BRCS3401MC
Rev. B Dec.-2018
DATA SHEET
Descriptions
SOT23-3 塑封封装 P 道 MOS 场效应管。P- CHANNEL MOSFET in a SOT23-3 Plastic Package.
特征
/ Features
VDS (V) = -30V
ID = -4.2 A (VGS = -10V)
RDS(ON) < 60mΩ (VGS = -10V)
RDS(ON) < 65mΩ (VGS = -4.5V)
RDS(ON) < 120mΩ (VGS = -2.5V)
无卤产品。Halogen free product.
用途
Applications
适用于作负载开关或脉宽调制应用。
This device is suitable for use as a load switch or in PWM applications.
内部等效电路
引脚排列
/ Equivalent Circuit
/ Pinning
3
1
2
PIN1:G
印章代码
PIN 2:S
PIN 3:D
/ Marking
Marking
http://www.fsbrec.com
B1H
1/8
BRCS3401MC
Rev. B Dec.-2018
极限参数
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
Drain-Source Voltage
符号
Symbol
VDS
数值
Rating
-30
单位
Unit
V
Drain Current – Continuous
ID
-4.2
A
Drain Current- Continuous A
ID(Ta=70℃)
-3.5
A
IDM
-30
A
VGS
±12
V
PD
1.4
W
PD(Ta=70℃)
1.0
W
TJ, TSTG
-55 to 150
RθJA
125
℃/W
RθJL
60
℃/W
Pulsed Drain Current B
Gate-Source Voltage
Total Power Dissipation
A
Total Power Dissipation A
Operating and Storage Junction Temperature
Range
Maximum Junction-to-Ambient A
Maximum Junction-to-Lead
电性能参数
C
/ Electrical Characteristics(Ta=25℃)
参数
Parameter
符号
Symbol
Drain–Source Breakdown Voltage
BVDSS
测试条件
最小值 典型值
Test Conditions
Min
Typ
VGS=0V
ID=-250μA -30
最大值
Max
V
-1
μA
-5
μA
±0.1
μA
VDS=-24V
VGS=0V
Zero Gate Voltage Drain Current
IDSS
VDS=-24V
TJ=55℃
VGS=0V
Gate–Body Leakage.
IGSS
VGS=±12V
VDS=0V
On–State Drain Current
ID(on)
VGS=-4.5V
VDS=-5V
-25
Gate Threshold Voltage
VGS(th)
VDS=VGS
ID=-250μA
-0.7
RDS(on)(1)
VGS=-10V
ID=-4.2A
RDS(on)(2)
VGS=-10V
TJ=125℃
ID=-4.2A
RDS(on)(3)
VGS=-4.5V
ID=-4A
60
65
RDS(on)(4)
VGS=-2.5V
ID=-1A
75
120
Static Drain–Source
On–Resistance
Forward Transconductance
gFS
VDS=-5V
ID=-5A
Drain–Source Diode Forward
Voltage
VSD
VGS=0V
IS=-1A
单位
Unit
A
-1
-1.3
52
60
75
4
mΩ
8
-0.75
V
S
-1.0
2/8
V
BRCS3401MC
Rev. B Dec.-2018
电性能参数
DATA SHEET
参数
Parameter
Input Capacitance
符号
Symbol
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Gate resistance
Rg
Total Gate Charge
Qg
Gate Source Charge
Qgs
Gate Drain Charge
Qgd
Turn–On Delay Time
td(on)
Turn–On Rise Time
tr
Turn–Off Delay Time
td(off)
Turn–Off Fall Time
Body Diode Reverse Recovery
Time
Charge
测试条件
Test Conditions
VDS=-15V
f=1MHz
VGS=0V
f=1MHz
VGS=-4.5V
ID=-4A
VGS=0V
最小值 典型值
Min
Typ
957
最大值
Max
单位
Unit
pF
115
77
VDS=0V,
VDS=-15V
6
Ω
9.4
nC
2
3
6.3
VGS=-10V
VDS=-15V
RL=3.6Ω
RGEN=6Ω
tf
3.2
ns
38.2
12
trr
IF=-4A, dI/dt=100A/μs
20.2
ns
Qrr
11.2
nC
A: The value of R θJA is measured with the device mounted on 1in 2 FR-4 board with 2oz. Copper, in a
still air environment with T A =25°C. The value in any given application depends on the user's specific
board design. The current rating is based on the t ≤ 10s thermal resistance rating.
B: Repetitive rating, pulse width limited by junction temperature.
C. The R θJA is the sum of the thermal impedence from junction to lead R θJL and lead to ambient.
D. The static characteristics in Figures 1 to 6,12,14 are obtained using 80 μs pulses, duty cycle 0.5%
max.
E. These tests are performed with the device mounted on 1 in 2 FR-4 board with 2oz. Copper, in a still
air environment with T A=25°C. The SOA curve provides a single pulse rating.
3/8
BRCS3401MC
Rev. B Dec.-2018
电参数曲线图
DATA SHEET
/ Electrical Characteristic Curve
4/8
BRCS3401MC
Rev. B Dec.-2018
电参数曲线图
DATA SHEET
5/8
BRCS3401MC
Rev. B Dec.-2018
外形尺寸图
DATA SHEET
/ Package Dimensions
6/8
BRCS3401MC
Rev. B Dec.-2018
印章说明
DATA SHEET
Marking Instructions
B1H
说明:
B1:
为型号代码
H:
为公司代码
Note:
B1:
Product Type Code.
H:
Company Code.
7/8
BRCS3401MC
Rev. B Dec.-2018
DATA SHEET
回流焊温度曲线图(无铅)
Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 150~180℃,时间 60~90sec;
1.Preheating:150~180℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件
Resistance to Soldering Heat Test Conditions
温度:260±5℃
包装规格
Time:10±1 sec
/ REEL
Package Type
封装形式
使用说明
Temp.:260±5℃
/ Packaging SPEC.
卷盘包装
SOT-23-3
时间:10±1 sec.
Units 包装数量
Dimension
包装尺寸
3
(unit:mm )
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
3,000
10
30,000
4
120,000
7〞×8
210×205×205
445×230×435
/ Notices
8/8
很抱歉,暂时无法提供与“BRCS3401MC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.17625
- 100+0.16375
- 300+0.15125
- 500+0.13875
- 2000+0.13250
- 5000+0.12875
