IRFR5505/IRFU5505
P-Channel 60 V (D-S) MOSFET
Descriptions
P 沟道 TO-252 / TO-251塑封封装场效应管。
特征
nd
uc
to
r
P-CHANNEL MOSFET in a TO-252 Plastic Package.
/ Features
大电流输出能力。无卤产品。
High Current Capability. HF Product.
用途
I-P a k
TO -2 5 1 A A
D -P a k
T O -2 52 A A
S
Applications
交流负载开关,蓄电池充电/放电保护。
Absolute Maximum Ratings(Ta=25℃)
D
符号
Symbol
数值
Rating
单位
Unit
VDSS
-60
V
ID(Tc=25℃)
-20
A
IDM
-80
A
VGS
±20
V
Avalanche Current
IAS
13.8
A
Avalanche energy L=0.5mH
EAS
65
mJ
PD(Tc=25℃)
W
PD(Tc=100℃)
10
W
Tj,Tstg
-55~150
Drain Current
Drain Current - Pulsed
MI
CR
Gate-Source Voltage
O
Drain-Source Voltage
Se
参数
Parameter
mi
极限参数
co
AC-in load switch,Battery protection charge/discharge.
JS
Power Dissipation
Junction and Storage Temperature Range
Maximum Junction-to-Ambient
t ≤ 10s
Steady-State
Maximum Junction-to-Case
Steady-State
RθJA
30
60
RθJC
www.jsmsemi.com
℃/W
7.5
第1/5页
IRFR5505/IRFU5505
P-Channel 60V (D-S) MOSFET
电性能参数 / Electrical Characteristics(Ta=25℃)
符号
Symbol
Drain-Source Breakdown Voltage
BVDSS
Zero Gate Voltage Drain Current
IDSS
Gate-Body Leakage Current
Forward
IGSS
测试条件
Test Conditions
VGS=0V
ID=-250μA
VDS=-60V
VGS=0V
VDS=-60V
TJ=55°C
VGS=0V
VGS=±20V
VDS=0V
最小值 典型值 最大值
Min
Typ
Max
-60
V
-1.0
μA
-5.0
μA
±0.1
μA
-1.7
-2.5
V
VGS(th)
VDS=VGS
ID=250μA
Static Drain-Source
On-Resistance
RDS(on)1
VGS=-10V
ID=-20A
87
92
mΩ
RDS(on)2
VGS=-4.5V
ID=-10A
98
102
mΩ
-0.7
-1.2
V
VSD
符号
Symbol
Ciss
Output Capacitance
Coss
Rg
CR
Total Gate Charge
Total Gate Charge
VDS=-25V
f=1.0MHz
VGS=0V
f=1MHz
330
VDS=0V
VGS=-10V
ID=-12A
VDS=-30V
3.8
Qgd
1.9
Turn-On Delay Time
td(on)
4.2
Turn-On Rise Time
tr
Turn-Off Delay Time
td(off)
MI
Gate Drain Charge
JS
Ω
7.5
Qgs
Body Diode Reverse Recovery
Time
Charge
pF
6.4
Gate Source Charge
Turn-Off Fall Time
单位
Unit
205
Qg(10V)
Qg(4.5V)
最小值 典型值 最大值
Min
Typ
Max
1650
VGS=0V
Crss
O
Reverse Transfer Capacitance
VGS=0V
测试条件
Test Conditions
Se
Input Capacitance
Gate resistance
IS=-1A
mi
参数
Parameter
co
Gate Threshold Voltage
Diode Forward Voltage
-1
单位
Unit
-70
nd
uc
to
r
参数
Parameter
VGS=-10V
RL=2.5Ω
1.2
VDS=-30V
RGEN=3Ω
tf
3.4
16
nC
ns
2
trr
Qrr
IF=-12A
dI/dt=500A/ms
IF=-12A
dI/dt=500A/ms
www.jsmsemi.com
27
ns
30
nC
第2/5页
IRFR5505/IRFU5505
/ Electrical Characteristic Curve
JS
MI
CR
O
Se
mi
co
nd
uc
to
r
电参数曲线图
www.jsmsemi.com
第3/5页
IRFR5505/IRFU5505
Package Outline
TO-252AA Outline
Dimensions are shown in millimeters (inches)
nd
uc
to
r
2.38 (.094)
2.19 (.086)
6.73 (.265)
6.35 (.250)
-A1.27 (.050)
0.88 (.035)
5.46 (.215)
5.21 (.205)
1.14 (.045)
0.89 (.035)
0.58 (.023)
0.46 (.018)
4
6.45 (.245)
5.68 (.224)
6.22 (.245)
5.97 (.235)
1.02 (.040)
1.64 (.025)
1
2
10.42 (.410)
9.40 (.370)
3
0.51 (.020)
MIN.
3X
1.14 (.045)
0.76 (.030)
0.89 (.035)
0.64 (.025)
0.25 ( .010)
M A M B
2 - DRA IN
3 - S OUR CE
4 - DRA IN
0.58 (.023)
0.46 (.018)
mi
2X
co
-B 1.52 (.060)
1.15 (.045)
LEA D AS SIG NME NT S
1 - G AT E
NOT ES:
2.28 (.090)
1 DIME NSIO NING & T OLE RANCING P ER A NSI Y 14.5M, 1982.
2 CO NTRO LLING DIMENS ION : INCH.
3 CO NFO RMS T O JEDE C O UTLINE TO -252AA .
4 DIME NSIO NS S HO W N ARE BEF O RE SO LD ER DIP ,
SO LDER DIP MA X. +0.16 (.006).
O
Se
4.57 (.180)
CR
Part Marking Information
MI
TO-252AA (D-Pak)
E X A M P LE : T H IS IS A N IR F R 5 5 0 5
W IT H A S S E MB L Y
LOT C OD E 2101
JS
P A R T N U MB E R
IR F R5505
C H N 2101
Made in
www.jsmsemi.com
A S S E MB L Y
L O T C OD E
第4/5页
IRFR5505/IRFU5505
Package Outline
nd
uc
to
r
TO-251AA Outline
6.73 (.265)
6.35 (.250)
2.38 (.094)
2.19 (.086)
-A-
0.58 (.023)
0.46 (.018)
1.27 ( .050)
0.88 ( .035)
5.46 (.215)
5.21 (.205)
LEAD AS SIG NMENT S
4
1 - G AT E
2 - DRA IN
6.45 (.245)
5.68 (.224)
6.22 ( .245)
5.97 ( .235)
1.52 ( .060)
1.15 ( .045)
1
2
3
-B -
co
NOT ES :
1 DIME NSIO NING & T OLE RANCING P ER A NSI Y14.5M, 1982.
2.28 (.090)
1.91 (.075)
2 CO NTRO LLIN G DIMENS ION : INCH.
3 CO NFO RMS TO J EDE C O UT LINE TO -252AA .
1.14 (.045)
0.76 (.030)
3X
mi
9.65 (.380)
8.89 (.350)
0.25 (.010)
2.28 (.090)
M A M B
0.58 (.023)
0.46 (.018)
O
2X
4 DIME NSIO NS SHOW N A RE BEF O RE SO LDER DIP ,
1.14 (.045)
0.89 (.035)
0.89 (.035)
0.64 (.025)
Se
3X
3 - S OURCE
4 - DRA IN
CR
MI
TO-251AA (I-Pak)
JS
E X A M P LE : TH IS IS A N IR F U5505
W IT H A S S E M B LY
LO T C O D E 2103
P A R T N UM B E R
IR F U5505
CHN
2103
Made in
A S S E MB L Y
L O T C OD E
www.jsmsemi.com
第5/5页
很抱歉,暂时无法提供与“IRFR5505”相匹配的价格&库存,您可以联系我们找货
