12
BZX84C36
Y13
BZX84C39
nd
co
mi
Se
CR
O
uc
BZX84C12
28.0
32.0
2.0
80
300
0.5
0.1
21.0
24.4
29.4
33
31.0
35.0
2.0
80
325
0.5
0.1
23.1
27.4
33.4
36
34.0
38.0
2.0
90
350
0.5
0.1
25.2
30.4
37.4
Y14
39
37.0
41.0
2.0
130
350
0.5
0.1
27.3
33.4
41.2
BZX84C43
Y15
43
40.0
46.0
2.0
150
375
0.5
0.1
30.1
10.0
12.0
BZX84C47
Y16
47
44.0
50.0
2.0
170
375
0.5
0.1
32.9
10.0
12.0
BZX84C51
Y17
51
48.0
54.0
2.0
180
400
0.5
0.1
35.7
10.0
12.0
JS
MI
30
www.jsmsemi.com
第3页,共5页
BZX84C2V4-BZX84C51
JS
MI
CR
O
Se
mi
co
nd
uc
to
r
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
www.jsmsemi.com
第4页,共5页
BZX84C2V4-BZX84C51
PACKAGE OUTLINE
Plastic surface mounted package
SOT-23
SOT-23
A
K
B
Dim
Min
Max
A
2.85
2.95
B
1.25
C
E
H
G
1.85
1.95
H
0.02
0.1
0.1Typical
2.35
2.45
All Dimensions in mm
JS
MI
CR
O
Se
mi
co
K
SOLDERING FOOTPRINT
0.43
0.48
J
C
0.37
0.35
nd
G
1.35
1.0Typical
uc
D
J
D
to
r
E
Unit : mm
PACKAGE INFORMATION
Device
Package
Shipping
BZX84C2V4-BZX84C51
SOT-23
3000/Tape&Reel
www.jsmsemi.com
第5页,共5页
很抱歉,暂时无法提供与“BZX84C47”相匹配的价格&库存,您可以联系我们找货
